Question about GE Refrigerators
Freezer works but not refrigerater why? - GE Refrigerators
  • 6,993 Answers
If refrigerator is not cooling properly can be due to a defrost timer, which is causing the fridge to go into defrost cycle. Usually it takes 45-60 minutes for refrigerator to come out of defrost cycle. If the timer goes bad then it will not come out of defrost cycle and can result in this kind of issues. It can also occur due to defrost thermostat, it allows current to pass through it at temperatures of 20 to 30 degrees Fahrenheit and prevents current from passing through it at 40 to 60 degrees. This is difficult to test, though, because it takes a prolonged, very-cold temperature to turn it on. The defrost thermostat is snapped onto the top portion of the evaporator. The thermostat sends temperature information to the processor. The defrost heater must be replaced when replacing the thermostat.
1. Remove the lower fan duct work from the evaporator cover.
2. Remove the 1/4-in. evaporator cover screws and remove the evaporator cover.
3. Disconnect the defrost thermostat wiring connector.
4. Remove the defrost thermostat from the evaporator.
I hope the above helps.......
Good luck.
Posted on Mar 23, 2011
My refrigerater is still iceing up ,in the freezer part,causeing the refrigerater too be warm ,and i have already changed the heater and the thermostat.
if you have a full freezer and a not so full fridge a brand new one will do that but check your door seals as well
Apr 23, 2012 | Refrigerators
My whirlpool refrigerater is not cooling properly, the freezer is working but the fan in back turns freely by hand but I haven't seen it actually start by itself
replace fan motor. same thing happened to me but I can't see other end of fan wires.I will have to cut and solder wires for new fan...I have question on how to get that darn relay box off compressor to see where condenser fan wires go!!!
Jan 28, 2012 | Amana ATB1832AR Top Freezer Refrigerator
The refrigerater wont cool
defrost for a few hours
Mar 11, 2010 | Refrigerators
Refrigerater is not cooling
The refrigerator gets air from the freezer. Look in the freezer for frost. If you have frost in the back or bottom the you have a defrost problem. Could be a timer or heater that is bad. If no frost do you hear a fan? You should have a evaporator fan running. Maybe thats out and it not circulating air for the refrigerator. You can check this out.
Hope it helps
Aug 17, 2009 | Whirlpool Refrigerators
My freezer and refrigerater will not get cold
u would have a leak in your sealed system if the fan and compressor are working and still not cold very expensive to fix
Mar 18, 2009 | Frigidaire FRT21H8 Top Freezer...
Jenn-air side by side refrigerater
Make sure the fan is working ,its located behind the freezers back wall.(5 to 7 screws) If it is working the vent from the freezer down to the refrigerator may be blocked.With out a fan you have no circulation .Also if you can move everything out unplug it w/ doors open 12 to 24 hrs this will free up any clogged tubes.Turn it to 4 or 5. Good luck.Let me know.
Len West
Feb 21, 2009 | Refrigerators
Freezer is cold but refrigerator is not?
In new models the freezer also cools the refrigerater with a fan. you have to call a repairman to do this work. he has the equipment to test the fans.
Aug 20, 2008 | GE Refrigerators
Deep freezer smells
ive heard that works also frigidaire makes a product called fridge aid that you can get at Lowe's or home depot that works pretty good made out of activated coconut charchol but yes you can do the coffee grounds in the freezer
Mar 28, 2008 | Refrigerators
Refrigerators Logo
142 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
