Question about Gaggia Espresso De Luxe Espresso Machine
How do you disassemble a Gaggia Espresso Deluxe? In particular, how do you remove the plastic case? Are there tabs, screws, somewhere that I am missing? What part do I remove to access the boiler? I'm afraid of breaking off a tab. Usually there is a right/easy way to do this kind of disassembly and a wrong/hard/break-stuff way.
  • Anonymous Mar 25, 2011
    Ah, figured it out myself.
    There is a SINGLE phillips screw holding the top cover on. It's located down in the reservoir fill hole under the fill cover. Remove screw, tilt top forward and pull up.
EsWorld
  • 1618 Answers
SOURCE: cannot remove shower holding plate
After removing the 2 allen wrench bolts in the holding plate, place the flathead screwdriver on the plate and using side of group as leverage lift. Check diagram below92b399a.jpg
Posted on May 27, 2009
EsWorld
  • 1618 Answers
SOURCE: My gaggia coffee deluxe is struggling to produce
Descale machine, then backflush brewhead with espresso machine soap or cleancaff or purocaff.
Posted on Nov 12, 2009
  • 421 Answers
SOURCE: Coffee Switch on NEw Baby Gaggia needs to be replaced
You need to go here:
http://www.partsguru.com/GaggiaBaby.html
All you ever needed for Gaggia parts and manuals
Posted on Jan 13, 2010
espressonist
  • 1711 Answers
SOURCE: How to remove shower disc
You can use the filter holder blocked with a piece of nylon so water will make the coffee around the shower and screw to desolve. Just keep the filter holder with hot water for 30 min and then try to remove the screw. You can hold the small screwdriver with a plyer and by heating it a litle bit on the back try at the same time to turn it. This will loose the screw.
Posted on Feb 17, 2010
  • 17 Answers
SOURCE: Hi. I have a Krups XP7245 combination
I had the same problem with the XP7240. The rubber seal in the plunger that pushes out the coffee cake after brewing is worn or dirty. You need to romve the cover by taking of the top (screws in the bean collector and cover tray for cleaning tablet). You have to be rough because parts are clicked together. The face of the machine comes off by pulling it upwards (it is just clamped with plastic nudges). Once that is done you remove the 4 screws that were hidden by the stainless steel face. Then remove the electronic board (leave connections on except for bean grinder and boiler). Grinder can then be removed followed by the cream cover. Remove the 15mm steel nut on top of the arm. Remove the front and display. Then use a torix on top of the brew plate and an allan key on the bottom of the plunger. Unscrew, remove spring and seal (very small cup). Let me know if you need more instructions (take a rainy sunday afternoon to do this)
Posted on Aug 15, 2010
I have a Gaggia "coffee" and no water goes through
Remove the 2 allen wrench screws under the screw and screen, this will drop the diffuser, careful do not loose spring and plastic ball that is in there. Then run machine without parts in place to check if water goes through. If yes replace parts minus screen and screw and test, it taht works insert screen and screw and test.
Sep 21, 2011 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
I have a gaggia deluxe coffee machine which won't dispense coffee. the pump works with the steam nozzle and I've checked the guidance on the possibility of an air lock, and dispensed a lot of water...
it can be 3 problems, you can eliminate them 1 by 1 in this order:
  1. Calcium in the boiler > you unscrew the filter&filter holder(2 bolts) than you unscrew the screw in center (you see it after disassembling filter holder). If it is full with calcium, the pipe which goes vertically up for few centimeters you can drill it with 3 mm drill BUT AFTER YOU TAKE OF THE FINAL 4TH BOLT. You continue and release the short pipe and provide flow from boiler, test it and clean it than with decalcifications'(it will be more easy for you)
  2. We suppose case 1 isn't, and u have flow after unscrewing the 4TH bolt, than you must check the pressure valve (it returns the higher pressure with dispensing water back to container. Follow the short rubber pipe and you will find it. check the gasket and functioning of it
  3. Pump could be to week with pressure that she can't open the spring of valve above 4TH bolt, in this case you need to change pump.
Mar 02, 2011 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Water for steamer but no water flows to make coffee
Remove the screw and shower screen under the brew head, make sure screen is clean, try running the head to see if water flows, if no water remove allen wrench screws, and check spring and valve seat, DO NOT LOSE SPRING AND VALVE. Try running head, if water does not flow, reassemble and descale machine.
Sep 10, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
I have a Gaggia Deluxe and it keeps dripping after you turn the switch off.
If it drips from the head, then remove the screen and screw, then the 2 allen wrench screws and diffuser, and check the spring and valve seat, that might be off centered, adjust and re assemble.
May 02, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Gaggia Titanium. . coffee not hot even though
Remove the filter holder and brew some water into a small plastic cup and check temp, it could be the thermostat for the coffee temp is damaged.
Apr 29, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
My gaggia coffee machine hasn't been used for a few months and now won't dispense hot water through the coffee unit
First remove the screw and screen then press brew button to run water, if that works clean screen and reassemble, if not you will have to remove the allen wrench screws and clean the diffuser and vlave spring.
Aug 09, 2009 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Low water temp Gaggia Coffee
descaling time with descaler not vinegar descaler melt calcium no calcium in boiler =warmer coffee vinegar remove some calcium in piece that might block somewhere else
THANKS FOR USING FIXYA
PIERRE
Feb 19, 2008 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Water leaking from chrome casing
check below some screw or push type open wl small screw driver separate the cover check hoses leak.if hose detached return and install clamp.
Oct 20, 2007 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Gaggia Espresso De Luxe Espresso Machine Logo
287 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
