Question about Dryers
Red, black, white I know the whte is neutral. Does red go to L1 or L2
    Novelist:
    Champion:
  • 210 Answers
You're correct about the white wire, it is neutral and should be attached to the center prong of the plug. In actuality, it doesn't make any difference which of the red or white wires goes to whichever prong, L1 or L2, the dryer will work either way. Just be sure the wires are connected tightly, wires that come loose and move back and forth in a recept slot cause heat, sometimes enough heat to cause something close to catch on fire. Tight connections on electrical systems save a lot of problems.
Posted on Mar 24, 2011
    Sergeant:
    Champion:
  • 202 Answers
Red goes to L1
Posted on Mar 23, 2011
How to connect the power to the dryer
most likely 240volts as most 120 volt dryers are already wired,depending on if its a 3 or 4 wire system depending on local electrical codes,but if its a 3 wire cord,take the RED to terminal L1 and Black to L2 terminal on the dryer terminal board HINT:(the RED and Black can go on either L1 or L2 they are interchangable) ,then the White wire to the N neutral terminal on the dryer terminal board usuall between the L1 and L2 terminal,if theres a Green Wire on the cord this is safety ground and can be attached to any metallic part on the dryer,if its a gray flat cord the 2 outside wires are L1 and L2 the center is Neutral,
so its:
RED=L1 or L2
BLACK=L1 or L2
WHITE=N or Neutral
GREEN=Safety Ground the metal dryer frame
Dec 09, 2012 | Dryers
Hi just wondering about 240 volt.What is the black wire and what is the red one and green and yellow....Which one is L1- N- E
The black wire is Half of the 240 volts. Both the black and red wires carry 120 volts to make 240 volts. The green wire is going to be your grounding wire. The yellow wir is more than likely your neutral wire (although that goes against the electrical code). Tie in L1 to either black or red. Attach the yellow to n. I hae no idea what the E stands for. What color and how many wire are coming from the oven?
May 08, 2011 | Ovens
I take it the wiring harness in front of me is 3 Phase. I have a Green wire, Red, Black and White. The wiring diagram on the back is marked L1, L2, N, E. Just need to know which wire goes where thanks.
It is not 3 phase...just single phase 240V....L1 goes to the one hot side of the 240 v, l2 goes to the other hot side of the 240V, N goes to neutral, and green goes to earth ground (metal box)
so....L1=Black L2=Red N=White E=Green
Jan 22, 2011 | Ovens
Need to know how to hook up to 220 power supply what wires go where we got a red wire,black,white, and green which is ground can u help?
L1
L2
L3
Neutral
Earth
North America
Black
Red
Blue
White
Green
There is no blue cable in a 220V, so you have only; white, black, red and ground always green colored wire.
Looking your plug frontal side.
Green Ground on top (semi-circle)
black on left
red on right
white on bottom (neutral).
Jan 10, 2011 | Miller Bobcat 3 Phase Welder Generator...
Wire from circuit breaker is Black/White/Bare(ground). From Jenn Air is Black/White/RED/Green (ground). How do I wire? Jenn Air Black to Black, Jenn Air Red and White to White? Grounds (Jenn Air Green to...
depending on your local electrical code:and I see that the unit is 240 Volts A.C., then RED=Power/Black=POWER(L1 & L2)/WHITE="N"Neutral/and GREEN=SAFETY GROUND,on the new unit, then use from the wall power BLACK = L1 and White= L2. then on the unit RED=L1 and BLACK=L2(either way you hook these 2 up there isn't a polarity issue on these 2 wires) on the units hook-up/then use the BARE supply wire as neutral and tie BOTH WHITE and GREEN from the unit together to this BARE wire
Apr 29, 2010 | Jenn-Air JED8230 Electric Cooktop
Install power cord - color sequence . Converting a 3 prong to a four prong power outlet.
a 3 prong has a black/red wire for L1 and L2 hots... then white for neutral- in the four wire setup it will be as follows black L1/red L2 both hot wires, white neutral or "N" terminal and /Green for safety ground to unit case
Sep 15, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Drier has stoppd heating. Exposed heating element. Coils not glowing. notice that coil is for 240 v and we are in the USA, on 120 v system. Continuity test of coil causes light to only flicker.
You need the dryer supply voltage to be 240VAC for the heater. Everything else runs off one leg of that or 120VAC L1 (Black)-Neutral(White)-L2 (Red)
L1 to L2 = 240vac
L1 to Neutral=120vac
L2 to neutral = 120vac
Eric
Jun 29, 2009 | Kenmore 63942 Dryer
Whirlpool Dryer LER7646EQ1 Not heating
If your drive motor is turning, but your timer and heating circuits are not working, it sounds like you could be missing one leg of your 220 service. The dryer timer and heating circuits utilize the full 220 from the receptacle, while the drive motor only uses 120 VAC. Unplug your dryer and check the voltage at the wall receptacle. You should read 220-240 VAC across the two hot leads (these are the two large slots). The wires are BLACK - L1 & RED - L2. If you only read 120, check each slot to the NEUTRAL slot (white wire) to determine which one is missing. Chances are, you may have a break in the L2 (red wire) line. Here's the wiring scheme depending in which type of power cord you may have:
3-prong color code:
BLACK (HOT – 110-120VAC) – May also be referred to as L1
RED (HOT – 110-120VAC) – May also be referred to as L2
WHITE (NEUTRAL – 0VAC) – Usually grounded to the equipment frame via a jumper wire or metal strap.
4-prong color code:
WHITE (NEUTRAL – 0VAC) – DO NOT ground to equipment frame.
GREEN (GROUND) – Attach to equipment frame.
Please doublecheck and let me know. If your source voltage is correct, perform continuity checks from the end of the power cord to the terminal block in the back of the dryer. Inspect for any burned or broken wires. If you are not able to isolate a problem at this point, please post back and let me know. I can assist you further. I hope this helps.
Aug 13, 2008 | Dryers
Installing a Dayton G73
If that is a 240V unit then you are correct wiring L1 and L2 to black and red. Unless the unit uses 120V for something like a control panel, it doesn't need the neutral.
Jan 14, 2008 | Dayton G73 Utility Heater
Dryers Logo
48 people viewed this question
Top Dryers Experts
