Question about Garden
How do i change the lower drive belt on a troybuilt front engine riding mower
  • 718 Answers
On most units you have to drop the deck to change belts, get down there and check it out!! Good Luck..
Posted on Mar 24, 2011
John deere 855-70 manual
On ALL Deere riding lawn mowers, 1st, position the deck under the tractor. Depending on the belt drive: either PTO (the yellow button on the dash panel), or tension engaged-(a lever on the right side of the operator\'s seat), you loop the drive belt from the front of the deck to the pulley, always in the lower front area of the tractor\'s engine. If it has "beltguards" too close to the pulley, you must loosen the retaining bolt for the guard, it will allow the belt to squeeze by and onto the pulley. Then, 2nd but don\'t forget to retighten after slipping the belt on, push the "Deck heighth" lever fwd to drop the deck "hangars" at the rear of the deck into position to "pin" the eyelets with the supplied pins, washers and keepers: usually a cotter pin or a lynchpin that inserts thru a hole on the smooth bolt-pin. The easy part\'s over, but don\'t panic. 3rd, lift the front of the deck onto a block, allowing a heighth to apply the "adjusting rod" into the front of the mower chassis. Screw the retaining nut onto the threaded (long bolt) and remove the block. You\'re done. Next, and very important, RAISE & LOWER the deck, engage the belt tension, (here you may have to clear the area and start the engine to engage the PTO drive, if it\'s electronically controlled belt-drive), this assures nothing is "misaligned" or improperly positioned. Now, if the machine is on a flat surface, lower the deck to a point just above the ground and measure the distance in four (4) corners of the deck and record the ht. Make the adjustments to LEVEL the deck. Now you\'re ready to start the engine from the operator\'s seat, slightly increase the engine from idle to 1/4 throttle speed so that engaging the drive belt won\'t kill the engine. Ensure the belts run smoothly, the blades turn, and the engine doesn\'t "bog". Lower the deck to a desired cutting ht., now MOW the grass!
Jan 28, 2014 | Garden
Transmission drive belt keeps breaking on my troybuilt bronco riding mower
look for a damaged pulley or seized idler they can cause premature failure of a belt
Sep 10, 2013 | Troy Garden
Steps needed to change transaxle belt
lift the front of the tractor up at least 3 feet and lower the mow deck to give you clearance. push the clutch pedal and lock it down to release belt tension. remove the mower belt from the engine pulley only. remove the trans belt from the idlers about midway back then from the trans pulley & finally from the engine pulley. put the new belt around the engine shaft above the mower drive pulley but not on the drive pulley then around the trans pulley. now you can put it on the drive pulley and finally on the idlers. make sure you have it under all the various keepers or the belt will shred in like 10 minutes. release the clutch pedal & check the belt again to ensure it is in the correct place. replace the mower drive belt & ensure that didn't come off other pulleys in the process. lower the front of the tractor and test
Oct 14, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Troybuilt riding mower won't pickup grass
can you tell me if unit has timmed blades and is the unit a rear catching unit ?
be sure engine speed is correct most applications this between 3400-3600 rpm
if unit has timmed blades - be sure that the blades are timmed correctly , and the correct blade is on correct side
if not timmed be sure blades are sharp and balanced , make sure the wing turn up is ok ( blade speed and turn up creates air velocity)
make mandrell vents are clear if unit has them , make deck belt is not slipping, and is not damaged
make sure deck belt tension is correct
make sure pulley splines are ok and are fixed tightly to spindle shafts and keys are in place
make sure the catcher vents or bag are clear and air can flow through,
lastly be sure that the deck is set level side to side and the deck has between 5 - 10 mm rake that is the height of front of the deck is 5- 10 mm lower than the rear of the deck
and the deck lifts up evenly
note let me know model and spec number of ride on mower
will try and help further if this info does not help
cheers paul46
Sep 13, 2010 | Troy Garden
How to change an engine to deck belt on a Troy Bilt riding lawnmower
Either put the front of the mower on a jack or ramps and lower the deck. There should be adjusters on the pulleys which hold the belt on. Loosen these, then put on the new belt and use pulley tensioners to adjust the belt securely.
Aug 05, 2010 | Troy Garden
FORWARD AND REVERSE GEAR SELECTION BACKWARD
Recheck your belts, does your engine have a pto
Jul 28, 2009 | Garden
Owners manual
Maintaining Riding Mowers Regular maintenance can reduce repairs. pagetools_04a.gif spacer.gif spacer.gif
Components of a typical riding lawn mower. (click to enlarge)
It's fun to ride around the yard on the mower, watching scrubby grass (and weeds) turn into trimmed lawn. However, when the grass looks as bad after you mow as it did before, or the mower doesn't want to start, riding mowers aren't as much fun. That's when it's time to put on your Fix-It Club hat and have some more fun.
A riding lawn mower is a gas-powered machine for cutting grass. The engine turns a rotating blade that cuts the top off the grass blades to a specified height. The operator sits atop the mower on a tractor-type seat with speed and height controls nearby. Riding mowers also can be used to pull small utility carts for other yard jobs.
To remove the mower deck:
  1. Make sure that the parking brake is locked.
  2. Place scrap lumber under the front and rear of the deck.
  3. Use the deck lever to lower the deck.
  4. Remove attachments from the deck.
  5. Remove the blade drive belt from the front pulley.
  6. Remove the front and rear deck fasteners, following instructions in your owner's manual.
  7. Use the deck lever to raise the deck.
  8. Remove the scrap lumber.
  9. Remove the deck from under the mower.
To adjust the drive belt:
  1. Remove the belt from the large idler pulley.
  2. Remove the belt from the adjustable idler pulley.
  3. Carefully remove the spring-loaded large idler pulley.
  4. Loosen the adjustable idler pulley and move it slightly toward the rear of the mower to tighten it[md]or move it toward the front to loosen it—and retighten the pulley.
  5. Replace the belt.
  6. Check belt tension and readjust as needed.
Apr 12, 2009 | Garden
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
