Hi experts. i was passing my f&p washing machine thismorning and heard a dripping sound and found the bowl had about 5mm of water in it?? does this mean i have a filling valve that is failing ? and are that easly replaced by the home handy man?
  • 96 Answers
Yes u need a new mixing valve. it will eventually flood your laundry room if you don't shut the valves off
Posted on Mar 24, 2011
My f&p mw511 washing machine is leaking water out of the blue nozzle inside the machine into the drum everything else is working fine please help I've tried pulling it apart still drips need help!
replace the water inlet solenoid unit as there is a hole in the diaphragm that is allowing tap water to pass through and into the bowl
simple solution is to turn the tap off at the wall after use until the faulty item is replaced
Feb 17, 2016 | Washing Machines
The water wont drain out of my hoover 750 la washing machine
Check all hoses for blockages, check pump for blockage. Make sure drip dry or sud save switch / push button is off. Check for clothing item caught between inner & outer bowl using torch.
Apr 10, 2014 | Kenmore 24032\24036 Top Load Washer
I have an Aquasmart W80T65C. After each load there is a small amount of water under the machine. The water is dripping off a black rubber elbow at right rear of the machine.
Hi - if you could try this - fill the machine with water and leave it overnite to see if there is any water on the floor.
Yes - then just tilt the machine on its back & find the leak.
No - then there is a small hole on the drain hose, this will be due to the movement of the bowl - rubs against something and over time springs a leak.
My washer has one on it now - just located the pin hole & wrapped duct tape around it - works fine for us.
Jun 22, 2011 | Fisher and Paykel Washing Machines
Slow drip near back of lid
Hi there.this may be water dripping from the injector tube where the water actually enters the bowl.It is normal to drip for a short while after the machine has just been used but if it is a constant drip then you probably have a faulty inlet valve.Try this,turn off one of the taps & see if dripping stops.if not,turn off tha other tap & see if it stops.this will tell you which of the valves are leaking.You could just turn the taps off after use,that would save having to replace it.Hope that helped you.if not then give more detail if possible please.cheers!
May 29, 2010 | Fisher and Paykel GWL11 Top Load Washer
Have Fisher & Paykel top loader. Error code
fault code 56 is a real code : bowl invalid check clutch in centre of bowl and pressure tube is not kinked,can also mean pressure tranducer on motor control board could be faulty, note check for obstruction between inner and outer bowl( missing a sock perhaps.?)
May 07, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Samsung Washer,less than year old. Not every load and not every item but periodically something will come out with stains not previously on the item.
This is common, if the machine does predominantly COLD washes.
Over a period of time, there is a build up of soap scum (washing powder/fabric softener etc) inside the machine, caused by using excess soap powder/detergent.
To recitfy this, fill the empty bowl (no clothes) with a solution of HOT water & CITRIC ACID (found in the baking isle of your grocery shop) on HI Water level. Set the machine to wash cycle, then drain.
Fill again with same solution, but leave solution inside the bowl overnight.
Drain next day, then follow with 1 single HOT wash (no clothes) on HI water level again.
The scum should be gone...
The hot flush should be done at least every 6 months, but this can be dramatically reduced if you use less soap powder (Samsung machines do not require as much powder, as do other machines)
"If this has helped you, please rate this solution"
Nov 29, 2009 | Samsung Washing Machines
I have a Samsung SW62ASP top load washing machine. I keep getting chunks of black flaky stuff turning up through my wash. I always empty the in bowl filter, is there another filter?
This is a common problem on washing machines, if you predominantly do cold washes.
Over a period of time, a washing machine will accumulate a buildup of Soap Scum (excess soap & softener residue) which can stick to the inside of the drum.
This black coloured soap scum occasionally breaks away from the drum, and attaches to the clothing fabric during the wash cycle.
You can rectify this, by doing the following:
Firstly, purchase a packet of CITRIC ACID from your local grocery store (usually found in the baking isle).
Do the following procedure before going to bed:
1) Do a HOT WASH without clothes (Hi water level, with HOT water) - allow machine to fill with hot water, then add the CITRIC ACID to the water. Allow the machine to complete a FULL wash cycle (i.e. allow machine to agitate for 30 mins or so, then drain).
2) Fill the machine again with the HOT water / CITRIC ACID solution, but this time allow it to sit in the bowl overnight (no cycle).
3) Next morning, set machine to spin & drain (i.e. to empty the solution)
4) Set machine to fill with FRESH HOT WATER ONLY (no citric acid), then set machine to spin & drain. This will flush all remaining residue left in the bowl.
Note: Soap scum residue is caused by using excess detergent/fabric softener. Hot Water flushing should be done every 6 months.
Contrary to what the detergent manufacturers state, you should follow Samsung's instructions by using HALF the recommended detergent.
Samsung machines prefer LOW SUDS, and you may find by reducing the amount of detergent used, you may even eliminate the buildup of soap scum.
"If this has helped resolve your issue, please rate this solution
Aug 05, 2009 | Samsung SW62ASP Top Load Washer
Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Apr 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
LG Top Loader WF-T8108TP - NOT SPINNING
unplug the machine take the back off and look for a small pipe 5mm going upwards, take it off and blow gently into it you should hear a click and one when you let the air out if so then the place you took the pipe from is blocked clean out the pipe with a pipe cleaner or metal rod replace the 5mm pipe put the back on retry the machine eric
Jan 11, 2018 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Hoover automatic 830 washing machine - leaking from under bowl
The water seal has been damaged. Will need to be replaced by a qualified technician.
Nov 03, 2007 | Washing Machines
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
