Question about Panasonic PT-53X54 53" Rear Projection HDTV-Ready Television
Panasonic pt53x54j, When I turn the tv on it turns itself right back off. Last time I tried, puff of smoke and burning smell
Slinteriors
  • 8617 Answers
SOURCE: panasonic pt-53wx53g tries to turn on but goes right off
That is indicating that the convergence circuits have shutdown the set. You will need new Convergence ICs. They should be STK392-110 or STK392-120 either number works the 120 being the better chip. I will post a link where you can get the new ICs and they provide step by step instructions with pics so you can do the repair yourself. You will find your IC numbers under the section titled Convergence ICs just click on that and you will find your STK numbers.
http://servicemanuals.vstore.ca/
Posted on Mar 30, 2008
  • 9 Answers
SOURCE: turns on then right off after a click saw smoke coming out of tv
check the board, maybe is burned , I have the schematics, if you want it, write me to ipbass@gmail.com, only I need the model of the board
Posted on Aug 23, 2008
  • 108 Answers
SOURCE: Reset Time Problem on Panasonic TV (PT-50LC13)
Power on the set, listen for afaint buzzing sound as the set tries to fire up. If you do not here it then your lamp driver, or ballast is most likely faulty. Also make sure you have the door and all covers back in place and secure. And make sure you insatlled an orginal panasonic lamp because some generic will not work.
Posted on Jan 09, 2009
welcomejee
  • 10594 Answers
SOURCE: Tv turns off randomly but turns on after 35 seconds.
How old is this TV and when did you replaced lamp last time?
Posted on Jun 09, 2009
Ecollier2012
  • 3459 Answers
SOURCE: Panasonic pt-47wx53g tv power light blinkcs 5 times and goes out.
Convergence problem...causing the TV to shut down. Goto www.TvRepairKits.com and get one of their fixes.
Posted on Jun 06, 2010
A small puff of smoke came from top right of laptop
Was it dust? Could be the power in socket/plug.
Feb 09, 2014 | Advent 6552 Laptop
Small puff of smoke coming through the top right of the laptop
The fan usually wont fail in that manner, If it still works normally, you can go to www.almico.com and download a program called speed fan. It is free and it will tell you the temp of everything in that computer.
I started my washer last night then went to check on it and it was not on. I tried to turn it on but no power. I checked the breaker and it flipped the bresker so I turned it back on. When I push the power...
If the breaker tripped, something shorted to ground in your control panel. You resetting the breaker and pushing the power button then cause something to burn further. I would suggest turning off the breaker then taking the control panel off to see where the "burning smell and small amount of smoke" came from. Look to see if a wire was rubbing against metal somewhere.
Jul 31, 2017 | LG WM0642H Front Load
Panasonic PT-51HX40B turns itself off and has no video, no lights
The buzzing noise that you were earing came from a bad ballast, and because of the bad ballast your lamp must have got out also, and that is were you are getting the burned smel from and also that is why you are no longer geteting any picture either.
So in this case you would have to replace the ballast board and the lamp on your tv set.
Jul 23, 2010 | Panasonic PT-51HX41 51" Rear Projection...
Turned on tv no picture only sound then i heard a pop and smelled burning tv turned itself off. 5 min tried turning on tv again nothing happened tv does not turn on at this time
Your RCA TV needs serious troubleshooting. Burning smell is from HV transformer or resistors smoking.
Most likely power supply and/or high voltage circuit or convergence circuit. Many times RCA have multiple or secondary faults that occur with HV or convergence failure.
Repair of RCA HV or convergence usually requires exact manufacturer parts and upgrades or repair in power supply. I would not advise trying this repair without manufacturer support for correct part numbers and service bulletins.
easyab
Feb 28, 2010 | RCA Televison & Video
Puff of smoke from crack between heater vent and dash
antifreeze i think,heater matrix leak ,try putting a rad leak stopper in
Jan 19, 2009 | 1998 Ford Contour
Burning Smell with Samsung HC-p5241w
dont fear the smoke behind. firstly open your tv. get a brush and clean the in side,it might be other particals dropped in side.
you are able to see where the smoke is coming from.
a qualified tech will solve that without wasting time on it.
Jan 07, 2009 | Goodmans 257NS 20" TV
TV shuts off by itself and has a burning smell
mine is doing the same thing but i was able to pinpoint it to a capacitor arching and smoking. haven't replaced it yet so i'm not sure if it's just a bad capacitor or a more involved issue.
Jul 29, 2008 | RCA D52W19 52" Rear Projection Television
Panasonic PT-53X54 53" Rear Projection HDTV-Ready Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
