Question about Amcor Waterless Vaporizer Air Purifier
I am a canadian and cannot buy any refills for the waterless vaporizer.
    Sergeant:
  • 296 Answers
Move to the US.
Posted on Mar 23, 2011
SOURCE:
25hp kohler hot start problem. Replaced fuel filter, plugs and cleaned air filter - same problem. it won'd restart when hot.
3 possibles come to mind
fuel vaporization in the line to the carby or in the carby bowl (check float level adjustment)
valves are being held open when hot--- valve stem lengths increase reducing tappet clearance___adjust valves when hot
check coil/ ignition module for failure when hot as they can open circuit ./ short circuit when internal components fail from heat
Sep 27, 2016 | Kohler Command V-Twin Horizontal Engine...
I have asked question 4 times ..provided my email..and yr site reply says for 9.99 yr question will be answered..nice thanks for nothing
Hi Monica:
Most large companies tend to like to keep their customers satisfied.
Fixya is intended to help people determine how to solve problems.
It seems to me that your problem is with a specific product, and since you bought it new, it would seem appropriate that you contact the CUSTOMER SERVICE DEPARTMENT of the store where you bought the product.
You could also contact Proctor & Gamble directly, but I would suggest that you only do that if you do not get satisfaction from the store where you made your purchase.
One last suggestion, try to be as pleasant as possible when dealing with anyone involved. Record the dates, times, and nature of your requests and discussions. Service people get to listen to complaints all the time, and they usually react well to a pleasant discussion.
Keep Smiling!
Cheers.
Jan 05, 2016 | Procter & Gamble 4 Pack-swiffer Wet Jet...
Rapping noise from engine after running low of oil
That's a bad sign.You probally damaged the engine.Have a shop check it out.
Feb 03, 2015 | EBC Brakes 2004 Ford Focus - Wagon, 2.0L...
Red light will not go out
Have you tried changing the batteries?
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Aug 24, 2013 | Air Wick® freshmatic refill,...
I have 2 and they smell bad. You have a bad reputation and I am going to return them to Canadian Tire if the odor problem is not resolved in the next 48 hours.
Stan, unfortunately what you're saying is not to Oreck, the manufacturer. This site is designed to help you determine what the problem is and hopefully, how to solve or repair the problem. But, not be threatened by what you want to do with your Oreck Air Purifier. Save that for Oreck.
With that said, I would have to ask you, when was the last time you cleaned or changed the filters on the air purifiers? I suspect that may be problem.
Mar 21, 2011 | Oreck (AIRCOM1BOI) Air Purifier
Is rainmate good for sinus problems
If you are having issues associated with dry sinus, and it is cold where you are located (with heating unit running), then yes, a humidifier will increase the relative humidity of the air and possibly decrease the issues you have with dry sinus, regardless of manufacturer.
You need to look for a humidifier that provides for a decent humidification rate, in terms of gallons per hour. The higher, the better. And, with that, you want a decent water tank storage amount, or you will be refilling all the time (the smaller the tank, the more often you have to refill.).
Also look for a humidity control, but don't pay a lot for it. The more humid the air, the harder it is for more water to evaporate into it. You would really like around 50%-60% RH in your home.
Dec 13, 2009 | Rainbow Rainmate Air Purifier
I have a lc1060 where do you put the vicks and the water at... Can you please Help me
What you have is an "air purifyer ionizer", not a humidifyer. humidifyers warm up and some people like to use vicks vapor rub. But you don't own one of those. So no you would be able to do that with this machine.
Jan 29, 2009 | Bionaire LC1060 Air Purifier
Got Rainmate yesterday and either my house is REALLY clean or it isn't working
i had the same problem. The goo pulled from the air gums up the small orifice atthe bottom of the stem that sticks down into the water. If the water cannot be pulled up into the stem and expelled out towards the bowl at high speed, it cannot work. Take the upper, motor half off, unplug it hold the plate with one hand and twist the stem 1/4 turn and it comes right off. Clean the crud (yes, its your own skin cells) and the hole with warm water and soap. put it back together and refill with water and it works like new. this is now monthly maintenance for me
HTH
May 16, 2008 | Rainbow Rainmate Air Purifier
Finding replacement filters
http://www.totalvac.com/HAPF600.html?zmam=6843742&zmas=1&zmac=6&zmap=HAPF600
You can actually use the size B....made by Holmes...Also C for the carbon filters
Oct 22, 2007 | GE HEPA 106653 Air Purifier
Amcor Waterless Vaporizer Air Purifier Logo
52 people viewed this question
Top Amcor Air Purifiers Experts
Marvin
Marvin
Michael Youngman
Michael Youngman
Are you an Amcor Air Purifier Expert? Answer questions, earn points and help others
