Question about Sylvania G-Netbook
I have wireless connection but can't connect to the internet. I can however connect my ethernet cord in and get on the internet that way. What could be the problem
  • 187 Answers
You may wanna check if the wireless switch is on or off (usually located on the front of the pc and it needs to be toggle on the right side)..if not work you may wanna try to update the wifi driver under device manager..
hope this helps :D
Posted on Mar 24, 2011
Can I disable wireless and connect with ethernet cord and modem, for work do not want remove wireless cord, in the day want to be able to use my wireless.
Are you talking about direct-connecting via Ethernet to a cable or DSL modem? You shouldn't have to disable wireless to do that. If the cable modem has an open Ethernet port, you should be able to run a straight-thru Ethernet Cat-5 cable between that port and the Ethernet port on your laptop. The laptop should recognize that it is connected to the modem through the direct connection. Check the manual for the cable modem or information supplied by your ISP for connection details. You may have to do some setup on the modem to get an Internet connection, like having your ISP 'activate' the modem. Just be sure your Ethernet cable is a straight-thru, standard Ethernet cable, and not a 'cross-over' cable such as is used to transfer data between two computers.
Jul 24, 2014 | Dell Inspiron Computers & Internet
Can not connect to internet with TL-WR340G
try to unplug and replug ethernet cord. if the ethernet port has no blinking lights try to change ethernet cord.
May 16, 2012 | D-Link DI 514 Wireless Router (DI-514)
Do u need a wireless adaptor to set up xbox live??
No, a Xbox 360 Wireless Adapter is not required to access, and set up Xbox Live, but you will need an internet connection. If you are close enough to a modem or router, you can buy an Ethernet cord, and plug it in to both the modem/router, and firmly into your Xbox 360 console. You will either need the Xbox 360 Wireless Adapter, or the Ethernet cord. Ethernet cords are very cheaper, much cheaper than a Wireless Adapter, but the Wireless Adapters are much or easier to reason with. So choose wisely with money.
Jul 06, 2011 | Microsoft Xbox 360 Console
How to hook up to new computer
1.You should have a modem you received from your ISP (Internet Service Provider).
2.Plug the Ethernet Cord Into the Internet port of your router.
3.If you have a desktop computer plug in the ethernet cord into one of 4 ports of the router.
4.Open you wireless connections and connect to the internet.
Mar 20, 2011 | Belkin Basic Wireless Router
How to connect to the internet
You should have a home modem from and ISP (Internet Service Provider) Also If you have a router you need to plug the Ethernet Cord (the cord that looks like a Giant phone line) into the internet port of the router, Now if the router is a wireless router and you want to use the internet wirelessly you need to open your wireless connections and you will see your router in the list. Simply double click the connection and it will automatically connect for you. If you do not have a wireless router and you want to connect more than one computer to the internet,Simply keep the ethernet cord plugged into the internet port on the router and you should have 4 other ports next to each other. Plug another ethernet cord into port 1 and plug into the back or side of computer. That's it. I hope this helped have a good day
Sep 29, 2010 | Computers & Internet
Connectivity issues with my srx200 wireless router
First take the ethernet cable one end should fixed with ur PC/laptop and other end connected to ur modem.finally configure the access page .
Apr 30, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
I have an acer aspire 6930 what are the steps to connect to wireless internet I have a wireless moden but have to keep the ethernet phone cord plugged in to browse the net please help
all you have to do is, take the wireless modem and check if there ports at the back for connecting the ethernet to the modem(mostly it will be there).you can refer the manual of the wireless modem to connect the modem to your acer(i.e the connections of cables)in a step by step process.i am telling this since you have not specified your modem's manfacturer and model no. you have to the install the software from the installation cd of the modem in your laptop.
the defaualt connection will be to connect the phone's ethernet cord to the main input of the modem(if you are using the phone for internet). and the power adapter in the nearby small slot.
Jul 20, 2009 | Computers & Internet
I need to connect my router to a Motorola AT&
The connection should be, from the modem connect the ethernet cord to the INTERNET/WAN port of the router. And your PC to port 1 of the router as well. You can then run the setup CD That came with your router.
Jun 24, 2009 | Computers & Internet
I cant play online without the modem being by my ps3?
Yes, using a longer ethernet cord will work, but the PS3 has a bult-in WiFi card that can connect to any wireless router (you can buy a wireless router from a computer store like BestBuy).
If you are going to buy a wireless router, see if a wireless G-mimo or wireless N with signal boost is within your budget. Try looking through the network settings to see if you can connect through the wireless router.
Or just get a longer ethernet cord and run it directly to the PS3 from the router. Ethernet cords are the most reliable connection, granted you are on a good internet connection, they won't get interference from things like mobile phones, cordless phones, microwaves, TV's etc.
I have both the PS3 and Xbox 360 and the only thing I like better about the PS3 is the free online game play and Blue-Ray. Other than that, they're even. Good luck and have fun online! If you find me (wraith0127) say hi! Don't forget to rate. Thank you!
Mar 02, 2009 | Sony Playstation 3 (PS3) Console
Sylvania G-Netbook Logo
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
