Question about Husqvarna Rose
No power to machine !!!! - Husqvarna Rose
  • 6,993 Answers
if it does not power up, then it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Take care...
Posted on Mar 23, 2011
Machine does not power up
The fuse is located in a little black box underneath the base of the machine, but it is not an easy job to take the box out, disassemble it, replace the fuse, and then reassemble the whole machine. I suggest you take it to a service center.
Aug 31, 2008 | Janome Memory Craft 4000 Sewing Machine
My Bernina E65 will not turn on. No power to the machine.
1. check the outlet
2. make sure the power cord is plugged into the machine snuggly and correctly
it also possible that the power cord went bad and that the machine needs to be checked to see if there is something wrong with the power cord or the plug in the sewing machine. or if there is something wrong with the on off switch..
Sep 04, 2013 | Brother XL-3030 Electronic Sewing Machine
Machine stop running
Make sure all power connections are in place, to outlet and to machine. Make sure power switch in ON.
Check outlet with working lamp to ensure power is coming to that outlet; check panel box to make sure power is coming to that outlet.
Aug 27, 2013 | Singer 2259 Sewing Machine
My Pfaff model 1211 machine won't come on. The power switch has been replaced but no light and no power for stitching
Sounds like a bad connection somewhere as the power seems intermittent. Consult your repair man to check the electrics.
Apr 06, 2017 | PfaFF Sewing Machines
Machine stops sewing
is the power cord for the machine plugged into the outlet correctly?
is the power cord plugged into the machine correctly
if the answer is yes to the above questions then
there could be something wrong with the motor
and the machine needs to be checked
Dec 19, 2012 | Euro-Pro Sewing Machines
Power doesn't work!
Disconnect, re-connect. If there is power at the outlet and the machine does not have any power, you may need a new power cord.
Or, it could be the switch is broken (internally).
Have the machine checked by a sewing machine service person.
Feb 21, 2010 | Singer 6038 Mechanical Sewing Machine
Power to the machine is ok the light dosen't
The power lite needs to be replace.
and check the power cord you might have a faulty line..
Jan 20, 2010 | Juki TL-98Q
I live overseas, and brought this sewing machine
its not transformer or machine problem at all.all the connections are also proper.its the power issue the required power to the machine is not getting from the electric outlet.just call the local electrician and check out the power supply voltage from the electric outlet.and power required to the machine which will be listed on the machine.if more power is required he will connect the over power IC and get the machine work.if less power is required he will connect the RESISTOR and lower the power to the machine and make it work.
Aug 30, 2009 | Simplicity Sewing Machines
Sewing Machines Logo
185 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
