Question about Kenwood Two Way Radio
Hi. My kenwood tw 4100 a drifts in frequency on 2 meters. I don't know about the 440 band. I haven't used that yet. What could cause drifting?
  • 27 Answers
Bad circuit components, and the only practical solution is to return the radio to Kenwood for service. The components that keep the frequency stable are supposed to check each other, so to speak, so that driting, if any, is minimal, and so little that the user does not notice it. You can find the Kenwood service by searching their site online.
Posted on May 01, 2011
Kenwood problems
do you mean the knob, or it just drifts down in frequency? if the knob drifts down, consult the manual on adjusting the tension on it, if it drifts down in frequency, it needs to be services, there are MANY things that can cause this
Aug 17, 2014 | Radio Communications
Baofeng UV5RA WILL NOT TRANSMIT
First, it's illegal to use that radio in the FRS bands. Also many of the Baofeng radios have very "dirty" output (spurs, frequency drift, bad modulation, etc). Your best bet is probably to buy another radio. With these radios about 3 of 10 I've tested have been bad.
Jul 21, 2013 | Radio Communications
My rg 66 signal meater dont work and no sound till it worms up whats wrong
frequency drifting on last number really doesn't make much difference. Lets say you are on CH 1 26.965 and the counter says the frequency is 26.9648 . Its not right but it close enough that its not going to make a whole lot of difference .Signal meter not working is not a problem either . You have to check the schematic for what voltage operates the meter,check to make sure that voltage is there. If it is then you should change the meter., if no voltage then you should check for the solution as to how to get it back. When the radio warms up and you hear people talking take some freeze spray and give the audio IC a shot to see if it still works or not .
Nov 17, 2012 | Ranger RCI-6900F-150 CB Radio
Galaxy dx 2547 base cb frequency drift problems
for upper ssb adjust L21 for 16.51250 mhz . adjust L22 for 16.50750 for lower ssb. you do have a frequency counter don't you ?
Jan 01, 2012 | Galaxy Radios DX-2547 40-Channels Base CB...
Assigning number to a frequency on kenwood TK-1118
You are talking about a HF (High Frequency) tranceiver, if your example is correct.
Assigning channel numbers to frequencies on a HF set, isn't possible on certain tranceivers in these bands, as there is no facility built in by default.
If you have the facility to store frequencies, I would do so in frequency order, that lowest frequencies first and gradually going up:
example:
4064
4960
5768
6770
7356
8560
9460
10210
14500
etc.,
I think you get my drift.
That's the best practice, that way you know where each frequency is located and the band it's associated with.
I hope this is useful to you.
Cheers,
Peter
Dec 01, 2011 | Kenwood Radio Communications
Hi, my 88 drifts off freq when it warms up. can you help?
  • Is it drifting off frequency by the radios meter or an external meter. If its the radios meter then hook up a meter externally.
Dec 26, 2010 | Galaxy Radios DX- 88HL Base CB Radio
Picture goes in and out
This will require you opening the back cover of the television to test some component with the use of an ohmmeter.
This may be a slight drift - like someone is messing with the fine tuning
or such a substantial change in tuning frequency that the channels go by
as though you are surfing.
Possible causes depend on tuner type:
1. Quartz tuner (10 button direct access digital synthesizer) - For a
slight drift, a component is probably changing value, possibly the
crystal in the reference oscillator. For gross changes - flipping
through channels - it is more likely to be a digital control problem -
the microcontroller is misdirecting the synthesizer to change frequency.
2. Varactor tuner (buttons but not direct channel access) - If only a
single pushbutton selection is the problem, the the varactor tuning diode
for that button is probably changing capacitance. If all channels in
a band (Vl, Vh, U) are having a problem, it is more likely to be a
drifting D/A or faulty AFT (Automatic Fine Tuning) circuit or power supply.
3. Turret or switch tuner (Knobs) - A component like a capacitor is changing
value.
You will have to get in there with a heat gun or cold spray and track it down
the old fashioned way. At least, the problem is almost certainly localized
to the tuner box (and possibly the controller if applicable).
As noted, gradual slight changes in tuning are likely due to frequency
determining components drifting.
Uncontrolled channel surfing is probably a logic problem. For the
quartz tuner, this could still be marginal connections causing the
microprocessor to misdirect the synthesizer to change channels.
For the latter case, particularly, the cause may still be bad connections
resulting in loss of channel memory and/or erratic behavior.
Take care...
May 21, 2010 | Mitsubishi WS-55859 55" Rear Projection...
Straight cutting with rip fence
when i use my table saw, i use clamps on the fence, i dont rely on the one built in.
Feb 26, 2009 | Craftsman 1/4 x 72-5/8" Band Saw Blade, 6...
Satellite dish receiver error LNB Drift detected
that's not true i work for dish network if u have an LNB drift of -8 or +8 you can get a free lnb service call and they can come out n fix at no charge
Apr 22, 2008 | DISH Network 301 DTV Receiver
Rci 6900f drifting
Since the RCI 6900 is a 10 meter ham radio, and not desogned for the 11 meter band, when you had it modified, you also expanded the PLL chip past it's normal use. 10 Meter radios are not designed for CB use ( and of course this is also illegal ) so the PLL does drift. There is no real fix on this problem. Sorry
Ed
NC Electronic
Mills, Wyoming
Dec 27, 2007 | Ranger Communications RCI-6900F-25 CB...
Kenwood   Two Way Radio Logo
162 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
michael galang
Jaime Hernandez
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
