Question about Dometic Rooftop RV Air Conditioner
Ac works for about 3 mins. then kicks out runs 5 mins. then cools for 3 mins.
    Champion:
  • 299 Answers
Circuit board. look at board on outside heater box most boards control both , check for flashing light and count blinks , read chart on blower about the flashes. new boards around 120.00
Posted on Mar 23, 2011
Ac compressor runs 5 min shuts off then restarts 10 minutes later for another 5 min fan runs ok
Shutting down on safety. It's likely a pressure switch, possibly low pressure if fan is running.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
May 24, 2017 | Heating & Cooling
The upstairs ac display is blinking cool on, but not cooling the house. The outside fan is running. please help. The downstairs display and unit working properly
Normally Honeywell will "blink" COOL ON when its in a timed delay, usually 3-5 mins. And then COOL ON will stay on without blinking. If you turn tstat off then wait about 5 mins, then turn to cool, watch for the blinking, then wait 5 more. If it doesn't turn on, check/change the batteries if it has them. Try turning the AUTO/ON to the on position to bring on the fan only. It won't cool doing this but it helps in homeowner troubleshooting.
Aug 05, 2015 | Honeywell Heating & Cooling
SPLIT AC CONDENSER TRIPS AFTER 1 OR 2 MINS, ONLY DURING THE DAY TIME
The condensor is not cooling fast enough. Try cleaning the condensor coil. Also check that the fan goes on. At night the outside temperature is cooler and does not need much work to cool down the condensor.
Jul 15, 2012 | Haier Heating & Cooling
Honeywell Thermostat RTH6350 makes heat run in AC mode after AC runs
Well, if it wasn't doing that before then you more than likely know its in your wiring. Cools down then heats back up sounds like the auto change over is on, and the heat setting is higher than the cool setting?
Mar 02, 2017 | Heating & Cooling
I installed a new colman mack thermostat in my camper witch has a colman ac unit now ac unit runs 5 min then shuts off for 3 min then starts again and keeps doing this . so I by past thermostat and it will...
if it is a programmable thermostat you can unhook thermostat and when it comes on select 3 instead of 1. As it sounds as though it is short cycling this happens in older houses with drafts. Hope this helps Tim
Sep 07, 2010 | Coleman Mach III Air Conditioner
Ac starts kicks on and off every couple mins
Sounds like the compressor is the one making the "NOISE". If the sound sounds like something trying to start, then kicking off, its probably the compressor and not the fan. Hence no cool air.
Jul 26, 2009 | Dometic Rooftop RV Air Conditioner
Maytag mdg6700aww gas dryer runs but heat kicks out after 5 min
You have bad coils on your main gas valve . They tend to short (open) after getting warm which cuts off the gas to the burner . After cooling , they will work again for another 5 min until shorting again . Replace the coils (2 in a kit ).
Jul 12, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Ac set at 74 room temp up to 78 and no Ac kicking on.
it could be the thermostat is loose on the subbase or if you went from OFF to COOL and the stat is a digital stat It will not come on for five min. This is a delay set by the manufacture to protect the compressor. during normal operation you will not notice because thier will be more than 5 min from the time it shuts of till it need to come back on but if the system switch is set to off and you switch to cool or unit just shut off it will always delay 5min. usualy there will be some insdiction on the screen that it is in delay like a flashing COOL or SNOW FLAKE or the word WAIT. the unit will not be running until the flashing words go solid
Jun 26, 2009 | Honeywell Programmable Thermostat Heater
Thermostat just stopped working.
is the tstat in cool mode? if not hit the mode button untill cool pops up then hit the down airow untill desired temp. sometimes the thermostat has a 5 min delay so be patent. If unit still does not run call the service co. and find out about how long they warranty their service call. usualy one month.
Jun 14, 2009 | Honeywell Electronic Programmable...
Dometic Rooftop RV Air Conditioner Logo
179 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
