Question about RJ Tech RJ-4200
Can i connect the rj tech rj-4200 to a vga computer monitor
Sd 4200
Make sure your DVD player has HDMI or Component RGB output,you will also need RGB component cables or HDMI cables to connect the DVD player to your Vizio,once you have attached one of the above cables you will need to press the input button on your TV'S remote to select either HDMI or Component.
Jun 07, 2012 | RJ Tech 4200 DVD Player
I have the RJTECH 4200 Karaoke Machine. Worked fine for over a year and recentlt loaded a CD and the power shut off. Tried everything, can't get it to turn on. Need help on getting repaired. p.
A repair if total dead is possible. Follow the money or the voltage in this case from cord to switch and from there to power supply--should be AC or wall voltage up to the power supply and then get rectified (changed) from AC to DC.
If no AC voltage past the switch--test it with a ohm meter--off no reading, on a reading etc.
May 27, 2012 | RJ Tech RJ-4200
How do i connect compaq presario x1000 to external monitor
Hi Judy,
The Compaq Presario x1000 notebook offers connections for external displays at the rear below the screen hinge as show in the picture below:
Identifying the back from left to right: Ventilation slots, External VGA Port, S-Video Port, USB Port, USB Port, RJ-45 Network Jack, RJ-11 Telephone Jack, Parallel Printer Port, USB Port and 1394 (a.k.a. "Firewire") Port.
You can connect a VGA monitor to the VGA port (blue colored jack) very easily. Any analog VGA monitor should readily connect to it. Additionally, the x1000 can output its display to TV or other monitor that accepts "S-Video" signals. An "S-Video" cable will be needed to connect between the "S-Video" jacks on the notebook (next to the VGA Port) and one on the TV. It is important to note that not all TVs support both or either "S-Video" or VGA inputs. When ever the there is a choice of using S-Video or VGA on a TV or monitor, the VGA will provide the best looking picture, and should be used.
I hope this helps and good luck! Please rate my reply - thanks.
Oct 03, 2011 | Compaq Presario X1000 Notebook
I HAVE A LG Full HD 1080p HDMI W2753V-PF 27-inch i was told my my tech that the monitor needs an inverter...Where can i get one and what is the part number ..if anyone could help me...
Well, you monitor has several input interfaces/connectors like;
  • D-Sub (Vga connector)
  • DVI
  • HDMI
If you are connecting this monitor to a computer, then you can use the Vga cable which came with the package. You can see the Vga cable here.. 3d8a2c8.jpg
You have to plug in either the terminal to the computer Vga port as shown below; 876c259.jpg
If in case you want better video quality and you don't have hdmi or dvi port
Dvi Port and Connector;
Hdmi Port
cables (these are available in most retailer stores)
It is not important to connect or purchase additional converter/hardware to connect you computer to the monitor, if you don't like the vga, you can simply get those cables.
I you let me know the Video card of your computer, I can help you better and shortened all these, but never mind, just refer to the pictures above and let me know if you can't make sure of yourself.
Good luck.
Thanks for using FixYa.
Jun 23, 2010 | Computers & Internet
Powers on but no screen
There may be problem with your Monitor or VGA Card.
When you turn on computer after sometime the monitor light will be orange colour it mean there is no fault in monitor. VGA Card is not sending signal on the monitor. you should change your VGA Card slot if the problem is still exist. Replace the VGA card or have a local tech take a look at the VGA card.
Mar 16, 2010 | Computers & Internet
My monitor cable does not connect to my computer, which is a optiplex 745, is there cable apadter that i can buy?
I ahve to assume that your new monitor has a DVI connection that looks like this...
ddcfd5a.jpg Your Optiplex probably has a VGA connection that look like this...
You'll need a VGA to DVI adapter (available at electronics stores or online everywhere.
Or, to take advantage of the higher quality resolution of your new monitor, you might consider buying and installing a new graphics card with a VGA & DVI adapter so you can plug it in directly and get higher res.
Oct 30, 2009 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
Picture moves vertically
if teh picture is also black/white, then it's set to the wrong system: press teh N/P button on yoru remote ... hopefully that will fix the problem
Oct 22, 2008 | RJ Tech RJ-4200
I do not here my voice in microphone
you have to play around with the volume buttons on the remote. Turn down the volume from the dvd player using the vol - button then turn up the mic volume on the front of the machine
Oct 12, 2008 | RJ Tech RJ-4200
New microphones will not work
http://reviews.cnet.com/dvd-players/rj-tech-rj-4200/4505-6473_7-31490033.html
Aug 22, 2008 | RJ Tech RJ-4200
Connecting samsung monitor to my laptop
Assuming you are connecting the mointor to DVI or VGA cable. You can connect the monitor through windows. In vista, right click, personalize, display settings, You should see a greyed out monitor. Click extened the desktop onto this monitor, It should automaticaly detect itself.
In xp its similar. Right click on desktop, go to properties. You should see a screen pop up. Go to the last tab. it should be monitor. Click on teh greyed out area and click Extend the display to this monitor.
May 30, 2008 | Acer TravelMate 4200 Notebook
RJ Tech RJ-4200 Logo
Top RJ Tech Televison & Video Experts
Tom Chichester
Are you a RJ Tech Televison and Video Expert? Answer questions, earn points and help others
