Question about Samsung SCH-U450 Cell Phone
How to i get it to only vibrate once not 3 times
  • yadayada
    yadayada Mar 23, 2011
    Have you gone into tools and then to sounds?
  • 437 Answers
Hi polarbearduc you need to go into settings on the phone. or you can use thr setup wizard. Go under phone settings and look for master volume . then alerts. next you can change your vibrate from 3-1. Not all samsungs can change the vibtare modes. The wizad is at the very bottom of the settings and tools. number 11 if I remember right ok hope this helps. just follow the wozard step by step set up
Posted on Mar 24, 2011
Tip
CUSTOMIZING YOUR PHONE SOUNDS
the samsung sync is a pretty good phone with many options of customization available. problem is, most are hidden. heres how to access them:
1. open phone, and push the side key under the memory card slot. [alternatively, just get to the PROFILE option. in that case, skip 2]
2. scroll over to the 'PROFILE' setting
3. highlight the 'NORMAL' setting, and push the 'OPTIONS' key.
4. go to 'EDIT'. push 'CALL ALERT' and you get a wealth of options.
i will map them out for you too lazy to look through everything:
1.    INCOMING CALL
Call Alert Type:
                [Melody]
                [Increasing Melody]
                [Vibration]
                [Vibration Then Melody]
                [Vibration & Melody]
                [Vibration And Increasing Melody]
                [Mute]
Voice Call Ringtone
                [Takes you to My Stuff, where you can choose a .mmf file to use.]
Ringtone Volume
                [1-7]
Auto Reply
                [Activation OFF/ON]
                [IF ON, THEN REPLY TO SEND]
2.   New Messages
Message Alert Type
                [Melody]
                [Vibtarion]
                [Mute]
Message Alert Tone
                [OPTIONS:
                   [1. USE EFFECT TONE]
                   [2. USE MY ALERT TONE]
Message Alert Repetition
                [Once]
                [Periodic]
Alert Tone Volume
                [1-7]
3. PHONE SOUNDS
Keypad Tone
                [Beep]
                [Clean]
                [Mute]
Power On Type
                [Melody]
                [Vibration]
                [Mute]
Power Off Type
                [Melody]
                [Vibration]
                [Mute]
Folder Open/Close Tone
                [Melody 1]
                [Melody 2]
                [Melody 3]
                [Mute]
Volume, Phone Sounds
                [1-7]
if i missed anything, leave me a message, or email me:  mannyftw [AT] aim [DOT] com
on Oct 27, 2007 | Samsung SYNC SGH-A707 Cellular Phone
Steering vibration while driving
If your tires are not balanced or you have a warped rim this will do this, especially at certain speeds you will notice it more, I would have your rims balanced first, and keep in mind if a rim is not able to be balanced it is warped.
Oct 22, 2012 | 2006 Mazda 3
Want to silent keypad when typing or dialing
Hi nanro346,
Editing the Normal - Message Profile 1.Touch >Settings > Sound Profile >Normal. •Touch the name field and not the radio button to the right. 2.Touch drop-down menu (upper-right of the screen) and selectMessage. 3.Touch the Message Alert Type field, select one of the following and touchSave: • Melody: the phone rings using the ring melody selected in the Ring tone menu. • Vibration: the phone vibrates 3 times. •Vibration & Melody: the phone vibrates and plays a melody simultaneously. • Mute: the phone is silent and does not play a melody or vibrate. 4.Touch the Message Alert Tone field, touch to select a ringtone and touchSave. 5.Touch the Message Alert Repetition pull-down and select one of the following options and touchSave: • Once: repeats the message alert once. • Periodic: repeats the message alert periodically. 6.Drag the Alert Tone Volume slider to the volume level you desire (range is 1-7). 7.Touch the Vibration Pattern field, then touch to select Vibration 1 - 3. 8.TouchSave to return to the Sound Profiles menu
Apr 29, 2011 | Samsung SGH-A877 Impression Cell Phone
When my samsung impression is on vibrate, and i get a text message it vibrates at least 10 times. how can i get it to only vibrate once?
1)tap on settings
2)next tap sound profile
3)next tap normal
4)then tap on the upper right side (the dialog box that says call) with the drop down arrow
5)choose message
6) then you can set it from there, you can change the setting of your msg alert type, alert tone, alert repetition, alert tone vol, and vibration pattern.
Jan 10, 2010 | Samsung SGH-A877 Impression Cell Phone
My daughter has a samsung sch-r500 and dropped it. Now the screen is broke and can't see it. It keeps vibrating when it gets texts like every 3 minutes. How do I change the settings on the tones/vibrate...
The long button on the left side of the phone is what controls the tone/vibrating. Are you trying to set it to ring or turn the sound off completely?
If you want it to ring open it, and hit either button on the left side. Then hit the upper button once for it to beep one time when a text or call is received, twice for low, 3 times for medium, 4 times for medium/high, and 5 for high.
If you want to silence it, hold the bottom button on the left side down.
Nov 22, 2009 | Samsung Hue (SCH-r500) Cellular Phone
Recoil not recoilling good
hey fark
This is easy. Take off rope housing (four screws). Once off, pull the string out 3/4 of the way. Once out, tie string around spindle one extra time ( real easy just wrap string once more around winding spool ). This oughta make string snap back after pulls.
Jun 28, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Whenever I turn on my car there is alot of vibration from engine
bad engine mount make car shake.cylinder misfire make engine shake.
May 10, 2009 | 2000 Mitsubishi Eclipse
Dash does not vibrate??? anyone help
It does vibrate! All you have to do is hold down the # button for about 3 seconds and the let it go. The phone will vibrate once, and then it will have the "vibrate" icon at the top of the screen to let you know that it's on vibrate. To turn it off of vibrate, hold down the # again for about 3 seconds. Hope this helps!
Mar 08, 2009 | T-Mobile Dash Smartphone
Please
you can take the phone to a mobile store or a professional and have the phone reflash.
Dec 14, 2007 | Nokia 6300 Cellular Phone
Samsung SCH-U450 Cell Phone Logo
44 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
