Question about Maytag Neptune MAH9700 Front Load Washer
My Maytag Neptune washer wont start circuit breaker tripping and I got a flash from indside the washer i am an electrician who is very good at trouble shooting of electrical circuits but I do not have any schematics,what is the most likely problem?the door is open and power switch is off.Thank you
  • 29 Answers
Inside or on the back there is a schmatic with trouble shooting guide. remove top panel and look for burnt spots. most common issues would be broken/cut wire or bad board
Posted on Mar 23, 2011
I accidentally hit the off button of my washer instead of hitting pause to open the door. Now it wont start. How do I reset it?
Pull the plug or trip the breaker and count to 10. Put the power back on and that should reset it.
Or put it on a spin cycle and start again.
Apr 15, 2018 | Maytag Washing Machines
Girlfriend for some reason put a screwdriver in the door latch of our maytag neptune washer. Tripping the breaker. Got the breaker on. Plugged in washer . code dO . wont start.
The D0 error means the door is open. It is not but the switch is now broken and the machine thinks the door is open. IF you post the model number, I can link you the part.
Dec 06, 2017 | Maytag Washing Machines
Maytag neptune mah6500 front load washer stuck in cycle and trips dedicated circuit breaker.
Circuit breaker trips mean dangerous high current short-circuit somewheres, call serviceman.
May 03, 2017 | Maytag Washing Machines
Maytag Neptune Tripping circuit breaker midcycle
this looks like it may be your wash heater or your motor
if you take off your motor lead from motor if it still trips ???????? then look at the heater it wants to be replaced
Nov 22, 2013 | Maytag Neptune Washer Door Mah3000aww
Hi I have a maytag neptune MAH 9700AWW washing machine it stopped working and tripped the circuit breaker I am an electrician I would appreciate any help with this problem thank you
sounds like a shorted main control board inside in the upper portion of the unit,if it trips the breaker before you can do any functions on the machine,this is a 3phase inverter board for the 3 phase motor and the triacs do short on this board,if you can get it to fire up,then try running the tech sheet diagnostics located inside the units left wall
Mar 23, 2011 | Maytag Neptune MAH5500B Front Load Washer
I have Maytag Neptune front loader washer. When
Hi.
Error LR means Locked Rotor.
Either the motor is faulty, there is a wiring problem, or the control assembly is faulty.
Try tripping the circuit breaker to reset the machine, if code comes back a technician must have a look at the motor.
Jun 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer will not restart
There is a main control board on top which may need to be replaced,
if you remove the back top panel there is a tech sheet with a lot of information tucked in there, Suggest you plug something else into outlet to make sure outlet has power, and breaker is still ok,
good luck
May 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer trips circuit breaker during spin cycle
try unplugging the motor then put onto spin it will pump out ok and run othewise spin if all else is fine ,next reconnect the motor if it trips again then motor ' fault; repair /replace.
Apr 08, 2010 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune has no power any suggestions
Check for ~220 volts AC across the two slanted contacts on the dryer power socket. If nothing, check the house electrical panel for tripped dryer circuit breakers(pair)--push the breakers OFF, then ON to reset. Recheck for 220 volts at dryer socket--if ok now, try the dryer. You need to use a voltmeter for this checking. If it starts, then quits, you likely have an internal short (heating element) inside the dryer case that trips the circuit breakers.
Jul 23, 2009 | Maytag Neptune MAH9700 Front Load Washer
MAH3000AWW Trips 20Amp Breaker at rinse cycle
The motor is known to have bad windings. Do a search for "Neptune Washer will not start" Also just inside the control panel where the start/stop sw is should be a paper folded with the diagnostics test and schematic. It is tucked under the pressure sw attached to the back. If not there then search "Maytag Neptune motor phase test" There is also a Service Manual FREE at Goetlieh's site.
Sep 27, 2008 | Maytag Neptune Washer
Maytag Neptune MAH9700 Front Load Washer Logo
82 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
