Question about Whirlpool Microwave Ovens
My microwave doesn't have any power. Won't turn on and doesn't show the time. I checked the power source and it is good. Is there a fuse internal or is it broken?
    Champion:
  • 299 Answers
They have a fuse under front panel , if it blows thats it have to get a new one. happens alot and people don't know they have a fuse. couple of screws and u there.
Posted on Mar 23, 2011
Does this unit itself have fuses inside it? If so, how do I access them.
Shelia, A lot of microwaves do have internal fuses, Links below will show how to change them.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Fix Microwave Oven Simple Fuse Replacement
Microwave Won Work GE Microwave Thermal Fuse Replacement part WB27X1127
Microwave Line Fuse Replacement Whirlpool Microwave Repair Part W10422951
Mar 21, 2016 | Microwave Ovens
GE Microwave JVM1540LM2CS Doesn't Heat
The turntable and the magnetron are two separate items and one should not impact the other. Since the other items are working it is doubtful that the fuse is bad. Also you need to know that the proper way to work on a microwave requires the use of special equipment to check for microwave leakage, it is not recommended to service them yourself.
Jan 22, 2018 | Microwave Ovens
Replaced 20amp fuse that was blown. new fuse did not blow, but oven is still dead.
see this causes and fix it. God bless you
If your microwave oven doesn't seem to work at all, check these: Fuses Door switch Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it. Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work
Sep 22, 2012 | Cuisinart CMW-100 Microwave Oven
I have an over the range DAEWOO MT1510W Microwave i think the fuse blowed my manual doesn't show where it located at
The fuse probably is internal. It may be necessary to remove your OTR microwave to get access inside.
Jan 13, 2012 | Daewoo Microwave Ovens
Microwave won't turn on
Hello, welcome to Fixya!
The unit not powering on is an indication that it has a power fault.
First, remove the microwave's power cord from the wall, wait for about 30mins, then plug it back in. It may cool by then and might power on. If it doesn't power on, plug it into another outlet, to make sure there electricity entering into the unit.
If plugging into another power outlet doesn't power it on then the unit is most likely having a power problem.
When electric current comes from the power outlet into the microwave, it goes straight into the power supply board which then circulates the current into the unit. So if the microwave doesn't power on, the first thing is to make sure there is power entering into the machine.
So check the power cord, if it is a 3-pin plug, it must have a fuse in it. check the fuse if it is not blown. if fuse is intact, then power supply board should be checked.
If any machine or electronics device doesn't power on, it means its having a power problem. It might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This microwave must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the microwave turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter and continuity tester in order to read the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store within our vicinity.You might also find visible bad component without testing with a meter. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.
Jan 04, 2012 | Magic Chef MCD1611 Microwave Oven
I have a built-in AEG Microwave code MC166(0E?) My son unfortunately used the microwave as a timer so it was on for 30mins without anything in it. It now won't turn "on"; no light/clock...
What fuse did you change? The fuse on the wiring that leads to the microwave needs to be intact, then the fuse in the Microwave itself needs to be checked. Usually there is a plug where the microwave is plugged in, in the cabinet above the microwave, you can take another small appliance or a power tester to make sure power is available in the outlet where the microwave is plugged in. If the power is on at the outlet then you'll know that it is the microwave itself that has turned itself off for some reason. You can get manuals for these ovens at this website
May 11, 2011 | Microwave Ovens
Oven just went dead, no lights, no power etc. checked power source and everything works fine. Sharp Model R-9H66. looking for repair in spokane , WA..can you help?
Possibly the internal fuse. Unplug unit, remove all case screws on the back of the micro. Slide the case toward the back and remove. Look for a glass tube type fuse, simular to automotive fuses of the past. It should be located near the controls. If bad, the internal wire will be broken or burned, I have been able to find replacements at Radio Shack. Take the old one with you. If the fuse is good, I'm sorry, it's beyond my microwave knowledge level.
Mar 03, 2010 | Microwave Ovens
Microwave doesnt power up, suddenly stopped working, can it be the fuse? ow do u check if the fuse is OK?
If there is no power at all then it could be the internal power fuse has blown, there could also be other parts faulty also. I would not recommend you to check this if you are not electricallly qualified as a microwave is a very dangerous piece of equipment to tamper with, even if there is no power to it. It would be best to call a service engineer to check it over for you.
Sep 23, 2009 | Oster 0.7 Cu. Ft. Compact Microwave
My sharp carousel II microwave doesn't seem to have power. I checked the power source and that seems fine. Is there an internal fuse?
Is it dead, meaning no display, no light when you open the door and no beeps when you press a pad on the keypad?
We have the relevant service / repair manuals for this model and have uploaded it to our site here and here to help you.
They will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
Most computers will open these documents automatically, but you may need the free Adobe Reader
I would suspect the 20A ceramic line fuse or the magnetron temperature fuse.
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
20A ceramic fuses are available at local appliance part stores or places like Wal-Mart and Lowe's.
Jun 03, 2009 | Sharp R-1870 Convection/Microwave Oven
Frigidere PLMV169
the internal fuse has blown, if your capable undo the screws on the casing and the check all the fuses
Jan 31, 2009 | Frigidaire PLMV169DC Microwave Oven
Microwave Ovens Logo
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
