Question about Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac
Pour gas in carb. will run few sec. replaced both gas lines and filter.
  • 718 Answers
You will need to clean the carb or if this unit has a walbro carb buy a rebuild kit and it will work just fine.. Good Luck...
Posted on Mar 24, 2011
New engine Kawasaki 25 hp mower engine has fuel starter engages won't start. I pour gas in carb it starts and run for few seconds what up.
Carb is not feeding gas to motor. Rebuild or replacement is mandated.
If there is a switch on the gas line to the carb it has to be turned on.
Sep 05, 2015 | kawasaki Garden
My 88 katana wont start An run but it will for a few sec if i put gas right in the carb I looked it over and the carb seems to be fine
Assuming that the fuel spigots are open, check for crud in the tank which is clogging the fuel line by blowing some compressed air backwards through the spigots, and change the fuel filter.
Apr 30, 2015 | GAS Motorcycles
Wont start getting gas to carb and have fire
The object on top of the intake is the throttle body. Are you getting power to the injectors, and a ground signal from the engine computer ? ?
Aug 06, 2014 | 1997 GMC Yukon
New carb on 49cc scooter. only runs for 30 secs then acts like it runs out of gas. still gas in new fuel filter that cam with carb
Sound like the float in the carb is getting stuck the way to tell is loosen the screw at the very bottom or carb and see how much gas comes out it should run forever if only runs for a few secs the clean out carb
Aug 07, 2013 | 2008 Keeway Matrix 150
Engine stopped. fuel cutoff. I thought I traced it to the underseat cutoff switch. replaced switch. still not starting. Will start and run on primed gas poured in carb. checked fuel filter(in line) good...
Pull plug andcheck and seeif it is Floded, see if plug is wet, and you can alson check and see if it is firing by grounding the the plug to the frame, with a ground wire and crak it over to see if you see it spark.
Sep 12, 2011 | John Deere 420,1020,2010,2020,2510,2520...
I have a troybilt mower with a honda 160 engine (#gcv160an5a) that will not start. I have cleaned the carb, replaced the spark plug, cleaned the air filter, new gas and oil. The spark plug is dry after...
You may have to replace the carb.But before you do.Check the the fuel line.There is a small screen in the carb,it may be clogged.Inside the tank is a small cylindrical filter,make sure it is good.Break the fuel line at the in line filter,to make sure gas is getting to there,if it is the problem is in the carb.
May 20, 2011 | Honda Garden
Engine stalled out,would not start, pour gas in carb,cranks,keeps running,until idle falls below 12to1500rpm,than stalls out again and will not crank,repeat gas or starting fluid in carb,cranks runs and...
This truck is fuel injected, the problem sounds like a weak fuelpump, it runs when you pour gas into it until that gas runs out, the first thing is to test the fuel preasure, if the pump is weak it may run with gas poured into it but wont idle, also a common problem is the coolant temp sensor and the ground wires to thermostat housing bolt but i wont bet its the pump inside the fuel tank, if you put a fuel gauge on it there should be at least 55-61 psi if its a few pounds lower it can cause problems, you have everything else and it runs with gas poured so its a fuel problem check the preasure, theres a valve up top on the fuel line to connect a fuel gauge to it, start there hope this is helpful.
Dec 27, 2010 | 1993 Chevrolet C1500
My yard machine Edger 3.5 hp wont stay runing if i put ges in the air filter hole it runs for a few sec. if I put my hand completly over the hole on the air filter it will run on low idle but as soon as i...
remove the gas can carefully the pulsa primer carburetor sits on top. Once you remove the tank open the cap and pour out the gas. THen carefully unscrew the five screws holding the carb on. Carefully lift the carb up leaving the gasket in place and clean the small 4 chambered bowl with starter fliud. Replace all parts put gas in it, push the primer until you see gas squirt into carb then pull the handle.
Sep 03, 2010 | Yard Machines Red Edger
NO GAS TO THE CARB HOMELITE 330 IF I PUT SOME GAS IN CARB IT RUNS FOR A FEW SEC.
Chain saws are known for plugged/pinched fuel lines
Drain the fuel tank
Remove the fuel line from the carb.
Blow air back in to the tank
Rinse out the tank
Repeat several times
Make sure your gas cap is clean and the vent in the cap is not plugged.
Make sure your air filter is clean
Refill with clean gas mix from a clean gas can
It should run for you
Let me know if this does not solve your troubles
Mar 15, 2010 | Welding Tools
Stihl 021 running poorly
Couple of things I would check first. Place a funnel in a can with a paper napkin covering bottom of funnel. Pour the gas from the saw into the funnel. If there is a lot of trash in there, remove the fuel line from tank. Clean the filter with carb. cleaner. Then clean the tank with carb. cleaner. If you still have problem. Replace the Air inlet tube, (clear tube with screw type device close to carb).
Apr 15, 2009 | RTO Spur Sprocket For Stihl 017, 021...
Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Logo
165 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
