Question about Jensen MCC-8320 Cassette Player
Blows fuse as soon as you put fuze in - Jensen MCC-8320 Cassette Player
  • 625 Answers
Check the connections at the stereo: apparently the 12 volt battery and/or the switch 12 volt accessory wire at the stereo is making contact with ground.
Posted on Mar 24, 2011
Hi. Could you tell me which fuse controls the electric aerial. Nissan terrano ll 1996 import.
typically the fuze is under the hood. It is a inline fuze attached to the antenna motor.. I may be hidden under the fender, so find the motor for the antenna and follow the wires till you come upon the fuze holder. It comes apart with a twist, be sure to replace with the same value fuze. 2 amp usually. It has been my experience that these fuzes blow because of a short in the wiring or a short in the motor itself. so if your replacement fuze blows right after you put it in, you have more than a fuze problem.
Mar 03, 2015 | Nissan Cars & Trucks
2004 Pontiac Montana a/c fuse blows as soon as u put it in . Blows hot air only
If the fuse blows as soon as you turn the A/C on, the compressor clutch has failed (shorted). Simple repair.
If the fuse blows as soon as you put the fuse in without the A/C on, you have a physical short in your wiring.
May 16, 2014 | Cars & Trucks
Blowing A/C fuzes
Well the short answer is too much current flowing thru the circuit. It would depend on what the fuse controls as to where the problem is. Could be a component or a wiring problem, including a short to ground.
Jul 03, 2013 | 2006 Chevrolet Impala
40 hp mercury
Hi Greg,
You Have A Short!
If You Put A New Fuze Does It Blow When You Turn The Key On, Or
As You Try To Start Or When You Operate The Trim Switch.
Try To Acertain What You Do When It Actually Blows The Fuze
Let Me Know
Cheers
Gordon
May 04, 2013 | Light Outboard Motor Boat Bass Fishing...
Blows a fuze when turned on--have tried sevreral times with new fuzes..hasnt been used in months, only used 3-4 times..
every time you put a new fuse you just do more damage to your amp, and by now probably the whole power module is probably fried.
Jun 12, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
I think the flasher relay is out on my 1991 toyota 4x4 pickup. It was making a lot of noise before it stopped working anytime the blinkers weren't on. Then after a day or so it just stopped working and now...
The flasher relay on a 91 Toyota pickup should be on the back of the fuse box. You access this by removing the dash panel that is under the steering wheel and then removing the screw that holds the fuse box in place. Turn the fuse box over and you will find the flasher in the center. Check this out
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=video&cd=5&cad=rja&uact=8&ved=0ahUKEwjAsbXrgcnWAhVX-GMKHU_8BCcQtwIIOTAE&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DcHl81d-SW8w&usg=AFQjCNHZFEI8hwXRPaUnYZJPuY_R8xuUPg
Sep 28, 2017 | Cars & Trucks
The electrically operated windows do not work. The fuze is blown and I cannot replace them because as soon as I try to the fuze blows. Car is off at the times I tried. Also windows worked fine throughout...
If it blows instantly you have a dead short, And the only honest opinion anyone of us can give is trace it, From the switch to the box, and to the motors, Sorry and good luck
Jun 11, 2010 | 1991 Volkswagen Passat
Looking for stereo fuse
the stereo fuse is under the hood in fuse box and uses a five or ten amp fuse no fifteens will blow it right up
Nov 21, 2008 | 1992 Jeep Wrangler
Jensen MCC-8320 Cassette Player Logo
85 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
