Question about Watches
I have a ehowardclock watch radio controlled with the two push buttons I had the battery changed with out a manual. To get one I need the model number off the back but this watch does not have a number on the back. How do I get it to start running. The second box with numbers is working.
VOTIT
  • 2071 Answers
SOURCE: Tropby radio controlled watch, runs slow, even with new battery
Your watch is need to clean an replaced the old oil in gear shafting that is the common problem of a watch when the old oil is sticky already thats makes the gear moves slowly and your watch is always late . If ever your watch was already clean and replaced new oil and still working slowly then the problem is in the circuit board is near to run out its needs to replaced whole circuit board so its better again. I know this because im a technician in Rolex service center before. Feel free to ask whatever the result.
Hope it may help you;
Regards;
VOTIT
Posted on Jan 30, 2009
  • 61 Answers
SOURCE: how to open the back of a wrist watch to change
Identify first if it is a "screw on back" or a "pop off" back. Screw on backs have multiple indentions on the caseback where a special tool fits in the grooves to twist it on and off. If it is a screw type back then you will either need to buy a pricey caseback wrench or take it to a jewelry store that changes watch batteries.
A pop off back will have a smooth caseback with no indentions on it.
Most of these are "pop off" backs. to pop the back off get a very sharp blade and apply pressure at about a 30degree angle between the case and the caseback on the underside of your watch. From there you should be able to pry it and it should pop right off. Another way is to put a razorblade between the case and caseback, tap the blade with a small hammer (lightly!) and then pry the back off.
Posted on Oct 19, 2009
Testimonial: "thanks so much for the info!!!! you helped me alot!!! moon444"
  • 55 Answers
SOURCE: Need battery model number
the size cell that goes in this watch is a 395...good luck :)
Posted on Nov 18, 2009
SOURCE: I have a Carne & Viceroy Radio Controlled Watch reset time
I went to How To Mend It Site and I fixed the watch in ten minutes and it was free I expected fast response from you because of the charge.
Posted on Dec 20, 2009
SOURCE: need to change time and cant find manual
Posted on Jan 06, 2010
Klik radio controlled watch
Why would he need the manual to do that ???
The time is self setting !
and to chage the battery just take out the back cover and slide the pin holding the battery in place, and replace it with the with similar battery...
I will try to find the manual for you..
post back in a second
Jan 09, 2008 | Watches
Tip
HOW DO I SET MY DIGITAL -- (PUSH BUTTON) -- WATCH
mcdevito75 here, The Quartz Mechanism is made in such a way, that the battery"s electricity changes in a way, while going thru the Quartz and thus Display"s the Numbers and or Letters on the Dial or Display, By PRESSING these Various Buttons, you are Changeing the Battery"s Voltage thru the Quartz and thus Displaying the Numbers and or Letters. ---------- Genarally, you need worry about only TWO (2) of these Buttons to SET your DIGITAL (push button) Watch, They are the MODE and SET Buttons. ------------- The MODE Button is usually on the Right side of the caseing, PRESS this Button, depending on your watch you may have to hold down this MODE Button 2--3 seconds, once you see the Dial Or Display BLINKING you are set to RE--SET your watch, NOW, PRESS the SET Button, usually on the LEFT side of the caseing to change each Function (Hour, Minute Etc.) once each Function is SET, PRESS the MODE Button to move onto the next Function. ------ Once all the Functions are SET, PRESS MODE again to see a STEADY Display or Dial. ---- It May take a little practice so be patient. ------ Some DIGITAL watches may not have a MODE BUTTON, But Rather a DIMPLE on the watch caseing you would PUSH in with a PIN or Tooth Pick, same MODE and SET procedures would apply. --------- Use your watches name plus .com online to obtain a user manual or look for a small watch repair shop in your area to order a NEW owners manual for your watch.
on Jul 10, 2010 | Watches
Watch tells wrong time however many times io reset
Best thing you can do is download the instruction sheet from braun-clocks.com. Go to bottom left of page and click on Manuals search, then enter your watch model number in the box.
You need to calibrate the hands, particularly if you've changed the battery. Read the instruction carefully, it's a bit involved but it will solve your problem.
Jan 20, 2014 | Braun bn0087 radio controlled black...
How do I adjust the time zone on my E.Howard atomic watch? The T2 button doesn't activate anything when it's pushed?
No, just set properly. This watch is very difficult to set. A watchmaker may be able to help you. The instructions are not very clear. You might try a watchmaker for assistance or try calling them although I have not had much luck along those lines.
Dec 28, 2011 | La Crosse Technology E. Howard Ambassador...
Need a manual/ instructions for auriol 2-LD2970-4 radio controlled watch
Go to
http://www.2instructions.com/search.php?cmarque=AURIOL&modele=RADIO%20CONTROLLED%20WATCH%202-LD2970-4
Jan 27, 2011 | Bulova Watch
How to set time on my National Geographic Dakota Atomic Watch?
For the national geographic radio controled watch.
The easiest way to rest this watch is to remove the battery.
Once replaced the watch will flash set to 12. Push and hold the upper button till the hands spin. Press this button again to stop the hands. Tapping the upper button will make the hands move forword 1 sec. Set all the hands to 12. becareful, if you pass 12 you will have to go around again. to start the hands spinning again press and hold the upper button untill the hands move. Once all the hands are at 12, press the lower button and the screen should flas LON for london. Set the city code using the upper button to your area. press the lower button hard to confirm the information. The watch should set itself to the correct time. If it starts running from 12, place it on the window sill for the night so that it can get a signal.
Mar 08, 2009 | Dakota Watch Company Radio Controlled...
My watch hands don't move
The best way is to go back to the shop and ask for users manual or ask to set the watch.
If you still need any further advice- upload watch model, number, all the details e.t.c.
Dec 20, 2008 | Watches
LA CROSSE RADIO CONTROLLED WATCH
How do I reset watch after changing battery?
Sep 10, 2008 | La Crosse Radio Controlled Watch
Set date & time on radio-controlled Timex
Hold down the split/reset button until the flashing tower icon stops flashing then release the button. The watch will automatically receive the next scheduled radio update.
Apr 22, 2008 | Timex 27191 Wristwatch
Watches Logo
187 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
