Question about LG Dare VX9700 Cell Phone
My charger input is halfway out of my phone. it could be pulled out easily. My phone is also not charging because of it. I just need to know if the input could be replaced, or fixed by the verizon store. One side of the input will stay in, but the otherside will just come out. Also when we first found out was when my phone wasnt charging, and then my parents found out that the charger was really wiggley/loose in the input. Could verizon fix it? and how much does it cost? Thankyou.
  • 437 Answers
Hi kelc 1212 Theverizon stores don't do repairs. Your phone isn't carried by verizon any longer . Now you can call lg's customer services and they can give you the number for a repair center. They also will give the ptice you may have to send them the phone you will be with out a phones for two weeks. You can go int the verizon store and get a certifiy preowned phone for 69.99-289.99 they come with a new one year warranty. Verizon is changing a lot of it's ploicies because of the iphone. so hope this helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
Posted on Mar 24, 2011
Older model phone charger
4 important points or facts to note with chargers are as follows:
1. Supply voltage ~AC/Voltage (input, say 110Vac, 220Vac)
2. Output voltage (VDC)
3. Output ampere rating (amps)
4. Jack type for connecting charger to your phone.
What this implies is that you have to get your old phone to a store where phone chargers are sold or can be purchased (because of the connector jack)
However, you need to know the specific OUTPUT charging voltage (indicated as DC) and current for your phone
Oct 04, 2017 | Cell Phones
My Nokia E71 won't turn on or charge up. What can I do?
please check ur charger's hole (phone or charger). and - may touching:) thats y ur phone switching off:)
Jul 17, 2011 | Cell Phones
My mini phone will not charge or switch on
First, the battery is drained, therefore any effort to turn it on will turn out abortive. Connect the charger to the phone and leave it for about 30 minutes to see if it will charge. If it does not charge then it means there is a problem.
The problem is most likely from either the charger, the battery or the phone. You need to diagnose each of them to know where the problem is from. To diagnose them you need to test them on other devices in order to know where the problem is from. First test the charger on another phone to know if it works. Then insert the battery into another phone and try to charge, remember the battery is drained and need some minutes to boost before indicating a charge, then finally, try another battery and charger to know if it will work.
Which ever does not work of the charger and battery need to be replaced, but for the phone, it is the connection port that need to be fixed if it does not work.
Thank you for using fixya
Caseytech
Jul 01, 2011 | Cell Phones
My 1 month old dualshock3 controller goes crazy and does the wrong action. Sometimes it works correctly only if i connect my usb charger halfway in, thats crazy...
You may have to download a system upgrade for your ps3, It should download automatically if your ps3 is on-line, failing this reset controller and fully charge before using, The "usb charger halfway in" i don't know how you would fix this, sorry.
Apr 24, 2011 | Sony Dual Shock 3 Controller for...
The charger port on my g zone boulder came out
you can get a dock to charge it on..u will need your wall charger and it plugs into the desktop charger/dock/cradle or whatever u wanna call it. Then u bypass the need for a port. Bad thing is u cant use the car charger easily without taking the dock with u in the car/but can be done! I am looking for replacement ports for casio phones..if anyone knows where u can buy them?
Dec 12, 2010 | Casio G'zOne Boulder Cell Phone
Env2 charger wont fit in the hole and wont charge my phone
The issue is the charger port on the ENV2 breaks fairly easily. Thefirst step is to contact your carrier to see if it is covered underwarranty. If it is, great get it replaced.
If not, you have 3 options:
1. you can get the charging port repaired. The cost is about 50 dollars. I recommend Cellulardr.com
2. you can get a new phone. cost ???
3. You can get an external battery charger to charger the battery separatefrom phone. cost about 25 dollars. Check out the following link forones that are available on ebay. A extra battery is a good idea as well so you can have one charging at all times.
LG VX9100 ENV2 External Battery Chargers
Hope that helps
May 28, 2009 | Verizon Communications enV2 Cellular Phone
Can't charge my enV2
The issue is the charger port on the ENV2 breaks fairly easily.Thefirst step is to contact your carrier to see if it is coveredunderwarranty. If it is, great get it replaced.
3.You can get an external battery charger to charger the batteryseparatefrom phone. cost about 25 dollars. Check out the following linkforones that are available on ebay. A extra battery is a good idea aswell so you can have one charging at all times.
Hope that helps
Mar 07, 2009 | Verizon Communications enV2 Cellular Phone
I have a LG AX8600 and have to move the charger plug in till it will charge and if it doesnt sit in the right postion it will not charge, tried different charger and this is a brand new phone, traded in...
I have seen this with multiple phones, the problems can be in a couple places. Even with a new phone the charger port can be easily damaged, also your chargers (I know you have tried more than one) could have a couple problems; wrong size, short in power cord for charger, and damaged/ worn contact points. I suggest you take your phone to your local provider and see if the have the same problem when the plug the phone in to their own charger, if they do it is probably a charger port problem if they don't see the same problem you might just need a new battery charger. I know this seems redundant but it has to be one or the other. hope this helps :)
Nov 08, 2008 | LG Cell Phones
Phone simply wont charge
You have to use right Charger Model :PSM5049 A
Input 100/240V ~50/60 Hz .0.4A (Amper) !!!!!!!
Output 4.4V --1.5 A
The one you using probably is for Blure Tooth wich is weaker:
Model PSM 5037B
Input 100/240V ~50/60Hz 0.1A Amper
Output 5.9V 375mA
Aug 19, 2007 | Motorola Mobility A1000
My sidekick 3 has problems
It sounds like the prong in the middle of the AC input is loose and therefore not making a good connection with the charger. What do you mean when you say "it won't come all the way back on?"
Aug 16, 2007 | T-Mobile Sidekick® 3 Cellular Phone
LG Dare VX9700  Cell Phone Logo
41 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
