Question about HP LaserJet 1320 Printer
Hi! I just changed my print cartridge (HP LaserJet- C7115X, ink 15x) and the printing quality is still low! It's as if it's still running out of ink, however the cartridge is brand new. Please help!
  • HP Master
  • 1,915 Answers
Did you remove the strip that the printers ship with? If the pull tab is still in then there is typically enough toner to print a few pages and then it fades out. Remove cartridge and check on left and right hand sides for a plastic loop usually orange. The instructions would have been in the box.
Posted on Mar 24, 2011
How do i fix an incompatible ink cartridge
The HP laserjet 1000 takes either the C7115A or C7115X cartridge. The common name is a 15A or 15X. If you have anything else - forget it, it won't fit. If you have a new/refilled one that does not work properly - make sure you have removed the seal tape or return to supplier.
Jan 05, 2015 | HP LaserJet 1000 Printer
I have purchaed HP toner cartridge 13A from Computer Shop. But print quality of ink is poor. So, how to increase more quality of ink.
Hi
For increase the print quality go to the printer properties and go printer preference and select the device setting and set your setting.
Jun 17, 2011 | HP LaserJet 1300 Printer
Does not print dark enough to read. Changed toner and adjusted print darkness feature. Still does not work. Any idea what to do?
Hi
When printing, just adjust the PRINT QUALITY to PHOTO because I believe your print quality is set to TEXT. I am sure it will print move darker than before.
I hope it helps you solve your problem.
Regards
Feb 15, 2011 | HP LaserJet 3030 All-In-One Printer
I have a 15A C7115A printer Cartridge. We had purchased it to work in the hp Laserjet 1200 series. The cartridge that was in there was a 15X. Should it work? Am I inserting the cartridge incorrectly -...
the printer HP1200 uses both cartridge models, the only diference between them is that HP cartridge C7115X is for 5000 pages @ 5% coverege and HP cartridge C7115A is for 2500 pages @ 5% coverege.
The silver ribon that is hanging out is the cartridge sealer and you must pull on it until it comes off.
Nov 19, 2010 | HP Office Equipment & Supplies
Having trouble fitting new ink cartridge
Hi, when an ink cartridge runs low in your HP Officejet 5610 All-in-One printer, you will see a message on the printer's display screen. Faded-looking text or pictures also indicate low ink. Ensure print quality by replacing ink cartridges when they run low.
Instructions
Things You'll Need:
* HP #27 or #56 black, #22 color or #58 color photo print cartridge, or compatible equivalent
Turn printer on if it is off. Never attempt to change the ink cartridge if the printer is off. If it is off, it will not properly position or release ink cartridges, and attempting to change the ink cartridges may damage the printer.
Open the print-carriage door, located on the right side of the printer. The print carriage will automatically move into the access area.
Push down on the top edge of the cartridge you are replacing to pop it out of its slot. Remove the print cartridge and discard or recycle.
Pull off the protective tape on the new print cartridge using the pink tab. Do not touch any part of the cartridge except the black plastic. Touching the contacts or ink nozzles under the protective tape can damage the cartridge and result in poor print quality.
Hold the cartridge upright and push gently forward into the empty ink cartridge slot until it clicks.
Close the print-carriage door.
You can also use this video clip to learn more:
youtube.com/watch?v=wVXUndG-o_Q.
Please don't forget to rate me thanks.
Thanks for using fixya...
Oct 26, 2010 | HP Officejet 5610 All-In-One InkJet...
Cannot print in black because color cartidge is out of ink
There is a 'low toner' override in the menu system, but if this has NOT been set already, a 'flag' will be set on the chip on the cartridges that are low/empty.
The printer needs to 'see' cartridges that are usable, i.e. NOT empty, in order to function.
It is possible to replace just the chips on the colour cartridges, but then any colour printing quality could be compromised of course, as the colours will be low/empty. You would then be able to use the printer as if it were a mono laser, just changing the black cartridge when needed
Apr 27, 2010 | HP Color LaserJet 2600n Printer
Smudged printing. Ink cartridge just replaced.
This is a laser printer and does not have a print head to be cleaned. Fortunately it does have a laser cartridge that can easily be replaced and solve all of your problems : ) The replacement cartridge is a HP Q2613A or the high capacity HP Q2613X. Your local Cartridge World should have a high quality refilled cartridge that will treat you very well and save you money.
Jan 03, 2010 | HP LaserJet 1300 Printer
HP3015 All in One - new toner put in but printing very pale
Try going into the Maintnence Center, should be in Options or Maintanence and running it.
Mar 11, 2009 | HP LaserJet 3015 All-In-One Printer
Black Horizontal lines
hi!
Horizontal white lines usually indicate the ink cartridge is running out of ink or has some clogged ink nozzles. Try the following steps:
  1. Some of the ink cartridge ink nozzles may be clogged with dry ink. Use the ink cartridge cleaning service to try to clear them. Follow the steps below:
    1. check if there is plain white paper in the Input tray.
    2. Press Setup .
    3. Press < or >to select Tools and then press OK .
    4. Press < or > to select Clean Print Cartridge and then press OK . The unit prints a test page.
    5. Examine the test page. If the print quality of the page is good, stop here. If the print quality appears to be getting better, run the Clean Print Cartridge utility again
  2. If the self test appears better, Increase the copy quality setting (Normal or Best) and try copying again. If the quality is still poor, continue to the next step.
  3. If the quality is still poor, one or more of the cartridges may be low on ink or empty. Follow the steps below to check the ink levels.
    1. Open HP Solution Center .
    2. Click Settings .
    3. Click Print Settings .
    4. Click Printer Toolbox .
    5. Click the Estimated Ink Levels tab.
    6. Replace any ink cartridge that is low on ink.
  4. If the ink levels are not low, clean the cartridge face and electrical contacts at the back of the print carriage.
    1. Open the front of the unit to access the ink cartridges.
    2. After the ink cartridges are at the center, unplug the power cord from the back of the unit, and remove the ink cartridges. The power cord must be removed to ensure that the unit is not damaged during the cleaning process.
    3. Clean the cross-hatched area of the ink cartridge with a soft clean cloth that is slightly dampened with clean water to remove any build up. Avoid cleaning the ink cartridge nozzle plate. Cleaning this area can force foreign matter into the ink nozzles and plug them
    4. With a soft lint free cloth slightly dampened with clean water, clean the copper-colored contacts on the back of the ink cartridges.
    5. Allow the cartridges to dry before reinserting them.
    6. Close the unit, and plug the power cord back in.
    7. Print a self-test page to check the results. Follow the steps below to print a self-test page.
      1. Press Setup .
      2. Press <or > until Print Report displays and then press OK .
      3. Press < or > until Self-Test Report displays and then press OK . The self-test report prints.
    8. If the problem is not corrected by cleaning the ink cartridges, replace the ink cartridge(s).
- hope it will help to resolve you problem...
Jul 14, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Hi I have just inserted a new HP ink cartridge 94 into my HP PSC 2350, as the ink was running low. I was printing photos, which keept printing with a red line throughout the picture. After inserting the...
Try opening the printer properties and cleaning the print heads (should probably be done each time a cartridge is changed), it uses some ink up but should clean the build up from running the previous cartridge dry and hopefully solve your printing problem.
Good luck.
Mar 29, 2008 | Computers & Internet
HP LaserJet 1320 Printer Logo
112 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
