Question about Polaroid FLM-3732 Television
Tv will not even show red led when plugged in. worked fine til power outage. not fuse, tried that. problem?
  • Polaroid Master
  • 6,993 Answers
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Mar 23, 2011
Tv will not show a picture but will power on. most likely a surge from power outage.
Sounds like the circuitry is fried. You could have a TV-technician troubleshoot it with a multimeter, perhaps it's just something simple and cheap like a fuse or even the converter. Otherwise it might get so expensive, that it's not worth the repair ... unless you have warranty ofcourse !
Jun 23, 2014 | JVC EM32T 32" Class Emerald Series 720p...
TV won't turn on
there is a surge protector on the main power board this has probably blown. or the main power board fuse or plug fuse. check them one by one. there even may be a secondary fuse in the tv around 3amp witch can blow. it will have red and black lines on it or orange that is the rating of the fuse. surge protector is like a battery shap round with 2 prongs onto the board.
Sep 20, 2013 | Panasonic VIERA Televison & Video
I have LC-42D65U and unable to turn on the TV after experiencing power outage. Seems like its power button works and briefly hear the sounds, but cannot see the screen. After power outage, I have reset the...
Now tv turn on have power LED and OPC LED lights indications flashes together?Yes,this problems,it is the tv Tuner signal board it is causes and the problems.That the board where the incomming broadcasting signal cable plug into it.If turn tv on.No power LED light or any kind LED lights at all.Yes.Than the tv power supply board that the cause and the problems,that the board where the tv power a/c cord plug into it.U have some basic mechanicals skills like take things aparts and putting it back together again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board or tv power supply board for the replacement.
Aug 11, 2011 | Sharp LC42D65U 42 in. LCD HDTV
Tv won't turn on 4 blinking led
Red led blinks 4 times is an error code that shows that fan is not running in tv, check fans connections and make sure all are plugged properly.
Thanks.
Jul 18, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
VCR will not show picture or menu on TV after power outage.
Hate to say this, but when power outages occur, things like vcr's are the first thing to fry. But if you feel that the vcr is fine as far as powering up, then unplug it from the wall socket for 30 minutes or so, plug back in and see results.
Apr 13, 2010 | Televison & Video
43FDX15B No picture, Power light stays on
Just a thought, but check all of the pico fuses for a blown fuse. The pico fuses look like a small yellow resistor. Some Hitachi's are famous for having a blown hi-volt ceramic capacitor and a blown pico fuse.
I think the red led on is a short protect indicator, but I could be mistaken.
Sep 08, 2009 | Hitachi 43FDX15B 43" Rear Projection...
Polaroid FLM-3232.. Has no red led light showing when pluged in.
This may be a liitle more informative to you....if you haven't already read it. This fixed my problem, I had 2 blown caps.
Hope this helps!
djrhemi345
Mar 26, 2009 | Polaroid FLM-3232 Television
TV won't turn on after power outage
LOT OF TIME WHEN YOU LEAVE IT OFF FOR THE NIGHT DISCONNECT POWER CORD DEFECTIVE SURGE PROTECTOR IS NOT GOOD FORE EVER PLUG TV IN THE WALL WITOUT THE SURGE PROTECTOR IF IT GOOD CHANGE THE SURGE PROTECTOR FOR NEW ONE CHEERS
Jan 17, 2008 | Hitachi 60UX54B/55K 60" Rear Projection...
Progressive power up problem
Yeppers. Sounds like the standby power supply has a bad capacitor in it and the regulator Ic is defective. These parts should only be replaced by quilified technician as there is very high voltage inside these sets. Good Luck
Jun 14, 2006 | JVC AV-K29MX1U 29" TV
Televison & Video Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
