Question about Kirby Generation 3 Bagged Upright Vacuum
I have a small black plastic piece that came off the switch ,dont know where it goes re assembly
  • mark_wetzel5 Mar 24, 2011
    i have not put it together yet i need to know where the piece goes its like an 1" by 1" and has another 1/2 by 1/2 tail '
  • 10,319 Answers
The switch is fairly large so does the switch click on and off as it did when new? If not get a new switch
Posted on Mar 23, 2011
Dyson Dc07 Animal Cyclone Assembly will not release bin
I would highly recommend that you contact Dyson directly before you go breaking anything else. Good Luck!
Contact us
The Dyson Helpline is available during the following times (CST):
Monday - Friday: 8am - 8pm
Saturday: 9am - 6pm
Closed on Sunday
Aug 30, 2014 | Dyson DC-O7 Bagless Upright Cyclonic...
Switch Assembly
one spring larger goes on the red on /off small spring goes on the little white piece
Apr 05, 2014 | Dyson DC40 Multi-floor Vacuum DC40
I took apart my eureka quick up vacuum and am not sure how to re assemble
I just did the same thing and had to reassemble also. I recommend turning it upside down. First make sure the belt is wrapped around the motor threads as well as the brush threads, then rest the brush more or less where it goes in the front of the vacuum. The white plastic pieces each have a small hole - you need to insert one end of the brush into each while plastic piece. When you lie the plastic piece flat you should see that the other end fits together with the top of the vacuum. The trickiest part is getting the tiny little wheels into place. Just worry about the 2 in front first. Set them carefully into place in the square holes in the front corners of the machine. Use your finger or a screwdriver to fit the mini axles properly into the grooves. Carefully push the bottom of the vacuum into place until it seems to snap in place (be careful that the wires are tucked in well) and screw in the 4 main screws. Final step is to reattach the smaller black cover to the bottom (back) side - be sure to get that wheel in place before fitting the cover on and then tighten up the final 2 screws.
Mar 25, 2011 | Eureka& Cordless Quick Up Vacuum
Dyson dc05 takes the dirt up the cyclone cone instead of spinning it in the clear cannister and blocks the top filter within a few minutes??
Hi its Darran at Dyson.
From your description of the problem, it sounds as though the bin inner is missing. If you remove the bin and cyclone assembly from the machine and then seaprate the two pieces as if you were going to empty it, you should have a coloured piece of plastic in the bottom of the clear bin with a large black rubber seal around the top. If you dont, you will need to purchase a new bin assembly via our website at www.dyson.co.uk or via our Helpline on 0800 298 0298.
Kind regards
Darran
Dyson Customer Service
Jan 19, 2010 | Dyson DC05 Bagless Canister Cyclonic...
My son dropped the Hoover Floormate hard floor cleaner and a black piece with a spring came out. I dont know where it goes, and now the handle wont stay up.
From your description you have an issue with the pedal release in the base. this model is the original series, and I would not put too much money in the repair. not an easy cover to remove. check the base wheel assembly. the black pivot points break on these when dropped. If it is broke the part itself cost about $18. Cosider the overall performance and other repair items to determine worthwhile repair.
Oct 03, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
How do I replace the microswitch in my dyson DC04 Zorbster
Move the flexible hose at the rear out off the way and you will see a small hole that goes through to the on/off switch assembly. Use a small screwdriver through the hole to push the plastic clip away and you can then lift off the on/off button. You will then see a phillips screw that holds the switch assembly/housing to the main unit. Just unscrew and the whole switch unit can be removed.
Apr 24, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Replace power switch - Electrolux Epic series 6500
well, i post an answer in the wrong field, and i can't find it, so i will type one more time.
slide two vinyl side pieces off, and remove top halves. remove two screws from the switch, and remove it from top halve. between switch and outside button is a plastic rocker, which is broken. you will find two broken pieces, one spring for the rocker piece, and one small plastic rod, which goes inside of the spring for support. i do not know if part is available, but you can for quick fix like me, turn the switch on by the hand, assemble unit, and plug in, and plug out from the wall. whay? i dont have electrolux store close by.
john
Feb 21, 2009 | Electrolux Epic 6500 Vacuum
Spin brush removal
Brush Disassembly Hoover STEAM VAC Owners Manual F9514-900 (F9514900) does not
explain how to take the brush assembly apart. The instructions are as
follows:
Figure 1 shows the key
features. There are two
clear plastic outer pieces
which are held onto the
white inner piece with 3
tabs each. The clear
plastic tabs go underneath
the corresponding white
extended tabs on the white
plastic inner piece.
Figure 2 shows where the
screwdriver is inserted
(flat blade) and gently
pushed down while pulling
the clear plastic outer
piece away from the inner
white piece.
Figure 3 shows assembled
unit. Note extended brush
axle goes in center, which
fits into the female drive
unit on the shampooer.
I used the hose nozzle out
on the lawn to direct high
velocity water stream
trying to get the hair out
of the brushes. Hair and
fuzz remarkably entrained
in brushes, but I got 90% of it out.
Oct 19, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Ken 116 31912100
No belt, this is direct drive, the motor is part of the brush roll. If you go to sears.com, click on parts, put in you rmodel number, it starts with 116.*********. It will bring up a parts list along with a picture breakdown for you to look at, and you can order parts there also. You might also check where the hose goes into, some of these have a switch there, when you push the hose in it hits an actuator that engages the switch. This actuator breaks and then the brush roll won't turn because it can't engage the switch.
May 08, 2008 | Kenmore 31913 Progressive Direct Drive...
Kirby Generation 3 Bagged Upright Vacuum Logo
13 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
