Question about Samsung HT-AS720ST Theater System
Samsung Home Theater HT-AS720ST Crackling and Popping in one speaker with intermittent volume change in all speakers. 1st repiar for same problem done under warranty. Replaced main board. Happened again 15 months later. No longer under warranty Ordered the main board AH92-02697A to repair it. How do I prevent reoccurance? Since it is such a common failure on this model. Does Samsung have a fix or policy associated with it? Are there any alignment or set up issues associated with the main board installation? Thanks in advance for any help you can provide.
5 Suggested Answers
SOURCE: crackling from surrond sound
I have a SONY home theater4.gif system, HT-C800DP, there is a crackling sound when playing DVDs - it is almost as if the unit overheats. Is there any solution to this? Sometimes I cannot even finish a DVD as the noise gets very loud.
Thanks,
Cindy
Posted on Jan 05, 2008
  • 286 Answers
SOURCE: My Samsung HT-AS720ST (AV-R720) surround sound receiver started
The problem is caused by the PULSUS PS9829B digital audio processor. We ordered it in from a Samsung authorized service centre.
Problem is now solved. Unit works perfectly. If you have never tried working with surface-mount ICs I would skip it if I were you. This IC has over 100 pins on it. However the part is available from Samsung. Print this comment and take it to your locat service centre along with your receiver. They should be able to repair the board unless they are wussies and cannot do surface-mount work.
Posted on Oct 21, 2010
  • 286 Answers
SOURCE: The front right speaker channel on my Samsung
Normal 0
This is a common problem on this model. The fault is caused by the PULSUS PS9829B digital audio processor. We ordered it in from a Samsung authorized service centre.
SOURCE: Samsung HT AS720ST Surround system - Volume problems
I have the same problem. HDMI connection and the sound just stops. Very frustrating
Posted on Nov 07, 2010
The volume cannot exceed 10 almost no sound coming out of speakers
Make sure the wiring is making clean connections between the speakers and the unit.
Sep 13, 2013 | Samsung HT-AS720ST Theater System
We have a samsung AVR 720 receiver we only get sound on one channel and that goes out intermitantly.
Disconnect all wires to the receiver and speakers and connect them back again. The receiver should be on a surround or 5.1 mode
May 03, 2011 | Samsung HT-AS720ST Theater System
Have been trying to connect speakers to my samsung AV-R720 receiver but I am getting a terrible buzzing sound and only the center speaker is playing. I have lost the manual and would like to know about...
http://www.retrevo.com/support/Samsung-HT-AS720-Home-Theater-Systems-manual/id/6333ci454/t/2/
Page 10 discusses speaker connection.
Disconnect everything but the speakers and evaluate the buzz. It may be coming from external hardware or loosely connected analog cables.
Sometime juts rotating the ac plug on one device eliminates the ground loop buzz.
Feb 07, 2011 | Samsung HT-AS720ST Theater System
Static coming from the front right speaker. Sound now fades in and out, unit is only 2 years old.
I had this same issue about a year after I bought the product. Sent it back under warranty and about a year later, I have the exact same issue again. Never buying samsung receivers again.
Oct 11, 2010 | Samsung HT-AS720ST Theater System
Jun 17, 2010 | Samsung HT-AS720ST Theater System
The front right speaker channel on my Samsung HT-AS720ST Theater System has continuous static making a "snap, crackle, and pop" noise. I've checked the speaker and wire and have narrowed it down to the...
IF it is out of warranty, you can open it up and look for loose connectors on the boards. It may be a poor connection that is visible. Otherwise it may be a connection problem that is hidden/internal. Bad solder connection on the board/speaker tabs, etc.
Mar 30, 2010 | Samsung HT-AS720ST Theater System
My Samsung HT-AS720ST (AV-R720) surround sound receiver started making crackling noises in the front right speaker. I've changed the speaker and cable, but still the same results. Is there any hope for...
Dec 05, 2009 | Samsung HT-AS720ST Theater System
Static in speaker channel on my Samsung Surround Sound system
our started cracking and popping this morning. It seems from all the posts that it is always the right front speaker. With that kind of trend it can be traced back to mfg. Is there a recall, are they covering the cost?
Nov 11, 2009 | Samsung HT-AS720ST Theater System
System is samsung HT-TWZ415. all speakers work, not the sub
Check all of your connections, and make sure all cords are firmly connected.
Make sure if the subwoofer has a power switch, it is on, and if not, that it is likely to be faulty.
Jul 16, 2009 | Samsung HT-AS720ST Theater System
Samsung HT-AS720ST Theater System Logo
288 people viewed this question
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
