Question about Biostar M7VIG-400 (M7VIG 400-COMBO4) Motherboard
My M7VIG REV. 7.1 on Sempron +2200 processor with 512mb DDR400 RAM will not install Windows XP... what is wrong? Please help....
    President:
  • 1,623 Answers
Either the hard drive is corrupt or the installation disk is
Posted on Mar 23, 2011
  • Martin Murray Mar 23, 2011
    Whenever i have encountered a problem like this , i have copied the full contents of the install cd to a folder on the hard drive that i created called winxp. Then booted from a floppy drive with smartdrv on it(important to use otherwise it will take a very very long time to copy files during the install process) Once booted from the floppy type c: then enter then type cd c:\winxp\i386 then type winnt.exe and press enter and setup will start, if you receive errors during install using this method then your hard drive OR the ram chips are to be main suspects
Installing two ram( ddr400 512mb and pc400 512mb )
If you are referring to computer RAM always put the largest ram module closest the CPU central processing unit
try to keep the same brand and type of ram the same ie: ddr ddr3.......
you will be able to read the ram type on the ram already inside
make sure you secure the ram modules by pressing the levers down firmly at both ends of of there sockets
make sure your computer is turned of before you attempt this
be sure to wear an earth strap before touching anything inside your computer
the ram modules sockets are located near your cpu
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
hope this helps you
Mar 21, 2012 | Computers & Internet
Would it be compatible to upgrade to windows 7 from my xp Home Edition
Hi,The best way to find out if your system can run windows 7 is to install this tool ( http://www.microsoft.com/download/en/details.aspx?id=20 ) its called Windows7UpgradeAdvisorSetup.exe Just click the download tab. Run the program and when its completed it will let you know if you can upgrade or not.hope this is helpful.
Feb 18, 2012 | Microsoft Windows XP Home Edition SP3 for...
Hi! I recently bought a MSI MS-6741 Motherboard and set it up with a AMD Sempron 3100+(754) and 1GB of DDR400 RAM (Kingston KVR ,CAS 3.0) and Installed Vista Ultimate on the 120GB P-ATA IDE drive attached...
The board does support up to 2GB DDR400 RAM (for more info on the board try here).
You might also find MSI's support site helpful (here is link to your specific board that has up to date BIOS and drivers).
As for why your system only sees 512MB of RAM, I am not entirely sure, you could try running 'dxdiag' (just type dxdiag into the 'run' utility), which should give you a more accurate reading of how much RAM you have available. Otherwise, certainly try the BIOS update. If you are still seeing only 512MB afterwards, I would certainly be questioning the reliability the board (if the RAM has tested fine on other systems).
Dec 02, 2009 | Computers & Internet
My PC is not installing XP service pack 2
You'll need to upgrade your RAM, minimum requirements for windows xp is 512MB.
for the best price on ram go to http://www.pricewatch.com
i would recommend at least going to 1 or more gig.
Mark
Mar 27, 2009 | Intel Celeron 2.4Ghz Socket 478 CPU (...
Maldonado223
best processor
AMD Athlon, Athlon XP, Duron, and Sempron processors
200 / 266 / 333MHz front side bus
for further information visit the link
http://www.biostar-usa.com/mbdetails.asp?model=M7VIG+400
Jun 26, 2008 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
I Can't Install Windows XP Operating System on my AMD Sempron Computer
cheak ram clean disk ? try one ram do partion on hard drive del it then make new one then slow formatt then install ok and update call it in
Jan 18, 2008 | AMD Sempron 2400+, 1.667 GHz (sda2400box)...
Nero 7 wont work on vista
What error comes up?
Nero 7 is not made for vista, however I got it to work..
General System Requirements
  • DVD-ROM drive for the installation
  • Windows® 98/98SE/ME/2000 (Service Pack 4 or higher), Windows® XP, Windows® Server™ 2003, Windows® Media Center Edition 2005,
  • Windows® Internet Explorer® 5.5 or higher
  • To install Nero 7 you must have administrative rights for all operating systems higher than Windows® 2000.
Processor and Installed Memory
  • For writing audio and data discs: 800 MHz Intel® Pentium® III processor, AMD™ Sempron™ 2200+ or equivalent, 128 MB RAM
  • For TV recording, DVD and video authoring: 1.2 GHz Intel® Pentium® III processor or AMD™ Sempron™ 2200+, 128 MB RAM
  • For capturing and burning in real time: 1.6 GHz Intel® Pentium® 4 processor or AMD™ Sempron™ 2600+, 128 MB RAM
Hard Drive Space
  • 1 GB hard drive space for standard installation of all components
  • Up to 9 GB free hard drive space for DVD images and temporary files
Display Settings
  • Microsoft® DirectX® 9.0 or higher • Graphics card with at least 8 MB video memory and minimum resolution of 800 x 600 pixels and 16-bit color settings. However, 24-bit or 32-bit are recommended.
Optical Device
  • CD and/or DVD/DVD-RAM recorder
Sound Devices and Speakers
  • 16-bit Windows® compatible sound devices and speakers • Installation of the latest WHQL (Microsoft® Windows® Hardware Quality Labs) certified device driver recommended
Nero 8 was
Nov 29, 2007 | Microsoft Windows Vista Ultimate Edition
Biostar M7VIG-400 (M7VIG 400-COMBO4) Motherboard Logo
Top Biostar Computers & Internet Experts
Jayburt
David
David
Matthew Spark
Matthew Spark
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
