Question about JVC AV27WF36 TV
Tv wont turn on at all av-27wf36 - JVC AV27WF36 TV
  • rjblair65 Mar 24, 2011
    Its is not the fuse, that was one of the first things i checked
  • JVC Master
  • 2,098 Answers
Hi Rjblair65,
If the unit have no led light in the front panel after pushing the power on button and in the remote control, the fault is in the power supply section where the power cord is connected. Check the fuse first if blew replaced it with a new one(same voltage and current ratings). Let me know what you discover to assist you further.
Jdvillanueva
Posted on Mar 23, 2011
  • Jdvillanueva
    Jdvillanueva Mar 24, 2011
    If the fuse is intact you have to confirm if the voltage regulator circuitry is working. Check the B+ across the 160/200v electrolytic capacitor in the output of the chopper transformer. If there is no B+ in this test point the voltage regulator section was faulty. This is mostly caused by defective Voltage regulator IC (STR series) and some of the fusible resistor.
    If the B+ is present across the 160/200V electrolytic cap, the fault is in the horizontal circuitry which is the common defective parts is the H-out transistor and its fusible resistor.
    Also, bad solder joints (crack/dry/cold solder) is going to consider most especially in the B+ line, regulator section, and in the horizontal section.
    If you don't have necessary tools and test instrument and can't troubleshoot the symptom, I would advice you to look for a qualified technician to isolate the problem.
    Note : this fault needs the skills of an expert if you are going to fix it yourself. Don't attempt to work in the power supply if you don't know safety precaution of handling it.
    Hope I helped you.
    Have a nice day!
    Thanks for using Fixya.
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
Palsonic tv wont work in television mode only works when watching movies on av mode
did you try source you need to get out of Av if you have it sounds like the tuner could be faulty
Apr 15, 2013 | Televison & Video
Sony model no KP51WS520 red light flashes 9 times but wont turn on
Check if the TV is in an AV mode.
Normally if I leave my TV in an AV mode with nothing plugged in, it starts flashing the red led..
If no luck return it
Mar 17, 2012 | Sony Televison & Video
XBox wont work on it? Its hooked to the Av in/output but it wont pick up on channel 3 or 4 I dont have a remote.
To work on channel 3 or 4, you need a RF modulator from AV component input. Otherwise just select the AV input on your TV to use it(Xbox).
Nov 20, 2010 | Symphonic ST420FF 20" TV
Bush LCD tv wont allow Wii to be tuned thru AV
Hi, the av lead with the three connectors at the end make sure you have them connected correctly -
Yellow - Video
White - Left Audio
Red - Right Audio
It's a simple mistake to make , but check it.
Let me know - Anthony
Feb 10, 2010 | Televison & Video
Jvc av-27d304 no remote - how can I do a full reset? CC wont
If you go into your menu you might be able to access the close caption mode selection(cc1,cc2,etc)try different caption modes that may not be in use in your area. that way even though the c.c is on it will not show up. Hope this will help Good luck
Dec 02, 2009 | JVC AV-27D304 27" TV
Cant see screen
Make sure the setting on the AV cable is set correctly. Either for HDTV or standard TV. Put your TV on the correct output channel for your connection.
Feb 01, 2009 | Microsoft Xbox 360 Console
My DVD Player wont play on my tv dont know which is right channel
If you are using a scart lead then you need to set your t.v. to AV or EXT. Plug your dvd in, turn it on and using your tv controls, press av or ext until it picks up your dvd. Sometimes you may only need to press the av/ext button once sometimes 2 or three times, depending how many outlets you have on your tv and which one you have you dvd plugged into.
hope this helps
Oct 28, 2008 | Televison & Video
JVC MODEL # AV-48WP74 48 IN. BIGSCREEN TV.
I had a problem with my TV colors not lining up. One day I turned it on and the green was out of wack. I checked this message board and replaced the STK chips, bad soldering and all led to me just giving up on that and buying a whole new Convergence Board ($185). I just plugged this in and though now my Green lines up okay, my red is out of whack. Is there something I am doing wrong? Can anyone help me? Did i miss a step? Frustrated......Bruce
Jul 29, 2007 | JVC AV-48WP74 48" Rear Projection...
Image doubled when using 480p
No it is only 480i with component cable support.
Jul 27, 2007 | JVC AV27WF36 TV
Televison & Video Logo
37 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
