Question about DeLonghi Ovens
Replacement of the bottom element of a 61G gas electric free standing oven
  • 25 Answers
SOURCE: GLEB27T8ABA Frigedare Double wall oven electric
check the fuse/breaker for the bottom element
Posted on Dec 12, 2007
  • 1314 Answers
SOURCE: Frigidaire GM deluxe electri dean (electric oven wall unit)
if you feel through the insulation you can find the two wires that attach to the element pull them through to plug the element back on but there is no plug per say but first are you sure the element is good were there no wires on the element when you removed it should have been two spade connectors with wires on them attached to the element hold my rating till you reply
Posted on Jan 11, 2008
aborcass
  • 2651 Answers
SOURCE: Replacement of bottom oven element for Whirlpool oven
its only screwed in to back wall no???if screws rusted well then drill htem out.hidden bake elemnet??hidden under oven cavity??in that case right side wall of unit comes off( a few screws down back side of panel and it removes from the side.(shut power first this element is always live!!!!!!!
Posted on Feb 24, 2008
  • 161 Answers
SOURCE: Kenmore electric stove heating element how to replace
A replacement is usually around $40. There are usually 2 screws holding the element in the back of the stove. Turn off the power and remove the element. There are usually only 2 wires. It really doesn't matter which goes where. Install the new element and see if it will shut off when oven reachers temp. If it continues to heat, there is another piece that needs to be replaced. If there is a contactor or relay replace it, If not the thermostat needs to be replaced. Sometimes when the element burns out it shorts to the ground and fuses the contacts forcing the element to stay on. Sometimes you actually have to turn off the power to the stove.
Posted on Jul 15, 2008
  • 338 Answers
SOURCE: how to clean gas wolf oven
No. Because if you dont get all the cleaner off you dont know if it would be toxic or not.
Posted on Jan 16, 2009
Why is oven not getting hot enough /not cooking from the bottom
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
I offer free advice bcuz God is so good!
Jan 01, 2017 | Ovens
Changed my Oven element, now top and bottom don't heat up
The bake element
Feb 15, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
I have a roper free standing stove. Everything seems to work except the oven. When I turn the thermostat to broiler it works but doesn't when I turn to oven
next time send the model number and say if it's gas or electric?if it's gas you have a bad bake ignitor,if it's electric you have a bad bake element
Apr 22, 2011 | Ovens
GE free-standing electric range Pre-heat oven temp is about 50 degrees less than what is set (i.e. set digital display to 400 and over only reaches about 350). Is there an adjustment that can be made to...
We have a new GE Range and the signal beeps at about 100 degrees below the temp which we have set . The dealer replaced the sensor and the control circuit, but there was no change.
A service tech from GE came to our house and explained that the new ovens have a bottom heating element which is covered and therefore heats the lower part of the oven more slowly; but the exposed upper element heats more rapidly and the sensor is located near the upper element. We were advised to wait for about 15-20 minutes after the beep before placing the food in the oven. Judging from the number of comments found online, this seems to be a feature of newer ranges.
SnapDoc
Nov 08, 2010 | GE JKS05 Electric Single Oven
Oven won't light - electronic ignition oven
Hi, it could be your, electric heating element and oven burner gas valve. both are located in oven burner compartment, remove last bottom panel, locate oven burner, the valve that feed gas to burner, has two wires connected to it, that's oven valve could be faulty, also look on side oven burner, you will see electrical heating element, could also be faulty, it's better to replace both oven valve and element, that's the most common problem, but first check oven thermostat, that's knob you turn to light oven, if thermostat o/k, then it's your oven valve or heating element, (used to ignite oven burner) or call a mechanic, good luck.
Aug 12, 2009 | Kenmore 33169 Gas Single Oven
Baking Element Caught fire
Elements wear out from the inside. Sooner or later it happens to all of them.
Mar 31, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Light and fan come on but oven does not heat up
If the fan comes on, it will not be the timer, it will be the oven element not working.
Remove inner rear cover of oven, and you will see the element, remove screws and element, detach wires and fit on new element, be careful not to loose the wires behind rear of oven.
You may not see anything wrong with element, but the odds are that is the prob.
Please leave a fixya rating for my proposed solution.
Yhanks.
Jan 30, 2009 | Electrolux EOB5665G Ultrafan Electric...
Ovens Logo
Top DeLonghi Ovens Experts
ashburton
Naftali Haskell
Level 1 Expert
Jon Lamb
Are you a DeLonghi Oven Expert? Answer questions, earn points and help others
