Question about Panasonic KX-T7730 Corded Phone
How can I access the caller ID LOG (ie: history, or the last 20 numbers that came in)? I do not currently have an assigned button, so need the steps to do that. I tried assigning "7" and "97" to the CO4 button, but after testing it by calling in with caller ID, when I press the button it reads New: 000 Old: 000 I have confirmed, to the best of my ability, that all of the system programming settings are set to enable call logging, that all stations have access to the log, and so on.
  • 3 Answers
How do i make my phone number visible to my callers when calling from a Vtech phone
Caller ID
If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Call block
If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
Mar 15, 2016 | Vtech V CS6419-2 DECT 6.0 Cordless Phone,...
How do you retrieve the last number called to this phone?
If you have a CiX system with Caller-ID, a Caller-ID "review" or "log" key must be assigned on the set. Also, a CID buffer of (x) calls must be assigned in system programming. Once done, to review calls, press the CID Log key, scroll up and down using the NEXT/PREV soft key. This does not work on the older DK systems.
Dec 16, 2015 | Toshiba DKT2020SD Phone
How to get caller id for missed calls for Panasonic kx-t7730
Panasonic KX-TA624/824 automatic Caller ID logging How to set up automatic Caller ID logging
in the KX-TA624 phone system with KX-T7735 phones. (for dash four and five, and KX-TA824)
System Programming:
  1. In System Program number 900, enable Caller ID for the lines you have Caller ID on. (To get into system programming, press Program * # 1234.)
  2. In System Program number 901, select your own area code and any other area codes that don't have to be dialed when making a call. The area code digits are removed from Caller ID log information so you can return a call without dialing unnecessary digits which would mess up the call.
  3. In System Program number 902, if necessary, indicate the number of digits to be removed, and a particular digit (usually 1) that might have to be added, when returning a local phone call. The default programming is to remove the first three digits, and add nothing; which is correct for most locations.
  4. In System Program 903, if necessary, indicate the number of digits to be removed, and up to 4 digits that might have to be added, when returning a long distance phone call. The default programming is to not remove any digits, and add a 1; which is correct for most locations.
  5. In System Program number 909, enable Call Log Assignment for each phone where you want to log Caller ID information. You can use * to indicate you want logging at all phones.
  6. Get out of system programming. (Press Hold or End, then Program.)
Phone Programming:
  1. Program a button for Caller ID Indication on each phone where you want to log Caller ID information. Press Program, then the button you want to use for Caller ID Indication (we recommend the top button in the left column), then 96, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 6 instead of 96.)
  2. At each phone where you want to log all calls, press intercom, then 7382#.
User Tips:
  • The Caller ID Indication button will light up only when the system has logged UN-answered calls.
  • Use the Navigator Key at the lower right corner of the phone to scroll through Caller ID information.
  • You can erase the entire Caller ID log by pressing Intercom, then 70**#
  • You can erase an individual Caller ID record by pressing Transfer while the information is displayed.
  • If your phone does not have a Navigator Key, you can program an available button for Caller ID Selection. Press Program, then the button you want to use for Caller ID Selection, then 97, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 7 instead of 97.)
  • To call a number displayed on the Caller ID log, pick up the handset or press the speakerphone button, and press the Caller ID Indication button.
Jul 01, 2015 | Panasonic KX-T7730 Corded Phone
Toshiba call history set up
You need to setup a caller id button on one of your flex buttoms enable call history a custom service and setup number of call history number in station assignments.
Mar 24, 2014 | Toshiba DKT3020SD Corded Phone
The caller id is working but how to look back the last caller id number(or caller id log) on the KX-T7731, i am using it with the KX-TA824 system.
System pool is 300 numbers, personal is 20. There are logging and overwrite options in Maintenance programming 9.3 or system program 737 and 738. Then you program buttons for CID-Select and CID-Indication for either personal, system or both. (2 buttons per feature).
Carl
Sep 08, 2011 | Panasonic KX-T7731 Corded Phone
We have a KX-T7630 Panasonic phone system and we need to attach a caller id that diplays at least 20 calls; are they all compatible or do I need to buy a specific one?
It doesn't work that way. First of all, you install a caller-id card in your system, then the installer programs a call log button on a phone. This can log all calls into an ICD group and you get a maximum of 100 records per ICD group and a minimum of 480 records per system in a TDA-50. Those numbers change for ICD groups and increase on a TDA/TDE 100 or larger system.
Unless you understand and have access to system programming, it's a dealer program function.
Carl
Nov 13, 2010 | Panasonic KX-T7630 Corded Phone
I have caller id on my avaya phone but I don't know how to find the call log. How do I access the call log for caller id?
You need to do Admin programming to tell the system to log the calls (#317 & #318)
Then you need to put a log button on a lighted button (Feature 23)
Jun 25, 2010 | Avaya Eurostyle 18D Corded Phone
How do I set up a phone to display caller id? It displays on other phones in the office but not on mine.
To set up call id you need to enter programming2.gif . Programming is done on M7310, M7324, and T7316 sets only. Press the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program call log on. Press the show key (top right arrow)
Press the next key (bottom right arrow) 5 times. The display should say TELCO FEATURES.
Press the show key (top right arrow) 2 times. The display should say CALLED ID: N(or Y)Press the change key til it says Y.
press the release key.
May 03, 2010 | NorStar T7316E Telephone
Turn off caller id
Unfortunatly the only way to do it is to take line access off that phone and have a button call pickup to access ringing line. In this scenario extension wont ring Reffer to programming manual on support/avaya.com Cheers
Jun 10, 2009 | Avaya Corded Phone avaparp18d
How do I view caller ID?
The KX-T7731 is a proprietary system phone. You have a Panasonic phone system. Caller ID is transmitted between the first and second ring but the phone system itself is the only part that gets this information. The system has to be compatible for caller ID and it has to collect the caller ID data and send this information to your phone(s). Your phone can be used on many different Panasonic phone systems. The phone's part number does not help you. First thing you need to do is find out what system you have and if it has caller ID. The phone system part number should start with KXT like your phone.
Sep 17, 2007 | Panasonic KX-T7731 Corded Phone
Panasonic KX-T7730 Corded Phone Logo
360 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
