Question about KitchenAid KGSA906PSS Gas Kitchen Range
Oven does not heat up in a timely manner - KitchenAid KGSA906PSS Gas Kitchen Range
  • KitchenAid Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Aug 13, 2011
My electric oven heats to maximum when set on maximum but on other settings does n't heat up at all
When on Maximum a lot of electric ovens turn on both the broil and bake elements. When you turn on bake and it doesn't work then more than likely the bake element is bad. If you have a volt-ohm meter handy, unplug the oven from power. Remove the back panel. You should see the two wires connection to the bake element. No need to remove them at this time. Set your meter to ohms (horseshoe symbol) and place the meter probes as follows, one on the left and the other on the right metal part of the connectors for the element. The meter should read a fairly low resistance around 16 ohms if the element is good. If it is a high reading then the element is bad. As an example you can also check the broil element in the same manner and the resistance in ohms should be low, in the 16 ohm range. A new element can be ordered online by looking up the Make and model number for your oven. If you need one quicker, Home Depot and Lowes often carry "universal" elements. Disconnecting the connections and removing the two screws inside the oven that hold it in place will allow you to pull it out toward the front. Installation is the reverse of removal.
Dec 30, 2014 | Ovens
Neff 1031 2
The heating element(s) may have shorted.
Apr 13, 2017 | Ovens
Our Dacor ECS130SBK convection oven no longer heats, after using the broiler and leaving the door open.
The element is probably failed. Using an oven in this manner (turned on with the door open) is not good.
The element is replaceable, and will require some electrical tests to confirm the failure.
Dec 10, 2009 | Dacor ECS130 Epicure Electric Single Oven
Maytag Gas Range Model #MGR 5745ADA will not pre-heat in a timely manner. The oven also does not reach temperature as indicated by the display. Could the ignitor be faulty?
Firstly do not attempt to fix or change any part, as this is gas related and requires a gas technician. It sounds like you may have an issue with your ignitor and you aren't reaching the correct temperature. Although you may still feel heat, this is from the ignitor. But in order to ignite the gas it must glow a WHITE hot and not orange. If it is orange it is faulty and will need to be replaced. part number for the ignitor is 12400035. and can be accessed safetly by removing the lower oven panel inside the ovens cavity. If your ignitor is okay and you are still getting gas inside the oven it will most likely be your control board. part number for the board is 74003800. I would have a technician diagnose it if everything appears okay.
Thanks
Oct 14, 2009 | Ovens
A portion of the the heating element broke off
This does happen from time to time when the element goes bad. I've witnessed many of them blow open in this manner. This can also occur if something spills over in your oven and leaks directly on to the element. You will require a replacement heating element to restore your oven feature. The following link explains the steps required to replace an electric oven heating element:
http://www.fixya.com/support/r469407-replacing_bake_or_broil_element_in
This is a very simple repair that usually isn't that expensive if you wish to repair yourself. You can order a replacement on line from any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites offer great service with competitive pricing, so shop all of them for the best deal. You will need to use a more complete model number (usually located on a nameplate around the oven door opening, lower drawer opening, or back of the operator console) to get better results for your parts search. The model number you provided only returns partial results.
If you have questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: In some circumstances, the element failure can cause the Electronic Oven Control (EOC) board to fail. This is the control board on the operator console that controls all the oven features.
Sep 30, 2009 | GE Spectra JBP78 Electric Kitchen Range
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven elements just stopped working
If I understand your use correctly, you were using the oven to heat the space? Or for baking?
Regardless, it sounds as though the elements have failed. If you used the oven for heating the space (with the door open) the broiler element comes on during preheat of the oven to get the oven to temperature more quickly. The elements are NOT designed to heat a space, and will quickly burn out if used in this manner.
Jan 23, 2009 | Ovens
Whirlpool Double Oven GBD307
there are three possible issues, one is a faulty ground. the computer uses ground to determine zero in binary logic. It could also be a stuck key on the input board, or the main control board. Check your owners manual, some units come with an exceptional warranty on the electronics. This is a big one and it may be worth your time to call a tech in to check it out. electronics are expensive and you can not send them back if you diagnosis is wrong.
Sep 24, 2007 | Whirlpool RBS245PDS Electric Single Oven
Heating
Some Deep Fryers heat up faster than others, please see details below for pre-heating times: Non-Immersion Element (No element in the Oil): 25 to 30 Minutes Immersion Element (Element in the Oil): 7 to 10 Minutes Are you by any chance overloading the fryer? try smaller batches. Preheat the oven to 180 to 200 F. Heat the oil in the fryer to 280 or 290 F. In small batches appropriate to the size of the fryer (fries for a serving of 4 people may need to be divided into 2 or 3 groups), fry each batch for about 8 minutes at this temp. Remove to a holding bowl. They will look limp, nasty and oily. (This uses 1/4" square fries from baking pototoes cut with a standard mandoline.) When all the fries have been precooked, increase the oil temp to 375 F. Add the fries back to the oil in the same sized batches as before. It will take 3 to 5 minutes for them to crisp and brown. Drain, salt, and move to a cloth-lined bowl and hold in the 180 F. oven. Let the oil temp recover to 375 F. and cook the next batch in the same manner. Repeat, holding interim fries in the 180 oven, until all the fries are done. When all batches are done, toss to distribute salt and the new fries with old, and serve immediately. Properly done, all commercial french fries pale in comparison to these. However, I cannot guarantee that this method works with frozen commercial products. I always use fresh baking pototoes. That said, the frozen product should work to its optimal advantage when done in small batches with the first batches held in the warming oven as the other batches are done. If it still doesn't reach 300 F then by all means take it back to the shop and ask for a replacement. If you're out of warranty get an estimate for a repair. Good luck and bon apetite ;]
Jan 24, 2006 | Black & Decker DF200 FryMate Fryer
KitchenAid KGSA906PSS Gas Kitchen Range Logo
66 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
