Question about Emerson Em1200 Answering Machine
Hangs up after 2 seconds into recording message
  • 2 more comments
  • monkies8it Dec 26, 2008
    It is not a matter of how many rings til it picks up. The machine picks up correctly, then plays the greeting correctly, then beeps correctly, the incoming message is recorded correctly for about 2 seconds then the machine hangs up on the caller. Thus, when checking new messages, instead of "Hi, it's mom. I was going to be there at 6 o'clock with the check and the medicine." I hear "Hi, it's mom I w...*click*" "click" being the sound of the answering machine hanging up and not recording the rest of the message. Changing the number of rings doesn't affect this, it hangs up on callers irrespective of how many times it rang.
  • Winterfur Dec 31, 2008
    Machine hangs up after two seconds of message. I tried resetting the rings
    before answering [ 2 rings [ --- I tried unplugging the power for 10 seconds ---
    neither of these fixed the problem.
  • SGTBERGER Jan 31, 2009
    THE QUESTION ABOUT WHAY YOU COULD NOT LEAVE
    A MESSAGE NO LONGER THAN 2 SECONDS, WAS DODGED.
    It was not how to set the rings, it was to set the lenght of time someone could leave a message. Please get it right or stop ripping people off with a product that dose not work.
  • momagain3 Feb 08, 2009
    phone rings...answering machine picks up...plays greeting...beeps...cuts caller off after 2 seconds of recording...how do I fix this?
SETTING THE RINGS TO ANSWER
This setting allows you to select the number of rings before the answering system answers a call.
At idle status, hold down the volume "UP" button over two seconds to enter the ring times setting of answering. The answering system announces, "ring time two" (the default is 2).
To change the rings to answer, press and release the "PREVIOUS" button (<<) or the "NEXT" button (>>) and the answering system announces a number such as "2, 1, toll save, 9...” OR "2, 3, 4...", if you select the toll save and the digit LED light shows a “γ”, the answering system announces “toll save”.
After choosing a number, press the “PLAY/STOP” button one time to store the rings to answer, and the answering system confirms the setting and returns to the idle status.
NOTE: when the machine fails to operate properly, just unplug the power for 10 seconds, and redo the settings.
Posted on Dec 02, 2008
We don't know how to retrieve out messages from outside the house.
To play back messages remotely, first you'll need to have set up your two-digit security code (PIN). You can download a copy of the manual here which gives all the details. Once you've done that, here's how to use the system:
1) Call your telephone number and wait for the system to answer. If the answering system is off, it will answer after about 10 rings and sounds a series of beeps.
2) During the greeting message (or a series of beeps when the answering system is off), press 0 and enter your PIN code within 2 seconds. The answering system announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero." You will hear a beep.
3) Enter a command within 15 seconds. Each command thereafter must be entered within 2 seconds. These are the available commands:
  • 0 then 1 Repeat a Message*
  • 0 then 2 Playing incoming Messages
  • 0 then 3 Skipping a Message
  • 0 then 4 Deleting a Message
  • 0 then 5 Stop Operation
  • 0 then 6 Answering System On
  • 0 then 7 Memo Record/Stop**
  • 0 then 8 Greeting Message Record/Stop**
  • 0 then 9 Answer System Off
  • 1 then 0 Help
* For the Repeat a Message function, press 0 then 1 within about four seconds to repeat the previous message, or press 0 then 1 after about four seconds to repeat the current message.
**For the Memo Record and Greeting Message Record function, the first time you enter the corresponding command, it starts the Recording function. If you want to stop the recording, press 0 then 7, 8 or 5.
4) After the command has finished, you hear intermittent beeps indicating that the system is in the command waiting mode. You may enter another command at this time from the chart above.
5) Hang up when you're done.
Jul 05, 2011 | Uniden TRU8885 Digital Answering Machine
Can I check my messages from a phone outside my home, is it possible to make a remote enquiry? And if so, how does it work?Thanks in advance for your answer. Regards, Joy
Remote Message Retrieval
You can operate your answering system from a remote location using any touch-tone
telephone or the handset.
Remote access away from home
You can check, play, or delete messages, even record a new greeting message when
you are away from home. Additionally, you can turn On or Off your answering system
from a remote location.
Remote access:
press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code" in your owners manual.
3) The answering system announces the current time and the number of messages stored
in memory. You hear "To play incoming messages, press zero-two. For help, press onezero".
4) Enter a command within 15 seconds, each command there after must be entered
within 2 seconds. You may select a command from the following chart:
For your convenience
a remote operation
card is provided for
you to use while
away from home, it can be found in the back of your owners manual.
Command Function
0 then 7 Memo Record/Stop **
0 then 8 Greeting Message Record/Stop **
1 then 0 Help Guidance
Command Function
* For Repeat a Message function, press 0 then 1 within about four seconds to
** For Memo Record and Greeting Message Record function, the first time you enter
the recording, press 0 then 7 or 8.
5) After the command has finished, you hear intermittent beeps indicating that the
6) When you are finished, hang up to exit the system. The answering system
automatically returns to standby.
Your machine automatically has a PIN set of 80.
If you are trying to use remote access from a cellular phone and having trouble: Try changing your tone length on your cell phone to long.
May 25, 2011 | Uniden Cordless Phone
Code to retrieve messages
Here are the instructions you need to follow:
If you want to be able to play your messages from a remote location, you need to enter a two-digit Personal Identification Number (PIN) code (01-99).
To select a PIN, perform the following steps:
1) With the phone in standby, press [menu/clock] twice.
The system announces "Security code," and the current PIN code is announced as it is displayed on the base.
Then the system announces the instructions for setting the PIN code.
2) Press [volume/select/ ] or [volume/select/ ] until the desired number appears.
3) Press [set] to select the PIN code. You hear a confirmation tone, then the announcement "Security code" followed by the new PIN code is announced. After a few seconds, the system announces "To set ring time, press menu again."
Note: The PIN code is set to "80" at the factory.
Remote Operation
When you are away from home, you can operate your answering machine with any touch-tone telephone. Use this function to check for recorded messages, to play or delete messages, even record a new greeting message.
1) Call your telephone number.
2) During the greeting message, press [0] and enter your PIN code
3) The answering machine announces the current time and the number of messages stored in memory. Then you hear "To play incoming message, press zero two. For help, press one zero."
4) You may continue to listen to the voice prompts, or you may select a command from the following chart:
Command Function Command Function
[0] then [1] Repeat a Message [0] then [6] Answering Machine On
[0] then [2] Play Incoming Messages [0] then [7] Memo Record/Stop*
[0] then [3] Skip a Message [0] then [8] Greeting Message Record/Stop*
[0] then [4] Delete a Message [0] then [9] Answering Machine Off
[0] then [5] Stop Operation [1] then [0] Voice Prompts
* For Memo Record and Greeting Message Record functions, the first time you enter the corresponding command, it
starts the Recording function. If you want to stop the recording, enter the command again.
Note: Once you enter the remote access menu, you must enter a command within 15 seconds, or the
answering machine automatically hangs up and returns to standby.
5) After all of the voice prompts have been played, you hear intermittent beeps indicating that the system is in the
command waiting mode. You may enter another command at this time from the chart.
6) When you are finished, hang up to exit the system. The answering machine automatically returns to standby.
Turn on the Answering Machine Remotely
If you have forgotten to turn on your answering machine, you can turn it on remotely from any touch-tone telephone.
2) Wait ten rings until the system answers. You hear intermittent beeps.
3) Press [0] and then enter your PIN code. The answering machine announces the number of messages stored in memory. You hear "To play incoming message, press zero two. For help, press one zero."
4) Press [0] then [6] to turn the answering machine On. You hear the outgoing message and a confirmation tone.
5) Hang up the phone; subsequent calls will be answered by the system.
Feb 28, 2010 | Uniden EXAI5680 Cordless Phone
Answering system records message after hang up
One thing to try and take note of is when the message does pick up on the "two ring" message present part do you hear on your side two full rings before the pick up?
It may be that the primary ring starts on the home side as does happen sometimes with VOIP service. If you are only hearing 1 or 1 1/2 rings before the message picks up then you might try hanging up after the second full ring thus knowing no messages are present and it should overcome your problem.
Dec 12, 2009 | Uniden Cordless Phone
Retrieving messages over phone
when your greeting answers, punch in your code, usually a 4 digit code, each manufacturer has their own default code that it comes with.. check the manual or website
Apr 14, 2009 | Lands Phones
How to access messages remotely
While you are away from your home or
office, you can use a touch-tone phone,
or a pulse (rotary) phone with a pocket
tone dialer (available through your local
RadioShack store) to enter your PIN and
do any of the following:
• set the phone to answer or not
answer calls
• listen to your messages
• record a new outgoing message
• erase messages
• monitor the room where the phone
is located
Notes:
• You cannot remotely operate the
phone using its handset or another
telephone on the same line as the
phone.
• You can also listen to the message
recorded on Line 2 by making a call
to Line 1’s number (or vice versa).
USING THE TOLL-SAVER
If RING TIME is set to TS (toll-saver),
(see “Setting the Number of Rings” on
Page 15), the phone answers after three
rings if you have new messages (ones
you have not listened to). If there are no
new messages, the phone answers after
five rings. This gives you time to hang
up before the phone answers so you
can avoid unnecessary long-distance
charges.
Note: Toll-saver works only on the line
you called. If Line 1 has no new messages,
but Line 2 has one, the telephone
answers after five rings when you
call Line 1.
USING REMOTE
COMMANDS
Follow these steps to operate the phone
Note: If you wait more than 15 seconds
between keypresses, the phone sounds
a long beep and hangs up.
1. Dial your phone number and wait for
the phone to answer.
2. If the phone is not set to answer
calls, it answers after about 10 rings
3. When the outgoing message begins
(or the phone sounds a series of
beeps), press #, then enter your PIN
within 2 seconds.
If the PIN is correct, the phone announces
the day and time, then it announces
the number of new and old messages.
The phone plays all new messages,
then beeps about every two seconds to
let you know it is ready to accept remote
commands.
Notes:
• If the phone does not respond, try
entering your PIN again. If you enter
an incorrect PIN three times, the
phone beeps and hangs up.
Remote Operation 27
• When the phone is operating from a remote location, it stops all answering functions
and rC appears on the display on the base. The phone resumes answering
functions when it is no longer in remote operation, if you have not turned it off.
• The remote playback of incoming messages is limited to 4 minutes. If you have
more messages after 4 minutes have passed, you must press # 2 again to listen
to the rest of the messages.
• When using remote operation, you can only delete the current message during
playback. You cannot delete all the messages stored at one time.
The following table shows the remote commands you can use.
Note: Remote operation stops when someone picks up the handset and presses either
LINE 1 or LINE 2 (whichever is flashing), or any phone on the same phone line.
Remote Commands
Press #
then (within
2 seconds:
Function
Repeat current message during playback.
2 Play messages.
3 Skip current message during playback.
4 Delete current message during playback.
5 Stop playback, recording, and room monitoring.
6 Set the phone to answer or not answer calls.
7 Record or stop recording a new outgoing message.
8 Play the outgoing message.
9 Switch to the other line (Line 1 or Line 2).
0 Monitor the room where the phone is located for 15 seconds
Mar 19, 2009 | Lands Phones
ANSWERING A CALL AND NON FUNCTIONING ANSWERING SYSTEM
no make or model listed
on many phones there is an ability that when the phone is picked up it is automatically connected to the caller and pressing the answer button is the same as hanging up
as for you second point , if a caller rings but hangs up before the message beep or after the beep but hangs up , there will be no message recorded
Nov 15, 2017 | General Electric 29115AE1 1.9 GHz 1-Line...
Checking voice mail remotely
This may be a little late, you are probably home already, but here it is anyhow:
Remote Operation
You can check, play, or delete messages, even record a new greeting message from a remote
location (when you are away from home, or from another room using a handset).
Additionally, you can turn On or Off your answering system remotely.
press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code" on page 25
or 54).
3) The answering system announces the current time and the number of messages stored in
memory. You hear "To play incoming messages, press zero-two. For help, press one-zero".
4) Enter a command within 15 seconds, each command there after must be entered within 2
0 then 1 Repeat a Message* 0 then 6 Answering System On
0 then 2 Playing incoming Messages 0 then 7 Memo Record/Stop**
0 then 3 Skipping a Message 0 then 8 Greeting Message Record/Stop**
0 then 4 Deleting a Message 0 then 9 Answer System Off
0 then 5 Stop Operation 1 then 0 Help Guidance
* For Repeat a Message function, press 0 then 1 within about four seconds to repeat
current message.
** For Memo Record and Greeting Message Record function, the first time you enter the
5) After the command has finished, you hear intermittent beeps indicating that the system
chart above.
6) When you are finished, hang up to exit the system. The answering system automatically
returns to standby.
Dec 29, 2007 | Uniden DCT648-3 Cordless Phone
Uniden answering machine model 900MHZ
Here is a link to the pdf format owners manual from Uniden for this phone:
http://www.uniden.com/pdf/TRU8885om.pdf
Remote Operation
remote location (when you are away from home, or from another room using a
handset). Additionally, you can turn on or off your answering system remotely.
You can operate your answering system from a remote location using any touchtone
telephone.
off), press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code"
on page 25).
**For the Memo Record and Greeting Message Record functions, the first time you
enter the corresponding command, the phone starts recording. If you want to
Oct 23, 2007 | Uniden TRU8885 Digital Answering Machine
SW Bell FA-980 Answering Machine
Here is a link to a similar model: http://www.swbfreedomphone.com/ib/ibansw/fa970.pdf Here is what it says: TONE REMOTE OPERATION Remote Security Code To access answering functions from an outside line, you will need to enter the three digit security code located on the bottom of your unit. Write this number on the Remote Access Card, which you can keep in your wallet. Remote Turn On If you forget to turn on your unit: 1. Call your unit from a touch-tone phone. 2. Wait 12-14 rings until the machine answers. 3. The FA970 will automatically answer by playing your greeting. You may hang up the phone, and subsequent calls will be answered. Remote Message Playback 1. Call your unit from a touch-tone telephone. 2. After your FA970 answers, it plays the outgoing greeting and beeps once. Dial your three digit security code within 20 seconds after the beep, pressing and holding each digit for 1-2 seconds. Allow a 2 seconds interval between each digit. 3. Your FA970 will sound one beep to indicate the code was entered correctly. (If there are no beeps, enter your code again.) 4. You can press the following buttons on your keypad: Option Press Playback Mailbox 1 Messages (1) Playback Mailbox 2 Messages (2) Record Memo Message (3) Record New Greeting (8) Turn Off Answer Mode (9) If you press ?1? or ?2? (to playback messages), you have the follow options: Option Press Erase Current Message (0) Repeat Current Message (4) Repeat Previous Message (4) repeatedly Stop Message Playback (5) Skip to Next Message (6) To SAVE messages, hang up the telephone. Note: Your FA970 will sound a series of beeps if there are no messages. Remote Record New Greeting If you press 8 (to record new greeting): 1. When you hear a beep, begin recording your new greeting (up to 30 seconds). 2. When you have finished recording your new greeting, press (5). The unit will beep, and the new greeting will playback to you. 3. Hang up the telephone. Remote Record Memo If you press 3 (to record memo message): 1. Within three seconds of pressing ?3?, press ?1? or ?2? to select Mailbox 1 or Mailbox 2. Otherwise, the memo will be recorded in Mailbox 1. 2. When you hear a beep, begin recording your memo (up to 60 seconds). 3. When you have finished recording your memo message, press (5). 4. The corresponding Mailbox message count will be increased by one. To Retrieve Messages when Recording Memory is Full 1. When the message capacity is full, the unit will sound 3 beeps after answering the phone. 2. Within 20 seconds after the 3 beeps, dial your 3 digit security code. 3. Your FA970 will sound one beep to indicate the code was entered correctly.
Mar 22, 2007 | Southwestern Bell FA970SN Digital...
Emerson Em1200 Answering Machine Logo
399 people viewed this question
Top Emerson Lands Phones Experts
Computer Repairing
Computer Repairing
David Burbee
David Burbee
Are you an Emerson Lands Phone Expert? Answer questions, earn points and help others
