Question about Sony Audio Players & Recorders
Sony MP3 player will not power up even after charging all day.
    Sergeant:
    Champion:
  • 285 Answers
If it wont power up after been on charge all day then battery could have gone too flat to be charged, it may be charging but not giving the battery enough.
Posted on Mar 23, 2011
Sony walkman Sony Walkman Bean NW-E305 (512 MB) MP3 Player won`t charge
Good morning, afternoon, evening or night; whatever time of day you are reading this solution post. Thank you for choosing FixYa to assist you with your problem. Your Sony Walkman Bean NW-E305 (512 MB) MP3 Player won't charge properly? Well Danish, we must use a method called troubeshooting to figure out and solve this situation. There are several reasons why this player may not be charging properly. The cause is either coming from the battery inside of your MP3 Player, a bad or faulty USB cable connection, or something (software) isn't installed correctly. Let's look at the first cause- The battery. The battery life may be gone. If it is, you will need to replace it if possible. Your device takes a
Sep 26, 2011 | Sony Walkman Bean NW-E305 MP3 Player
Mp3 player dies after one or two songs even fully
If even affer charging for a long time the battery is draining off you will need to change the battery. Remove cover carefully test and confirm before you replace. attempt only if familiar and to do it carefully.Good day
Jul 03, 2010 | RCA Lyra RD2762 MP3 Player
Formatted NWD - b103f using win7 - power problem
Hi
I am not able to switch on my NWDB103/F mp3 player. Can anybody will help me. I went to Sony service center they have suggested to charge my mp3 for atleast 8 hours. After doing the so still the problem occured.
May 11, 2010 | Sony Walkman Bean NW-E307 MP3 Player
Washed my sony nwz-e436f is it repairable?
I've had good luck recovering cell phones that went in the water. I dismantle them as much as possible and the put them on the dashboard of my car in the sun. In the winter, use any place that gets warm (120-130F) without getting hot (150F+). Leave it there for a day or even two days before you try powering up. A hair dryer is OK, but it is hard to keep that running for hours at a time. Don't charge it until you are sure it's good and dry. Good luck.
Dec 21, 2009 | Sony NWZ-E436F MP3 Player
No power
Make sure that the battery is fully changed. Now, you need to test it to see if there's a problem with the battery or with the power switch.
Charge the player and turn it on while charging. If the player turns on while charging, then there could be a problem with either the battery or the wiring inside.
If the player will not turn on even if it's charging, then it could be the power button or some other components inside the player.
Hope this helps and have a great day!
Aug 12, 2009 | Sony Walkman Video NWZS615F MP3 Player
Fully charge sony walkman NWZ-E436F does not turn on power at all
well u might have gone wrong u should charge ur walkman for abt 3 hrs first use untill full appears and it is recommended that even if u dont plan to use u r walkman u should atlest charge the battery once a while for battery mentainance try to reset ur update the player firmware.or even then if it dont comes send it to sony or have a converstion with sony support
Jan 31, 2009 | Sony Walkman NWZ-S616F MP3 Player
Sony walkman nwz-s18f froze
I had this problem a few days ago and now my sony nwzs18f has different problems, the way i got it to charge back up was by using a usb charger that plugs into a socket rather than into your computer this should hopfully charge it back up and also it should unfreeze the screen.
hope this helps
Dec 29, 2008 | Sony Walkman Video NWZ-A816 Digital Media...
Will not come on or be installed
Many laptops do not have enough power resources to keep an mp3 player charged/properly functioning. To test, you will need to close all running programs, and devote the laptop solely to the function of charging the mp3 player (the laptop will need to be plugged into a wall outlet even if it has its own battery). This is not a guaranteed fix, but it is your only hope with a laptop. You will not experience the same problem on a desktop unless that mp3 player's hardware itself is faulty.
-Tha Mp3 Doctor
Dec 18, 2008 | RCA OPAL M4001 MP3 Player
Sony Walkman NWZ-S615F problem detecting and syncronizing
I had the same problem. One day my Mp3 started acting weird and said it was not recognizing the files and that i needed to re download them. Try plugging it up to your computer while its charging and hit the power off. Then reset your mp3 with the button at the bottom and it should recognize it.
Nov 17, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
Sansa 1g clip wont turn on.
did you try holding the power button on for ten seconds (the reset) after trying to charge it again? does it even power up when you plug it into the usb. if it powers on when connected to the usb and then shuts off immediately when you take it off the usb (rather than "refreshing database") then your battery is either 1)disconnected inside 2)dead or there may be issues with power management. Same thing happened to me (disconnected) but I soldered the loose connection and it only worked for two days, even checking the connections again. Now I don't know what's going on. It's more likely the battery has reached the end of its life.
Nov 16, 2008 | SanDisk Sansa Clip MP3 Player
66 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
