Question about JVC Televison & Video
My jvc dvd player is not reading the disc. - JVC Televison & Video
  • JVC Master
  • 6,993 Answers
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.....
Posted on Mar 23, 2011
4 Suggested Answers
SOURCE: jvc xv-s332 dvd player won't play
on the back is a seitch labelled ntsc/pal. flick it the other way might fix it
Posted on Mar 09, 2008
SOURCE: Sony DVP-CX995V 400 disc DVD Player wont read DVD-
After variety of different tests and findings I have resolved this issue. It appears that the DVD burner was not in good working order and the DVD player was not at fault. Thanks you to all who answered and responded to my problem. Many thanks.
Posted on Aug 20, 2009
  • 25 Answers
SOURCE: DVD Player stops reading disc Error message :
usually this happens when lens cannot read the the disc. Due to few reason 1 Your disk is scratched 2 Your DVD lens is covered with dust 3 You need to replace DVD lens
Try another few CD/DVD to rectify whether there is any problem with dvd you are trying to play
if this error occurs on all the dvd you played then the most likely proble is with your DVD lens either its coverd with dust use Disk cleaner if not you got to replace a new DVD lense as per model
Posted on Feb 18, 2010
Jvc dvd/vcr player records from vcr to dvd but only plays back the dvd on the jvc DR-MV79 won't play on any other dvd players
Have you finalized the DVD in question? Unfinalized discs usually won't play in other machines. Is the DVD type compatible with the other dvd players? (Some may not handle DVD+R for example; it is an acceptable disc for the jvc DR-MV79.) Try a different brand and type of DVD. Check your other players supported discs.
To Finalize the disc, Menu > Setup > Disc Setting > Finalize (if needed set Disc Protection to Off).
I hope this helps.
Dec 25, 2010 | JVC Televison & Video
Flashed my XV-NP1 with wrong firmware. now player wants original firmware CD. I need original firmware ISO!!!
  • Check the DVD player to ensure that you do not have a DVD disc inserted into the device. Press the "Eject" button and lift out any DVD present in the device.
  • Turn off your JVC DVD player.
  • Unplug the device from the power source.
  • Examine the front or rear of your DVD player and note the model number.
  • Reset your particular device using the "DVD Reset Procedures" documentation provided by JVC (see Resources). Cross-reference your particular device's model number with the instructions provided within the reset procedure documentation
  • Read more: How to Reset a JVC DVD Player ' eHow.com http://www.ehow.com/how_6940950_reset-jvc-dvd-player.html#ixzz16g5rec91
    Nov 29, 2010 | JVC XV-NP1SL DVD Player
    Cannot read disc
    The reason your DVD player is not reading disc is because the lens is not reading the disc.
    The reason the lens is not reading the disc is either because the lens is weak or dirty.
    Try to clean the lens with a lens cleaner.
    test it with a DVD, to see if it will work.
    If it does not work, then the lens is weak and needs replacement.
    to replace the lens,
    open the player with the appropriate screwdriver, open the disc tray, and replace the lens with a new lens, test it with a DVD disc.
    take care
    Jun 15, 2010 | JVC DR-MH30S DVD Recorder
    My jvc dvd player/vcr will not eject disc says its reading but wont play or eject
    You might want to check the thin ribbon cables attached to the dvd inside the unit, pull them out and slip them back in.
    Nov 24, 2009 | JVC HR-XVC27U DVD Player/VCR
    DR-MV100B will not read disc
    It could be a dirty laser. Try running one of those laser cleaning disks through it. That might help
    Sep 22, 2009 | JVC DR-MV100B DVD Recorder/VCR
    Jvc dvd player no disc error
    Hello!
    I did have a similar problem. It was solved by cleaning the laser lenses/prisma. You have to dismantle the whole pick-up the to see the laser lenses.
    There is one lens which is held by couple wires and below there is prisma/mirror.
    I did use ear-cleaner-stick and desinfection liquid (with alcohol) for cleaning. Now it works!
    Aug 16, 2009 | JVC XV-N312S DVD Player
    Jvc th-c50 will not read disc.
    first of all check the region of the DVD player & the DVD disc. Well, you could try this link, to help you crack the region restrictions on your DVD Player.
    http://www.digitalpinhead.com/dvd-unlock/?pu=false&srec=true
    Hope this helps:)
    Oct 19, 2008 | JVC Televison & Video
    Some blank DVD+R discs will not read on my DVD player
    The JVC DR-MV1S DVD Recorder / VCR Combo does not suppport DVD+R, only DVD-R, -RW etc.
    At least mine only supports these formats, as when I first bought mine, I got some blank DVD's they were DVD+R.
    I recorded a movie onto one on my PC, then tried playing it in the JVC unit... no go!
    Instruction manual (available for D/load online) proved to me that I could not play +R disks!!
    Jun 11, 2008 | JVC DR-MV1S DVD Recorder/VCR
    Jvc xv-s332 dvd player won't play
    Jan 25, 2008 | JVC XV-N322
    JVC DVD Player/Video Cassette Recorder Model HR-XV2EK
    try to clean your machine by playing a lens cleaner disc coz the lens might be dirt enough not to pick on data from the discs you play. if it does not work then isuggest you change the lens coz it might be weak
    Aug 01, 2007 | JVC DR-MV1S DVD Recorder/VCR
    Televison & Video Logo
    1,105 people viewed this question
    Top JVC Televison & Video Experts
    Jaime Hernandez
    Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
