The Daewoo DWD-WD3011WW washer can only finish the wash cycle , and washer will not operated , I purchased this product last year in sept, I have no idea what is going on. It is still under warranty
ginko
  • 19396 Answers
SOURCE: Daewoo Washer Error E8
Hi.
E8 is fault connection from CCU (Control board) to balancing sensor.
When you get E8, this is often because of a faulty control board.
Try first disconnecting power for a couple of minutes, to reset the appliance.
If you still get E8, then you need to call a technician. Testing is done jumping the two wires to the sensor to bypass the sensor, then replacing either sensor or control board.
If you want to arrange a repair, then you can call the phone number listed on the machine owners manual.
Regards.
Posted on Nov 08, 2009
SOURCE: error codes
if this is a fridgidaire washer, I guess it's a clogged coin catcher. You have remove the front access panel and clean it out. I am working on that now.
Posted on Dec 01, 2007
SOURCE: Daewoo washer - LE error message
replace the lock switch
Posted on Dec 27, 2009
  • 3 Answers
SOURCE: E8 code when washer fills on front loader daewoo
E3 CODE WHAT MEANS
Posted on Apr 09, 2010
blueextc3221
  • 15935 Answers
SOURCE: WASHING MACHINE NOT DRAINING
It appears your pump has failed or the inlet scree is plugged in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
Where is the reset button on DWD-G1281B?
There is no reset button, unplug the machine for 3 minutes to reset it.
Oct 13, 2016 | Daewoo Washing Machines
I have a daewoo washing machine dwd-g20dl showing error code LE
LE Washing machine door opening error
The washing machine or washer dryer door has been detected as open or unlocked.
·Close the door!
·Check the door lock switch
·Check the door latch
·Check PCB
Jul 09, 2014 | Daewoo Washing Machines
My Daewoo does not want to spin, any suggestions?
first does all of the water pump out when wash cycle is done? if not then check your drain lines and see if pump is coming on. if it is not then it wont let the washer spin,
Jun 03, 2014 | Daewoo Washing Machines
I have a daewoo washing machine model DWD-F1011
I believe the EO code means the pump is blocked, and you will have to clear the pump for it to work again.
Oct 12, 2013 | Daewoo Washing Machines
How to clear impellor
Top unscrews, impellor lifts off. Any tangled items can be pulled clear
May 19, 2012 | Daewoo DWD-WD3011WW 4.0 cu. ft. Capacity...
WASHER DOOR STUCK
Not all that uncommon on some front loaders. Yes, it is trying to lock and unlock. You can try two different things that might work. 1) Unplug the unit and let it set for 5 minutes and see if it then unlocks itself. Some units have a bi-metal timing that can take from 2-4 min. to release after the spin stops. 2) Wake up unit by pressing start or any button that starts the lock clicking. Have your hands on the door with some gentle pressure because if it unlocks you can pull the door open. Sometimes these things get mixed up and lock, unlock, and lock again. Once you get it open it usually clears up and does not happen very often.
May 17, 2012 | Daewoo DWD-WD3011WW 4.0 cu. ft. Capacity...
Daewoo DWD-F1011 PFE error code
I hd zs problem before,no problems in z water outlet,z pump
Nov 16, 2009 | Daewoo Washing Machines
Washing Machines Logo
110 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
