Question about Makita 7 1/4" Circular Saw 5007NB
My cutting depth lever will not tighten. How can I adjust it?
  • 2,176 Answers
On the lever there is a circlip that you remove and remove the lever, tighten the hex nut with the lever until it holds in place and reassemble in the reverse order. Also you might want to check the carriage bolt to ensure not rounded or the shoe bracket is not spread allowing the bolt to turn instead of locking the shoe. Let me know if you need more assistance
Posted on Mar 24, 2011
Skilsaw 7 1/4 saw depth locking lever will not tighten even when all the wsy dn. Can it be adjusted?
Take a look at the hinged part of the locking lever, usually there is a nut and bolt, looses the nut, open the lock all the way, tighten the nut and see if this helps. You may not like the position that it locks in, so then loosen it again and open half way, then tighten and check to see where it locks again. The lever may have a cam or tapered part that forces pressure on things to lock it. Examine it and find out how the lock works and then adjust it appropriately.
Mar 24, 2015 | Saws
I have a 6-1/2 "
go to milwaukeetool.com and you can download a copy of the owners manual with detailed instructions on this tool
Sep 02, 2011 | Milwaukee 0730-22 V28 6-1/2" Circular Saw...
I have a Craftman 19 HP riding lawnmower - used Model 944607192 My question is how do I adjust cutting blade depth since I do not have a manuel
There should be a long lever to your right when seated, move that lever forwards and backwards for height adjustment. Good Luck...
Aug 16, 2011 | Garden
I am unable to raise or lower the cutting surface of my DW734 thickness planer. The turn handle is very hard to turn. Is there some kind of a locking mechanism ? If I had a manual I might be able to figure...
Follow this link: http://servicenet.dewalt.com/Products/Detail?productNumber=DW734
This will allow you to download the manual and exploded art for base, cutterhead and motor. You may also want to check the position of the turret stop. First of all, make sure the cutterhead lockdown lever is disengaged. Here is from the manual:
Your planer is equipped with a turret stop (M), shown in
Figure 11, for repetitive planing of pre-set depths. Stops are
set at 0", 1/4", 1/2" and 3/4". Use the 0" setting when planing
between 1/8" and 1/4".
TO SET A PLANING DEPTH
1. Be sure the carriage is set above 1-1/4" before trying to
set the turret stop.
2. Turn the turret stop until the desired measurement
shows (Fig. 11).
3. Unlock the head lock lever (Fig. 8). Turn the depth
adjustment crank, lowering the carriage by the desired
increments, until it contacts the turret stop.
NOTE: DO NOT USE FORCE TO CRANK THE CARRIAGE
BELOW THE LEVEL THAT THE TURRET STOP INDICATES.
PERMANENT DAMAGE TO THE HEIGHT
ADJUSTMENT SYSTEM ON YOUR PLANER WILL
RESULT.
NOTE: The 3/4" turret stop can be adjusted for other planing
thicknesses. Adjusting the 3/4" turret stop does not affect the
other turret stop settings.
TO ADJUST THE 3/4" STOP FOR OTHER
THICKNESSES
1. Unlock the head lock lever (Fig. 8) and turn the adjustment
handle counterclockwise to raise the cutter head.
2. From the back of the tool, locate the turret adjustment
bolt (N) shown in Figure 11. This bolt is set for a 3/4"
depth of cut at the factory. Use the crescent wrench provided
to loosen the jam nut. Adjust the bolt up or down to
reach the desired planing depth.
3. Turn the depth adjustment crank, lowering the carriage by
the desired increments, until it contacts the turret stop.
Hope this helps.
Dec 27, 2010 | Dewalt DW734 Heavy Duty 12 12" thickness...
We have Skil 7 1/4 circ saw model 5400-01 how do you adjust blade depth?
There is a lever on the back of the top blade guard, if you pull up on it you can adjust the foot up or down to control how deep the blade will cut.
Oct 16, 2010 | Skil Xdrive 7 14" Circular Saw Ships Fast
What is the lever on the side of clippers
The lever adjusts the depth of the cut
Jul 07, 2010 | Wahl Health & Beauty
My saw blade slowly works it's way down making a rabit cut too shallow
Must be a slipping depth adjustment---put larger turn button on so can tighten more.
Feb 26, 2010 | Saws
Depth of cut lever very tight.
This unit has a lock nut on the cam actuation of the height adjustment. Loosen the locknut a touch at a time to get the right feel you are lookin for.
Jan 15, 2010 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Adjustment of sharpened cutter of porter cable 653 versa plane
There are two adjustments. First find the screw on the right side that allows loosening of rear baseplate. Once loose, another screw jacks the base up or down. They are both hex heads on mine.
Turn jack screw until a straight edge along the base just clears the cutter. Spin the cutter once to make sure both edges are the same depth and that both clear the straight edge.
For the front shoe, turn adjustment handle to zero. Remove the adjustment handle from the front shoe and find two vertical slots at the front. Two screws (hex heads) allow loosening of shoe. Once loose, the shoe can be adjusted by sliding up or down. With a straight edge held along the rear base and touching the front base, align the front shoe so straight edge barely clears blade and tighten screws. The front and back base should line up. Replace adjustment lever and recheck zero cut clearance as well as maximum depth. Readjust as necessary. If zero clearance is not an issue, the bases can be set to allow deeper cuts than factory specified. It's a powerful planer so if you're cutting softer woods, a deeper cut might be desired.
Apr 13, 2009 | Dewalt Tools & Hardware - Others
Makita 7 1/4" Circular Saw 5007NB Logo
257 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
