Question about Panasonic PT-53WX42 53" Rear Projection Television
Picture out of line Problem with the Panasonic PT-53WX42 53 in. Rear projection. Possible convergence circuit? How do i change it
  • Panasonic Master
  • 8,457 Answers
Picture colors lines R,G,B mis alingments,have colors shadows pictures or 3D pictures look alike?Yes.The tv convergence board is dead,the board require changes 2 STK convergence ICS and some or all of it resistors too.To fix the tv convergence board.U must have tools like a soldering iron,a desoldering pump or a roll of desoldering braids and also can do soldering work?Yes,tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit belong to ur tv model and make to repair it ur self.Or the shop will cost u like $300-350 for parts and labors.
Posted on Mar 23, 2011
Convergence Circuit Schematic diagrahm for my panasonic cinemavision rear projection HD TV? Picture of the convergence circuit on my circuit board.
I will need the model number of your set to assist you with your request. Please respond to this same post for assistance
Oct 21, 2011 | Panasonic PT-51HX41 51" Rear Projection...
I have a Panasonic pt-53x42 projection tv. I believe i have a convergence problem. I have double lines running along bottom of screen..Any help please...
Yes,this problems is 100% convergence problems,it dead.The tv have colors lines R,G,B mis alignments anywhere in the pictures,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 23, 2010 | Panasonic PT-47WX53 47" Rear Projection...
What is a convergence amplifier
The convergence amplifier is a three channel Integrated circuit which controls the convergence alignment of the three picture tubes in a rear projection TV. Your convergence amps are STK392-110 there are two of them also check the six 2.2 ohm 2watt resistors
Aug 06, 2010 | Panasonic PT-47WX49 47" Rear Projection...
No convergence of color lines
You can get the PT47WX49 Convergence repair kit at the following link which contains all the parts and complete detailed photo instructions on CD so you can do the repair yourself.
www.tvrepairkits.net
Jun 25, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic convergence- Blue Cross line not able to adjust
The panasonic rear projection convergence repair kit #2 is available for your model at the following link under convergence repair kits which has the ICs and resistors plus detailed instructions.
http://servicemanuals.vstore.ca/
Mar 13, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Convergence On Panasonic PT-47WX54j
You dont need codes for the service menu you need to repair the convergence circuit. If the lines wont line up in the customer menu they wont line up in the service menu either. Do you know how to solder? If so we can fix this yourself with a little instruction. Otherwise you will need to call a repairman. A good repairman will run you $300-$500 depending on your area. Let me know what you want to do.
Tim Nolan
Sep 25, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Picture has a green outline
your convergence ic's and possible low ohmage reisistors are at fault.there the large ic's that start with stk
Sep 10, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Convergence
covergence amp ic"S need to be replaced.
Aug 16, 2007 | Panasonic PT-53WX54 53" Rear Projection...
PT-47WX53 blue convergence
you will need to change or have the convergence IC's replaced I'm afraid. Good Luck
Aug 15, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Where can I get parts?
STK392-110=CONVERGENCE IC USE TWO FOR REPLACECEMENT PART= WWW.bdent.com Product Details: The STK392-110 is a convergence correction circuit IC for video projectors. It incorporates three output amplifiers in a single package, making possible the construction of CRT horizontal and vertical convergence correction output circuits for each of the RGB colors using ust two hybrid ICs. The output circuit use a class-B configuration, in comparison with the STK392-010, realizing a more compact package and lower cost. www.partstore.com
Apr 12, 2007 | Panasonic PT-56HX41 56" Rear Projection...
Panasonic PT-53WX42 53" Rear Projection Television Logo
130 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
