Remote does not respond to cable box. - Audio Players & Recorders
    Sergeant:
  • 296 Answers
Remote don't respond to anything but your finger pressing buttons.
Posted on Mar 23, 2011
I use a RCA remote to programe my cable box but my samsung tv get programe instead of the cable box.and now my samsung tv goes on and off. What's wrong?
The TV and the cable box are responding to the same code. You likely will have to find different codes for one or the other.
Jan 17, 2016 | RCA Televison & Video
I need the exact location of the IR sensor on the front panel of a Motorola DCH6416 cable box.
Do this like mine sweeping. Grab the remote and put it right up to the front of the box. Press the channel up or down keys as you move the remote across the front of the box. You'll get to a point where the box responds well. Then as you go past the point the box will stop reacting so well. Home in to the point where the box responds well. That's your point for the blaster.
Sep 14, 2014 | Arris Dch6416 Dual Tuner Hdtv Dvr Hdmi...
I need codes for my cable box its a moterola cable box from shaw in winnipeg manitoba my name is justin ledoux could you send me some codes pleaz
Sorry it took so long to respond to your request for assistance.[Motorola... 5000, 5002, 5003, 5028] These are the listed codes for your remote control to use with a Motorola cable box. I hope this information solves your problem, of needing the codes to use with the remote control and you Motorola cable box. Thank you for using FixYa and have a nice day!
Feb 10, 2009 | RCA 3-Device Universal Remote with...
Code list forToshiba television is ineffectual
You tried all of the following codes?
018,021,023,071,085,090
Doing as follows
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Try this if so
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Jan 08, 2009 | RCA RCR311B Remote Control
I have a 2004 Toshiba color TV 27".
simply look up the codes or contact your cable company for the toshiba tv codes to input into the cable remote. you may also be able to operate the cable box via the TV remote if the correct codes from the tv owners manual are entered.
Nov 25, 2008 | Toshiba 27A33 27" TV
RCA Universal Remote set to my Emerson TV
RCA Universal Remote Control Programming Codes Programming Your Universal Remote.
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Emerson CODES 011,026,027,028,029,030 031,032,037,042,053,064 065,067,075,076,079
Oct 12, 2008 | RCA 257003 Remote Control
My Sharp Aquos TV has stopped responding to remote control(s)
Unplugging my TV for 15 seconds (longer actually - at least a minute) made the remote and the satellite TV remote both work again with the TV.  Thanks for the tip!
May 14, 2008 | Televison & Video
Remote control sensor doesn't work when the room is dark.
its probably the led in the remoter, check with a camera on a phone point the camera at the remote if its dim, that's the problem, it could also be a damaged battery in the remote.
Jun 18, 2017 | Televison & Video
Universal remote
Codes for Samsung (one of them should work on your RCA remote)
006,011,014,015,019,027,036,037,077
  • TV-000
  • VCR-000
  • Cable Box-000
Apr 07, 2008 | RCA Universal Remote 3 Device Remote...
15 people viewed this question
 Grubhead
Grubhead
