Question about Husqvarna Riding Lawn Mower 46 Cut Kohler Yth21k46
ENGINE OIL CHANGE QTY - Husqvarna Riding Lawn Mower 46 Cut Kohler Yth21k46
    President:
  • Husqvarna Master
  • 1,545 Answers
Your owner's manual states: 51 Ounces W/Filter and 35 Ounces of Oil Without Filter. This info can be found under specifications.
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2008/HOUS2008_532430577.pdf
Posted on Mar 23, 2011
Trans.qty oil
engine running transmission shifter in park ....little square on dipstick is for warm oil
quantity everything include is around 8 to 9 quarts
Mar 25, 2014 | 2004 Buick LeSabre
TRASMISSION OIL CHANGE
Transmission oil CVT TC 08886-02105, qty 4L.
Manual transmission SAE 75/85
Sep 03, 2013 | 2008 Toyota Yaris Sedan
I drained the oil from my gearbox and replaced it with the .85 L of 80W-90 gear oil recommended by my Clymer book. I then measured the amount of oil that was removed from the gearbox and it was close to...
How could you be sure that the oil qty that was in the gearbox was correct to begin with?
Sorry dont know which model BMW you have so cant tell you the correcdt qty.
Jun 20, 2011 | BMW K 1100 LT Motorcycles
I have a Yard Machine riding lawnmower model 699 with a briggs and stratton engine. I have lost the manuel for the engine and need to change the oil. is it a 30 weight and how much oil will it take?
hi there
here is web site for owners manual
http://lawnandgarden.manualsonline.com/manuals/mfg/yard_machines/series_690_thru_699.html
off the top off my head use sae 30 oil briggs and stratton oil
qty should be about 1.3 - 1.4 litre
but just drain oil while hot fit bung and refill to the upper oil level on the dip stick
cheers pauly46
dont forget the thumbs rating
Jun 05, 2011 | Garden
Oil is not low but oil light is on
  • This may be an oil pressure light in which case you need to inspect and or replace the Oil Sending Unit. Located towards the bottom of the engine. When these go bad the pressure will not stabilize and can damage your engine.
  • There is also a service bulletin to look at before replacing the unit.
  • TSB NO: 08-36-99
  • SUBJECT: Engine Oil Pressure Light Flicker
  • DATE: Oct. 15, 1999
  • OVERVIEW:
  • This bulletin involves adding a terminal/wire/vent to the oil pressure switch connector.
  • NOTE: THIS BULLETIN APPLIES TO VEHICLES EQUIPPED WITH A 2.7L ENGINE.
  • SYMPTOM/CONDITION:
  • With a hot engine the oil pressure light may be on or flicker on at idle.
  • DIAGNOSIS:
  • Verify engine oil pressure as described on page 9-21 of the 1999 Concorde/Intrepid/LHS/300M service manual (Publication No. 81-270-9140). If engine oil pressure is within specification perform the Repair Procedure.
  • PARTS REQUIRED:
  • Qty Part No. Description
  • 1 05017800AA Wire Terminal/Vent
Regards, Tony
May 11, 2011 | 2002 Dodge Stratus
How much oil does a briggs and stratton 18.5 horsepower engine hold?
use the dip stick as a guide
just fill it up with sae 30 oil untill the level reaches the full mark on dip stick, run engine and recheck level
on average qty might be 1.4 litres to 1.6
it varies between models
cheers
Aug 10, 2010 | Garden
WHAT IS THE FUEL/OIL MIXTURE FOR A POULAN PREDITOR 2150 CHAINSAW?
if using a good quality 2 stroke oil brand
mix it @ ratio 50:1 that is 100 mils of oil per 5 litres of petrol
or on a 1 litre basis it would be 20 mils of oil per litre
but !!!! if you are using generic 2 stroke oil from a garage
run it on 25:1 mix that is 40 mils of oil per litre of petrol
be sure to put required qty of in clean container 1st then add petrol qty to the can and give good shake , then fill your saw
cheers hope it helps
paul
Jul 31, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
What oil is ok for this old bike,1980 xj650 maxaim
look on right side engine cover/clutch cover, probably an oil level window there, small circular glass. oil quantity will be on cover probably as well, if it says 2,500 cc it's the oil qty not the engine size :))
Jun 16, 2009 | 1980 Yamaha XJ 650
Husqvarna Riding Lawn Mower 46 Cut Kohler Yth21k46 Logo
442 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
