Question about Vacuums
The multi speed switch on my Lasko 20" home box window fan stopped working. Can it safely be rewired by cutting out the switch and rewiring using wire nuts to re-attach the plug cord directly to the two highest speed (4) wires? Which is really speed #3 I tested it using just electricians tape for the test. It worked fine when plugged in for testing. If there are no firs hazards I will place wire nuts on all connections andone wire nut each on the unused speed wires #2 #3, which are really speeds 1 and 2 because switch wire for on/off is wire#1. MAIN CONCERN - any safety hazards ...um...like FIRE? THAKS A LOT!!
Noggin
  • 944 Answers
SOURCE: Rainbow Vacuum Model D3B
If it won't work without a ground wire, but still works with one, then you must have a ground/earth connection to make it work - it sounds like there is a safety device that needs an earth to release, you could almost certainly bypass this relatively easily, but it will be there for a good reason and that would be dangerous. Bearing this in mind, regardless of which 2/3 prong adaptors you use, without an earth connection it will not function without risk probably of electric shock from the case or damage to the vacuum, else the safety device would not be there. Get an electrician to your home, and make him install grounded sockets where necessary (should be all, but at least get a couple). Ungrounded/unearthed domestic power sockets at all domestic AC voltages are lethal eventually, to man or machines. A lot of devices don't need an earth, but especially something with a big motor or a metal case usually does. At least ask a local electrician what he thinks. If you want to do it yourself, an Earth circuit in your home is not too hard to achieve if you have basic wiring skills (and access to the ground floor), but most insurance would dislike the idea - if you want to - post again and I may talk you through it. Hope this helps :) Please be careful :(
Posted on Mar 24, 2007
reddevil6
  • 1673 Answers
SOURCE: Rainbow D4C power switch replacement
As far as I know, that switch with 6 terminals is still available. But if not, I would wire the 2 for the power head and the 2 motor wires together. Then you would have 4 leads to attach.
Posted on Jan 31, 2008
RockyNR1
  • 324 Answers
SOURCE: Kirby G6 Power Switch Test ?
You can look at the wiring diagram and try to figure out how to use a circuit tester to test the switch but I would just suggest just swapping it for a good one (always good to have one good switch for testing) and see if it solves the problem.
Good Luck
Rocky
Posted on Oct 30, 2008
  • 44 Answers
SOURCE: Electrolux Guardian canister electrical problem
I believe there is a fused lead inside of the canister. Depending on where you connected your test light, you may have blown this fuse. I don't think you will have much luck finding aftermarket parts for this unit, so you may want to find an Aerus dealer. You can go to Aerusonline.com and use the dealer locater to find the closest store. Good Luck!
Posted on Jan 02, 2009
gaztechno
  • 3 Answers
SOURCE: vacuum won't switch on;got it apart;cord ok;need wiring diagram
Its a great idea to write on paper how its connected . So it helps with dis assembly & reassembly . I tried a Internet search . Looks like it'd cost money for a service manual. Though. I found a Kirby Spares Website that could help. Although it doesnt have Document downloads with repair help. There are spares & there is a telephone number for an engineer available during office hours. That you could ask for repair help. With wiring connections for your Kirby G3.
http://kirby-owners-club-shop.com/faqs.htm
The Engineers Telephone Number is 0845 388 9301
I repaired my Parents Kirby Heritage some while ago. With a new set of Brushes. Bulb Repair.
They are a Great Machine. Bit Expensive. Though Tough & Well Made !
Gary
Posted on May 24, 2009
How to replace el8602a power cord
Electrolux Vacuum Cleaner EL 8602A How to replace the ...
www.manualsonline.com/.../vacuum.../how-to-replace-the-power-cord-o...
Question About Electrolux Vacuum Cleaner EL 8602A. How to replace the ... How toreplace the power cord on Electrolux EL8602A. Asked by gerry nickel on ...
Rewiring the Power Cord for the Electrolux Model G ...
? 4:27
https://www.youtube.com/watch?v=4uqNa7mVBO8
Jan 30, 2012 - Uploaded by Jayson1940D14
Rewiring the Power Cord for the Electrolux Model G ... How tochange the Electrolux 725 Suspension Plate - And Get Access To The Motor ... Brown Vintage ELectrolux Canister Vacuum Cleaner 1401-b - Duration: 0:17.
Electrolux Nimble Upright Vacuum, EL8602A - YouTube
? 3:49
https://www.youtube.com/watch?v=-anwdD4fK-o
Nov 11, 2014 - Uploaded by Michael Callender
Electrolux Nimble Upright Vacuum, EL8602A Best Price ... Dirt Devil UD70095 Power Reach Multi Cyclonic Pet Bagless Upright - Duration: ...
Jan 30, 2016 | Vacuums
MR Oreck keeps cutting out
Cable has broken internally, wiggling is temporarily making contact which is why it then works. Get it rewired by a cometent person !
Oct 18, 2014 | Vacuums
MY ORECK KEEPS CUTTINH OUT IF I WIGGLE THE WIRE IT STARTS AGAIN IT IS AN ORECK XL UPRIGHT
Cable has broken internally, wiggling is temporarily making contact which is why it then works. Get it rewired by a cometent person !!!
No power, electrical wirring is intact from power plug to switch to pcb
normally with a henry the cable breaks from where it joins the hoover just take apart from hoover end cut about a foot of cable off and then rewire
Feb 09, 2014 | Henry Numatic "" Canister Vacuum
Poor cable connection in handle
You will have to open handle where switch is . undo screws where power cable goes into switch. Cut +/- 100mm off exsisting cable & rewire .
Sep 23, 2012 | Sebo Automatic X1 Bagged Upright Vacuum
This fan will not run. We do not have a model # but the numbers on it is:LOT NO. T-163 P/N 2030016H. Is there a wiring diagram we can get for this? It is a fan withat goes in a window and has an exhalst...
This is used in a Lasko 2155A window fan. It is best to buy an entire new unit. The motor does not seem to be available anywhere.
11/20/2015
Feb 26, 2011 | Dayton Vacuums
How to rewire the vacuum
strip wires and connect them. their color-coated
May 19, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
I need to replace vacuum hose
If you have a vise, put the end in to and you want to just squeeze it so you can get to the 2 tabs inside and using 2 flat blade screwdrivers, pry outward and the hose should come out of the cuff. Sometimes you can just cut and rewire, but watch and match colored wires to the right colors, mix them up and you would have a electrical mess. When you put it back together, push the cuff down until you hear it snap into place.
Mar 24, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Replacement motor
The manual only show one wire from the motor going to the switch, the other going to the cord, then the ground wire. I would wire it the way your old motor was, could be that some models maybe were 2 speed and the other wire would be used for that. Either that or the wrong motor was in the box, it is the right part number (43576197 is Hoover number)
Nov 15, 2007 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
