Question about Toshiba Computers & Internet
My Toshiba NB200 doesn't want to boot. I already press f2 or f12 but it only said Please wait but it did not continue. I turned it on and off also but to no avail. What could be the problem?
    Scholar:
  • 115 Answers
There is a possible corrupted files on the system that is why your laptop won't boot up. You may try this first; Turn OFF the laptop, remove the power sources (ac adapter and battery). Without power sources, hold power button 10 secs. Put back the power sources, and power ON the laptop. If the laptop will still not boot, turn if OFF again and keep tapping F8 upon turning ON to enter safemode. In safemode do the system restore. You will find the system restore in start/all programs/accessories/system tools/system restore. Select the previous date that the laptop was working fine. If will not work, the last option is the recovery. You may access the recovery partition by hitting 0 upon turning ON. But this procedure will reinstall the factory settings, meaning, it's like starting from scratch again.
Posted on Mar 24, 2011
Bios setting probleme
you can not press the F12 or F2 Key at startup ....You need to hold the key down abd bios will open of boot order if F12 is pressed.
So hold the key down(F2,F12) then press the power key...keeping the F key pressed down.
Good Luck
Jun 19, 2013 | 10 10 Computer Network adapter Cable...
How did i boot my toshiba satlilit pro
Here is a solution for your problem.Please follow the below steps to boot your laptop.
1. First of all insert the CD from which you want to boot your laptop. 2. Shut down your system. 3. Press the power and then start it again and press the "C" key to boot from the CD.
If this method doesn't work, you can try pressing F2 or F12 at startup and selecting the CD drive from the list of options.
If neither method works, hold the "Esc" key while restarting the computer and press F1 when prompted to access the BIOS. From there, you can change the boot order so that the computer attempts to boot from the CD before any other devices.
This will surely help you out.
Thanks you. Have a good day.
Aug 10, 2011 | Toshiba Satellite A60 Notebook
How can i go to bios setup
Straight from the Dell website:
  1. Turn on (or restart) your computer.
  2. When "F2 = Setup, F12 = Boot Menu" appears in the upper-right corner of the screen, press .
If you wait too long and the operating system logo appears, continue to wait until you see the Microsoft Windows desktop. Then shut down your computer and try again.
I hope this answers your question!
Apr 15, 2011 | Dell Dimension 2400 PC Desktop
Hello, the problem with my mini toshiba nb200 is that when I on it, it shows the initial screen which says ; TOSHIBA Leading Innovation >>> Press [F2] for ...
If you are getting the Toshiba Select F2 or F12 screen the mother board has finished with POST.
Toshiba laptops are very good normally but don't boot up if there is a device in the USB slot or a CD/DVD in the drive.
If it still refuses to POST, remove the AC Adapter, remove the battery and remove the hard drive.
Power the unit up without the hard drive and it should complete POST and complain that there is no hard drive. If that doesn't work remove AC adapter, ensure battery is disconnected and remove hard drive and RAM. Try again. If it still doesn't work, you have a mother board fault and it needs a service centre. www.Toshiba.com will help you out.
If it does work at one of the options, when you have closed the laptop down, replace the RAM first and test, then the Hard Drive.
Hope this fixes your problem.
Feb 05, 2011 | Toshiba Satellite A205-S4617 Notebook
My Toshiba NB200-10G laptop will not turn on correctly it turns on and then it goes blank with a little White line flashing in the corner I tried taking the battery out but it doesn't work please help
sounds like you have broken your master boot record, if you are running vista or 7 just start the comp with the OS dvd in the drive (you may have to change the boot order in your BIOS or press f11 or f12 to enter your boot drive selector screen.) and select the repair option, if it is XP boot to the XP cd and enter into the repair consol and type CHKDSK at the prompt then enter, after check disk has run type FIXBOOT then enter to write a new boot sector then type FIXMBR then enter to write a new master boot record, type EXIT and press enter to reboot
Good luck.
Jan 22, 2011 | Toshiba Computers & Internet
When I turn notebook on it only powers to the screen that says f2 for set up or f12 for boot options, occasionally I can hold the f12 key while powering up notebook, release key when it comes to that...
try to reset the bios to factory defaults to do that keep tapping the f2 key as soon a you turn on the computer until you see the bios screen then using keyboard go to a tab which says boot then press f9 key press 'y' to confirm then your computer should boot properly everytime..
take a look at this picture just to show you how that screen looks if this doesn't work try doing system restore..to do system restore try this link..see the use system restore topic
Oct 02, 2010 | Toshiba NB205-N210 Netbook
We have a toshiba m105-s3004,when we boot it up, the toshiba logo comes on, and at the bottom of the screen it says f2 of f12, i press the f12 button then it just locks on saying please wait.
1. turn off laptop
2. take off battery.
3. wait 5-20 mins
4. turn back the battery inside laptop.
5. turn on wait until it open.
but if still not working and same problem then i suggest you to reformat your unit....
thanks,
Feb 19, 2009 | Toshiba Satellite M105-S3004 Notebook
Toshiba Satellite A135-S4427 Frozen
there is problem with the mother board try repairing at repair shop
Nov 29, 2008 | Toshiba Satellite A135-S4427 Notebook
Bios batt
if you leave it long enough does it boot ?
press F2 and go through the settings and check for something like "display boot menu" or similiar.
remember to save your settings upon exiting
Sep 20, 2008 | Toshiba Satellite M100 Notebook
Open Questions:
Cloud Backup For Small Business 'Dataalign We understand the difficulty of reaching a great quality tech support at time. We all have gone through the phase of struggle when we have to look for reliable tech support in affordable prices. Toshiba support is now available at just a click away or just a phone call away on toll free helpline number. Toshiba support by well-informed and erudite experts who have made it a mission of their lives to provide best tech support for their customers. Customers have shown over whelming response to Toshiba tech support as it a one and only needed platform for all tech issues faced by the customers ever. Toshiba support provided by TechFree has always gained appreciative remarks from customers. They have always been praised for their hard work and dedication over the years which has resulted them in gaining a lot of fame for their work. Toshiba customers face many type of issues like dealing with their slow performing Toshiba devices, treating issues faced in Gmail, yahoo or any other email supporting site, networking issues, software not working issues, issues with viruses, malwares and issues in printers, routers or other relatable peripheral devices. These issues and many more are professionally resolved without much delay. Tech support professionals of Toshiba support use their knowledge and experience of years and together with highly advanced technologies to resolve issues of their customers in the right way. They get highly acclaimed by their work and the way they treat their customers with respect and courtesy. They make sure to patiently listen to their customer's issues in order to be able to understand the issue in depth and provide right type of support for longer lasting effects. Tech support of Toshiba can be reached via the toll free helpline number +1 888 784-9316 and they assure to be assisted by expert tech support executives. These executives work 24/7 throughout the year. They also provide 30 days money back guarantee and free device check-up along with free online data backup. For any type of tech support or computer repair services at any time of the hour call on toll free helpline number +1 888 784-9316
Jul 05, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
782 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
