Question about Compaq Presario CQ60-220US PC Laptop
My screen wont display anything and i wanna bring it up on my desktop computer monitor. how can i do that?
    Sergeant:
  • 296 Answers
Buy a VGA cable and connect it to the monitor. Then power the laptop up.
Posted on Mar 23, 2011
How do i manually switch my screen back to laptop after switching to another monitor ?
If your using a windows computer like Windows Vista, 7, or 8. Right click on your desktop and click screen resolution. It'll bring up monitor properties, you can click the other monitor plugged into your computer and set it as the default. If your graphics card supports it you could even click to extend displays and use both at same time, moving your mouse past edge of one of sides of your screen to move to other display.
Aug 15, 2014 | Sony VAIO Computers & Internet
When i turn the monitor on it just comes up black screen,and it wont go to menu or anything
-remove it from your computer -if you do have a spare desktop computer plug it to see if it will do the same thing -if same thing happens LCD needs to be replaced - if you will get a display from a 2nd desktop computer / There's something wrong with the RAM/VIDEO CARD of the 1st computer.
Dec 30, 2010 | Acer 22" X223w LCD Monitor
Hi, Just setting up this monitor with a new desktop computer. Message is coming up on the monitor 'Input signal out of range'. What does this mean and how can it be fixed? Best wishes, Giovanni.
It could be either your 'display setting' is not set right or the 'Screen Refresh Rate' is more than what your monitor can handle.
To solve this:
Step 1: Open your 'Display Settings' either by right clicking on the desktop or by opening up your control panel.
Step 2: Bring down the resolution to '1024 by 768 pixels'
Step 3: Press 'Apply'
If this did not solved the issue go to the next step
Step 4: Click on the 'Advance Settings' button
Step 5: Click on the 'Monitor' tab and bring down the 'Monitor refresh rate' to a 60 or 75 Hertz
This should fix your problem.
Mar 07, 2010 | Microsoft HannsG HU171D 17" LCD Monitor
My newer flat screen monitor went black but works fine when hooked up to another computer and I have an older monitor that I hooked up and the older one works fine...??
That sounds like a display/resolution setting problem on your PC. I doubt there is anything actually wrong with the PC or the monitor, since both work with different combinations, so its most likely just a setting.
Some monitors don't display anything when they get a signal/resolution that is not compatible with their displays. I would try changing the display settings on your computer with your old monitor, then switch monitors and see if your newer monitor works.
Here's how to adjust the display resolution:
If in XP, right-click on the desktop and go to Properties, and select the tab for display settings and adjust/lower the resolution. If in Vista/Win7 right-click the desktop and select Screen Resolution/Display Settings and adjust it there.
Feb 15, 2010 | Rosewill R900J 19" Flat Panel LCD Monitor
I have a new HannSpree 25''/HF257 monitor and my desktop image is wider than the screen. How do I bring all images into the viewing area?
CTRL PANEL...Display(XP) or ( personalize )(Vista) select a display higher than 1024x768
please rate our help++++Thanks for using FIXYA
Sep 23, 2009 | Computers & Internet
My samsung 923 nw wont display anything!!
check to see if you get image when lowering the resolution, do this with yoru older monitor try to bring it to a basic 800x600 with 16 bit color depth. then switch monitors and see what happens. If this monitor is energy efficient you may want to check on the power savings settings for your computer.
Jun 01, 2009 | Computers & Internet
My computer dont have a display
if its a desktop, run monitor self test, unplug cable of monitor from back of pc, turn on both monitor and computer, if nothing on screen. monitor needs to be replaced., if its laptop, tkae out battery and unplug ac , press and hld power button for 5 seconds to drain power, put battery back and power on system then immidiately press f2, if it brings to you a different screen, good. but if not. display is not working , the hardware part.
Jan 14, 2009 | Computers & Internet
My computer monitor has somehow turned its brightness all the way down, possibly due to me choosing a new screensaver which was already installed on my computer. Sadly, my monitor, an Emprex LM-1704...
Find yourself a dark room or wait for the night to come. The darkest monitor adjustment could somehow reveal some light when there are no other light source available.
You may also hook a conventional CRT monitor and make your changes (such as bringing your computer back to its original settings). The darkest adjustment in CRT monitor could still render discernible displays.
Sep 09, 2008 | Computers & Internet
Computer will not load anything
Turning you rmonitor on then your comp my monitor has a delay and if i dont turn it on before i turn my comp on or before i here the little beep noise my comp makes the monitor wont display anything.
Jul 14, 2008 | Systemax AOL Optimized PC (100607) PC...
Blank Screen
Can you see anything at on but dimly? If so thats is the backlight tube If you cannot see anything then it is a major fault eitherway a repair shop job I should think
May 30, 2007 | HP L1902 19" LCD Monitor
Compaq Presario CQ60-220US PC Laptop Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
