Question about Royal 85X Shredder
Royal 85x paper shredder: The shredder will start to shred but stops shortly after "grabbing" the paper. In order to get it shredding again, I have to put the machine in reverse, remove the paper and try refeeding the paper. It usually takes several attempts to get the machine working. Once the machine starts, however, it works as it should as long as I keep a continuous feed going. Not sure which part needs cleaned/replaced. Please help. Thank you!
  • 52 Answers
Sometimes spraying shredder oil on the cutting teeth wil work.
You should shred paper with a light weight machine oil poured on the paper to keep the cutting teeth working freely.
Good luck.
P.S. If this doesn't work then just take the head off and cleanj/lubricate any bearings you find.
Posted on Mar 23, 2011
Royal shredder high pitched motor sound
stripped a gear
junk it and get a new one
Jun 10, 2017 | Royal Office Equipment & Supplies
My royal shredder will shred paper just fine but now it won't shred a credit card. any ideas?
Silly question if it shreds paper fine but....when did you last oil the machine.???
Cross cut shredders need to be regularly oiled..( pour some shredder oil across the cutting blades).
It may just be that the credit card is too thick!
Jan 25, 2011 | Royal 112MX Shredder
Royal 85x crosscut shredder stopped working
Some shredders aren't designed to shred anything more than paper. Credit cards, staples, paper clips and the like could have jammed it up. Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 25, 2010 | Royal 85X Shredder
Royal VF700 won't barely shred one sheet of paper. It givexs the overload red light when 1 sheet of paper has just barely started to be shredded.
Royal. Haven't heard of that brand. Could get in contact with tech service, but it's probably easier to grab a new paper shredder.
May 24, 2010 | Royal VF700 Cross-Cut Shredder
It will not shred - the reverse works fine
UNPLUG THE MACHINE AND TRY CLEANING THE "EYES" WITH A SOFT CLOTH. IF THAT DOSN'T DO IT YOU MAY HAVE DEFECTIVE EYES OR PCB...YOU CAN CALL ROYAL FOR PARTS AT 1-800-524-0799.
May 21, 2010 | Royal 85X Shredder
ROYAL RL170MX Shredder won't shred
Did you ever put shredder oil onto the cutting blades?????
The blades can clog with paper dust and then it can't shred as many papges as it should or even jam completely...you should occasionally shred a sheet of paper with shredder oil poured onto the sheet.
Aug 11, 2009 | Royal 1280MX Shredder
JAMS...DOES IT NEED OIL?
You should occassionally lubricate any x-cut shredder, just put some shredder oil on a sheet of paper ; a big "s" pattern of oil will do then shred the sheet of paper to get the oil down into the cutting shafts.
Aug 07, 2009 | Royal 85X Shredder
Royal VF12mx shredder
Pour some shredder oil in the throat where you normally insert the paper...put some shredder oil directly onto 1 sheet of paper and try shredding 1 sheet. If it wont even shred 1 sheet I would ask is the shredder running???
Mar 05, 2009 | Royal VF1012mx Shredder
Royal 10X confetti shredder
More than likely, there is a lot of paper debris jammed between the cutters and strippers. If you are handy, try the following.
Disconnect the power.
Disassemble the shredder from the lower bin to access the cutting head. Clear the head of all debris with a small screw driver or ice pick. Reassemble and oil the cutters with shredder oil, being careful not to get any oil on the optics. This should solve the sluggish problem. Oil on a regular basis, before every use.
Jan 06, 2009 | Royal 10X Shredder
Royal 85X Shredder Logo
421 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
