Question about Foxconn 865G7MF-SH Motherboard
Sata drives how to make two bootable sata drives master and slave
I have set drive 1 into bios as first boot but it boots from drive 2 only both drives os are good (xp)
Posted on Aug 08, 2008
  • 1,027 Answers
Sata drives do not have a Master or Slave setting, as they connect only one drive per interface. The order of booting is determined in the bios of the computer, by their position in the drive list, with the first being the default. After the POST test, most have a brief selection for the boot manager, then it will proceed to the default disk or the first one that has a bootable section.
Posted on Aug 03, 2008
2 Suggested Answers
  • 1314 Answers
SOURCE: Where are the sata drives???
Once you've connected your drive, have you ran disk management to initialize it and format it? Windows won't be able to see it unless it is initialized and then formatted.
Click start, run.
Type c:\windows\system32\diskmgmt.msc
Posted on Jun 15, 2009
Cant find the slave drive on boot
Master/Slave configuration I am assuming you have IDE hard drive and not SATA. SATA is a small cable IDE is a wide 40 wire flat cable. You must install the jumper on both drives as master and slave. On the old WD HDD master has jumpers between 5 and 6 and slave jumper between 3 and 4. Default is jumper between 1 and 2 which is cable select which you use for a single drive.
Nov 09, 2013 | Dell Inspiron 531s Desktop Computer
Jumper configeration for harddrive
for ide usually located on the top of the hard drive is the diagram
sata drives will automatically designate master slave
single or master :::::
master with slave ::'::
slave :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
hope it helps
Aug 25, 2012 | Computers & Internet
I need some help pleas my harddisc keeps blinkin whats wrong its not workin
There are several types of damage to your hard drive
When the computer is turned on, audible sounds, from hard drive. See the video and
This means, your hard drive optical is damage (heavy damage on the hard drive)
2. Hard drive not detect.
When the computer is turned on, a message appears "Disk boot failure, insert system disk ...." - see the abdulkarimap.jpg
Solution :
Hard drive ATA
move the jumper from Master to Slave, or the other.
Move the serial cable, from ATA1 to ATA2. Or replace the serial cable
Hard drive SATA
Use a jumper, on the hard drive SATA
Move the SATA cable, from SATA1 to SATA2. Or replace the SATA cable
3. Hard drive bad sector. To fix hard drive bad sector,
use the software HDD Regenerator Bootable CD. Create, HDD Regenerator Bootable CD, restart the computer and boot from Cd Room. To repair hard drive bad sector, see the video .
Sep 23, 2011 | Computers & Internet
Master/slave settings on sp411c samsung drive please SATA
The SATA hard drive did not have master/slave setting at the hard drive
if you want to make the hard drive as master just connect your hard drive to SATA 1 slot at Motherboard
and id you want to make the hard drive as slave just connect your hard drive to SATA 2 slot at *********** board
i hope this helpful
thank you for using fixya
Feb 09, 2011 | Samsung Computers & Internet
I have a seagate barracuda 7200 7 40GB, with 2 partitions: 1-(c:/)WindowsXP, 2-(d:/)for save my personal files.At PC startup, the message that appears is missing OS. BIOS detected HDD, but Windows CD no,...
you can take backup of D drive om other computer .
Conect your harddrive to that other computers CPU but make sure that your hardddisk is slave which has issue you can set slave your hdd with jumper read on harddisk.
then connect it to cpu with SATA or IDE .
Then winxp find that all partition then take backup.
AND IFyou haven't other computer you need winxp bootable disk.
Boot your computer with winxp disk then follow the procedurer then you see on screen
your old winxp for repair then when it ask for "r"
Presss "R"
thats it.
Thwen it repair your winxp then you can use easily.
Aug 22, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
Slave jumper setting
SATA drives don't have jumper settings.
You can set master/slave in BIOS.
Mar 29, 2009 | Seagate 500GB Maxtor Diamondmax21 SATA2...
Master slave jumper settings on 250gb Maxline Plus II SATA
There are no master/slave settings on SATA drives because each drive has its own cable. The drive order is determined by what SATA port they are plugged into, or by the BIOS configuration.
Mar 16, 2009 | Maxtor MaxLine Plus II 7Y250MO 250 GB SATA...
Sata HDD set in primary master in Bios
Try considering these:
1. DOS disk doesn't recognize SATA, that's the truth
2. You're going to have a problem if you install OS in your computer (solution: do not select SATA in HDD type but rather IDE)
3. For your SATA HDD to become primary (boot first) try to select your SATA HDD as devic first to boot..
Jan 04, 2009 | Maxtor Hard Drive
My motherboard can't read any bootable dvd
you have to check
1) new DVD master/slave setting, it should be set to slave cause your old one set master
2) go bios setting check IDE device should display the DVD device at slave position.
3) start windows it should be there
Dec 15, 2008 | AOpen Computers & Internet
Sata 2 hdd how to set to master 400gb
sata devices do not work like IDE, they do not have master/slave. If you want to set it to bootable, you have to go through the bios. On most computers, press DEL while it is booting, then go to "standard cmos features", search around a bit until you find where to set the bootable device list, and set the 400gb to the first.
Jul 16, 2008 | Hitachi Computers & Internet
Foxconn 865G7MF-SH Motherboard Logo
65 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
