Question about Casio FX-9750GPlus Calculator
How do you add matrices such as a (2x2) (2x3) on a casio fx-9750g
  • Casio Master
  • 8,073 Answers
Here is enough to get you started and a little more.
Read the post ant consult your calculator manual. The screen captures below may not look exactly as your calculator but the steps are identical.
A. Define a matrix (Create it)
  1. Turn calculator ON.
  2. Press Menu,select the MAT icon and press [EXE]
  3. You see a list of possible matrix labels (A, B, C,D,E,F)
  4. All that have not been created have a "none" to their right
  5. Highlight a matrix name and press the right arrow. Where there was "none" , you have a template 0x0.
  6. That is where you specify the dimensions (mxn). example. 2x2
  7. Enter the first dimension and press [EXE]
  8. Enter the 2nd dimension and press [EXE]
  9. A matrix template opens where you enter the coefficients left to right and up down.
  10. After each coefficient press [EXE]. Cursor moves to the next coefficient, etc.
Press [SHIFT][QUIT] to return to the list of matrices to create new ones
B Operations on matrices
Once you have one matrix, you can do operations on it: Calculate the determinant (if matrix is square), calculate its inverse, transpose, augment it, fill it, etc..
  1. These operations are accessed as follows.
  2. Quit the matrix editor by pressing [Menu] and selecting the [Run] application.
  3. Press [OPTN][F2:MAT]
  4. You have the menus Mat,M(atrix)->L(ist), Det(erminant), Trn (transpose), Aug(ment) ->, Iden(tity),Dim(ension) Fill
Example : calculate the determinant of a matrix A (already defined).
  1. You press the [OPTN][F2:MAT] key sequence (just above)
  2. Press [F3:Det]; the command det is displayed on screen.
  3. Press [F1:Mat] the identifier Mat is displayed.
  4. Press [ALPHA] A; screen display det Mat A.
  5. Press [EXE] to get the value of the determinant.
C. Square of Matrix A
[OPTN][F2:MAT] (MAT) [Alpha] A ^2 [EXE]
D. Product of two compatible matrices MatAXMatB
[OPTN][F2:MAT] (MAT) [Alpha] A [*] (MAT) [ALPHA] B [EXE]
Part E Invert a (square, non singular) matrix that was already defined.
Press [OPTN] [F2:Mat] to open a screen similar to the one in capture above
Press [F1:Mat] to have identifier Mat displayed.
Enter the name of the matrix by pressing [ALPHA] A, for example.
Press [SHIFT] [ ) ] activate the (x^-1) key.
This is what you might see (with parentheses and without).
Press [EXE] button to calculate the inverse.
Posted on Apr 07, 2011
Calculate the inverse of a 4X4 matrix on fx-570ms
The Casio FX-570MS does not handle matrices. So you cannot create matrices, let alone invert them. Sorry.
The Casio FX115 ES handles matrices for up to 3X3 dimension. Create the matrix.Have its name displayed on the command line and press the [x^-1] (reciprocal ) key.
Apr 16, 2014 | Casio FX-115ES Scientific Calculator
How can i calculate inverse of 3*3 matrix using casio fx-570MS
The casio FX-570MS does not handle matrices. So you cannot create matrices, let alone invert them. Sorry.
Feb 12, 2011 | Casio FX570MS Scientific Calculator
How do i multiply to 4x4 matrices using fx-991 es ?
The enclosed screen capture shows all the possible dimensions for matrices on the Casio FX-991ES. As you can see the maximum dimension of any matrix is 3. You can only create matrices with dimensions less than or equal to 3.
Dec 01, 2010 | Casio FX-115ES Scientific Calculator
How to solve 7*3 matrices on casio scientific calculator
The enclosed screen capture shows all the possible dimensions for matrices on the Casio FX-119ES/991ES. As you can see the maximum dimension of any matrix is 3. You can only create matrices with dimensions less than or equal to 3.
Nov 30, 2010 | Casio FX-115ES Scientific Calculator
On which calculator can i solve 6*6 matrix
If you want to manipulate 6x6 matrices, you can use one of the CASIO Graphing calculators, such as theCFX-9850GPlus, or the FX-9750G plus.
Graphing calculators from other manufacturers can also handle such matrices. The FX-115ES can handle matrices with dimensions up to 3x3.
Nov 25, 2010 | Casio FX-115ES Scientific Calculator
Can this calculator do present and future value?
No, it does not. You will need a graphing calculator such as the Casio FX-9750G Plus or the newer version FX-9750 GII.
Sep 19, 2010 | Casio FX-300MS Calculator
I have a Casio fx-115ES; I have followed the manual for creating and multiplying matrices. The matrices have been simple, 2x2 for each, but it returns with "Dimension Error". Any suggestions? Thank you for...
Calculator should be in [MATRIX] MODE
Try the matrices 2X2 matrices matA [1,2,3,4] matB [5,6,7,8], Add them, subtract them, multiply them, take the square of each. If that works for these matrices, then it must be your data. Be careful with negative numbers. To enter those, you must use the change sign (-).
There is also the possibility that the instructions were misread.
Dec 14, 2009 | Casio FX-115ES Scientific Calculator
How to calculate calculus problem by a scientific calculator fx-991ms
If by calculus problem you mean derivatives of functions, integrals, extrema and such things, I am sorry to inform you that neither the Casio FX-300MS, nor the FX-991MS can handle them. The newer Casio calculator FX-991ES is capable of performing numerical differentiations and integrations. There also graphing calculators by Casio FX-9750G, FX-9860G as well as by Texas Instruments (TI 83 PLUS/TI84PLUS) that are reasonably performant in that area.
Hope it helps.
Oct 19, 2009 | Casio FX-300MS Calculator
I NEED TO USED MY CASIO FX-9750G PLUS
Turn calculator ON. You should see several icons. Use the arrows to highlight the RUN icon. Press [EXE], the screen clears and you are left with a blinking cursor. Now you are ready to start using the basic functions (add, subtract, multiply, etc.). But if you want to do more and pay tribute to the huge capabilities of your calculator, you should take a look at the manual.
Here is the link to all chapters..
http://support.casio.com/manualfile.php?rgn=1&cid=004002005
Hope it helps.
Apr 04, 2009 | Casio FX-9750GPlus Calculator
I need to know how to get to reduced row echelon form
i tried to graph a simple function but it wont show the lines it will only show the graph
Mar 17, 2009 | Casio FX-9750GPlus Calculator
Casio FX-9750GPlus Calculator Logo
196 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
