Question about Lofra MBX76MFI Dual Fuel (Electric and Gas) Kitchen Range
My friends fan assisted oven on my lofra cucine has stopped working where can i get it fixed
5 Suggested Answers
SOURCE: Lofra MXD96AMFE/C Dual Fuel Range Cooker
Hi
The timer on our Lofra MXUD76MFE broke about 2 months after the 12 month warranty ran out.
Being a bit of a fiddler i took the top off the cooker to access the timer (not that difficult) when i ispected the timer i was astonished that it had lasted the 14 months it had such was the quality of it.
The timer was easy to set to ensure the cooker worked but unserviceable to restore the timer mechanism.
I thought given that it was such a cheap looking part (even allowing for the exorbitant price of parts) it would be worth replacing.
Came across the new appointed distributor - Premier Appliance Brands - based in Warrington (01925 248980)
They gave me a part No of 03010631 but didn't have stock and initially could not give me a price. i left it a couple of weeks and rang back this week.
They quoted £77 - needless to say i didn't order it
Posted on Nov 30, 2007
SOURCE: LOFRA oven won't ignite/what are these symbols?
Figured out the triangles mean fan. I blows the hot air down. Still no clue about the other one. Found the sparky thing and scrubbed it with a wire brush (making sure the gas was off). After many more attenpts I turned on the top burner and tried again and it lit finnnnnaly.
Posted on May 29, 2009
javeedcare
  • 316 Answers
SOURCE: nothing on my lofra oven
Hi You need to check out the fuses and the power supply. Dont forget to check the power point as well.There seems to be no power supply to the unit.
Regards.
PLZ. dont forget to rate my suggestion.
Posted on Jul 19, 2011
  • 3 Answers
no power in the lofra oven
Posted on Sep 29, 2013
Our Lofra gas stove tops ignition isnt working on all jets. Electric oven is working. What could be the issue ?
personally I would call a repair service . gas being dangerous I do not recommend DIY fixes
Sep 12, 2016 | Lofra Kitchen Ranges
Where can I get an operating instructions manual for a LOFRA Quartz 60 electric oven.?
Hi, I have checked across the web andd cannot find a manual , however the LOFRA website has a contact facility through which they will probably be happy to assist
I have added a link to their on line enquiry form below
Jun 19, 2015 | Lofra Kitchen Ranges
Lofra oven doesent stay alight
I had the same problem with my Lofra, I removed the cover on the bottom of the inside of the oven and then unscrewed the metal bit under that. Then I tested it again so I could see why it wasn't lighting up. Turns out the heat sensor was in between two flames and wasn't detecting that the gas was on. I wiggled things around a bit until it stared working, then put the cover back on. Now it works wonderfully. Now I just have to fix the timer.. It doesn't ring when it reaches the end. Hope this solution works for you guys.
Dec 18, 2012 | Lofra MXD96MFEPI Dual Fuel (Electric and...
Lofra LEF9EGP electric oven stopped working - fuse?
You probably had the heating element burn out. Disconnect it and test for continuity. If open, replace it.
murf427
Aug 01, 2012 | Kitchen Ranges
Nothing on my lofra oven works small oven fine top fine oven died no lights or fan
Regards.
Jul 19, 2011 | Lofra MXGC96AMF/CV Dual Fuel (Electric and...
Hi I have a Lofra Maxima Model no: MXD96AMFEP and need the Oven Selector Switch and Oven Door Hinges - can anyone help please am deperate!
Hi Gemma, this is Carlos from Lofra of Brazil. I would recommend you to contact our headquarters in Italy to help you locate the needed part for your range.
Please write to consumerservice@lofra.it or call +39 049 9904811.
Kind regards,
Carlos Fleischfresser
Lofra Sud America
Jan 18, 2011 | Lofra MXGC96AMF/CV Dual Fuel (Electric and...
Max 160 degrees celcius
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 05, 2010 | Lofra MXD96MFEPI Dual Fuel (Electric and...
May 28, 2009 | Lofra PXUD66GGI/C Gas Kitchen Range
Cooker lofra
fuse in plug new one job done + wife turnd oven off ?
Aug 18, 2008 | Lofra MXGC96AMF/CV Dual Fuel (Electric and...
Kitchen Ranges Logo
178 people viewed this question
Top Lofra Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
ray gallant
Are you a Lofra Kitchen Range Expert? Answer questions, earn points and help others
