Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Frig is not cold- alarm keeps going off but freezer says it is 6 degrees and it seems fine - just the frig part not cold. It is up to 47 degrees
    Genius:
  • 1,114 Answers
It sounds like you may have a faulty thermostat, or a control panel issue. I would recommend that you call a repairman, that will alleviate the guess work as it could be a few things that could be wrong.
Posted on Mar 23, 2011
Refrigerator freezes
Sounds like might be the Temperature Control Thermostat or some sensor in the circuitry telling the compressor and cooling parts to keep running because it thinks it isn't cold enough. There is probably a circulation fan to blow the cold air through the damper and it may not shut off either, conveying too much cold thermal conduction through ducting and all frig parts, regardless of damper being closed or open. With the temperature set on low, do the compressor and fans ever shut off once cold temperatures are attained? Freezer should be 0 or lower, frig 35-40.
check this video at RepairClinic.comhttp://www.youtube.com/watch?v=5vA8Ksv5kVY&feature=player_embedded
Apr 07, 2013 | Electrolux Refrigerators
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
Whirlpool Frig/Freezer - Frig side too warm at 60 degrees
Check for another fan to cool the fridge side. It could be bad.
murf427
Aug 01, 2012 | Whirlpool Refrigerators
I have a new frig that I keep in my garage to keep extra food and drinks in. Since the weather turned cold, the freezer is not working properly. The frig still seems to working great. Can you help with...
If the ambient temp is below 52 degrees the unit will not work properly throught the cycles you will need to get what is call a garage kit to install in the unit.
Dec 25, 2010 | Frigidaire FRT21H8 Top Freezer...
Freezer Alarm keeps going off...
I think your freezer's coils have been damaged. Consult a enjinner.
Aug 10, 2009 | Kenmore Freezers
My Jenn-Air frig, model JCD2389G,isn't cooling. It's less than 7 years old. Freezer seems fine. Frig is set at coolest and still is only 55 degrees. Cleaned back of frig, what else do I check? thank you,...
Check the fan located in the freezer compartment.
This fan blows the cold air from the freezer into the fridge and is about 40 dollars for the part. Simple to fix too.
Gary
Jun 05, 2009 | Jenn-Air JCD2389G Side by Side...
Freezer 28 degrees at full cold
that's good. It 's not a deep freeze.
May 01, 2009 | Refrigerators
Freezer is freezing but fridge is not cold as it was
Sounds like defrost timer is not putting the refrigerator in defrost every 8 hours. You freezer should be below -5 degrees. Also the condenser beneath the refrigerator possibly needs cleaning. First slowly turn the defrost timer clockwise until freezer goes in defrost. You should hear the sound of crackling noise in freezer after about one minute into defrost. If timer does not come out of defrost or does not turn itself then replace it. Let me know what you find, Thanks Sea Breeze
Feb 07, 2009 | Frigidaire FRT15G4B Top Freezer...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
75 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
