Question about Ovens
Digital Display show F1 and is beeping - Ovens
    Sergeant:
    Champion:
  • 202 Answers
F1 means you need a new clock (main control board)
Posted on Mar 23, 2011
Have a Frigidaire FEF353bfwc. Getting error message F1 and start button lights up and beeps constantly. What to do? Can it be fixed? and what would you guess is approximate cost?
Hello there and thank you for choosing fixya
The dreaded F1 error code can be difficult to diagnose but here is the best thing to do
this is from the manufacture of the oven.
F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad Here is a simple test that you can do to determine whether the clock or the touchpad are defective when the display reads F1:
- Disconnect power to the range.
- Gain access to the back of the ERC (electronic range control, or "clock").
- Unplug the touch pad ribbon connector from the ERC. This will be a flat wire about 1 ½" to 2" wide.
- Make sure everything is clear and will not short out when power is turned back on. Replace any covers removed to gain access to the ERC.
- Turn the power back on to the range.
- Watch for the F-1 and listen for the beep.
- If you get the F-1 and beep, replace the ERC.
- If after approximately 60 Minutes you do not get the F-1 fault, replace the touch pad.
NOTE: Some models incorporate the touch pad and the clock control as one part so F1 = bad clock control.
Warning: If you do not feel comfortable doing this test or making this repair please contact a qualified appliance repair technician.
Aug 05, 2011 | Ovens
I had the oven on 350 for 45 min. baking potatoes and then the oven beeped twice and F1 showed up on the screen where it had said 350 so I turned the oven off and the time then showed on the screen. ...
The manual says error code "F1" means a problem occurred in the circuitry and suggests pressing "CLEAR" to reset it. If the problem persists, contact a repair guy.
See page 19: http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316257104en.pdf
"This oven is equipped with a state of the art electronic oven control. Among its many features is a full time oven circuit diagnostics system. The control constantly monitors its internal circuitry as well as several crucial oven circuits to insure they are all operating correctly. If at any time one of these systems fails, the control will immediately stop operation, and beep continuously (flashing an error code of F1, F3 or F9 in the display window, if equipped). Electronic control has detected a fault condition. Press CLEAR to clear the display and stop the beeping. Reprogram oven. If fault recurs, record fault number, press CLEAR and contact an authorized servicer."
Mar 14, 2011 | Ovens
My oven has been beeping for the last couple of hours. My son pushed bake and put the temp up to 425. After it preheated, it started beeping and F1 is showing on the display. I have tried everything to...
you can first try to reset the curcuit breaker
flip on and off
if this does not help
usually an f1 error is your control board
what is your full model number from inside the oven?
Apr 22, 2010 | Kenmore 30172 / 30174 / 30179 Gas Single...
The stove just says F1 and beeps won't let me do
Hello with the limited information and no make or model I can only give a generic response to this one. Most manufacturers F1 code indicates a bad control board (EOC) and or a bad touch-pad. If you have any other questions please feel free to comment. Mike
Nov 03, 2009 | Ovens
F1 display and beeping
F1 Power to element relay energized during time of day display.
1. Wiring harness shorted.
2. Or change power relay board (PRB).
Note: for double ovens, change second oven board.
Jul 27, 2009 | Jenn-Air JJW8230D Electric Double Oven
Oven showing F1
kenmore digital stove is clicking when cooking in oven
Apr 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Getting error F1 on digital display
F1 Board failure Replace control board (also called ERC or clock).
Mar 20, 2009 | Ovens
Range developed problem while cleaning oven
Your electronic oven control is bad and must be replaced.
The clock.
Mar 15, 2009 | Ovens
Fault Code F1
Frigidaire oven fault code F1 means the electronic clock control is bad and should be replaced. That is the electronic control board that shows your clock display and is also called clock or eoc, depending on your model.
Mar 25, 2008 | Frigidaire (FEB30S7D) Oven
Kenmore, F1
I really need to know the make and model but most F1 are a bad control board.. F1 Analog to Digital Failure Disconnect from power for 30 seconds - if display reappears - replace control board
Aug 27, 2007 | Ovens
Ovens Logo
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
