Question about Sylvania G-Netbook
I COULDNT CONNECT TO THE INTERNET AFTER REBOOTING 4 OR 5 TIMES NOW IT JUST SAYS LOADING OS SYSTEM AND SITS THERE. I HAVE 3 OF THESE NONE OF THEM WORK. HOW CAN I GET THIS TO BOOT UP
    Genius:
  • 1,267 Answers
You will probably have to re-flash your system. Take a kook at my TIP at: It is looking for apassword (WiFi Network Key) You have to double click on the little computericon down in the right tool bar area, the one with the two side radiating arcs,and possibly has a small red X under it. The red X indicates that it is NOTconnected. When you double click on that icon a window called RT28701 opens up,then you click on Wireless Information tab, then you cursor down to the name ofyour WiFi and high light it and click the connect box. Then another windowopens up called Network Properties. Uncheck "The key is providedautomatically" box. This will allow you to type in your "NetworkKey", the password that protects your network from outsiders. This"KEY" was set up when you installed the router on your servercomputer. If this does not work at first, turn the machine over on its back andusing a toothpick, insert it into the little hole about an inch diagonally fromthe right corner of the data plate, this will re-load a new copy of everythingincluding the WiFi RT28701 driver. sometime thisdriver gets confused. See my TIP at: It is looking for a password (WiFi NetworkKey) You have to double click on the little computericon down in the right tool bar area, the one with the two side radiating arcs,and possibly has a small red X under it. The red X indicates that it is NOTconnected. When you double click on that icon a window called RT28701 opens up,then you click on Wireless Information tab, then you cursor down to the name ofyour WiFi and high light it and click the connect box. Then another windowopens up called Network Properties. Uncheck "The key is providedautomatically" box. This will allow you to type in your "NetworkKey", the password that protects your network from outsiders. This"KEY" was set up when you installed the router on your servercomputer. If this does not work at first, turn the machine over on its back andusing a toothpick, insert it into the little hole about an inch diagonally fromthe right corner of the data plate, this will re-load a new copy of everythingincluding the WiFi RT28701 driver. sometime thisdriver gets confused. See my TIP at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing AdditionalInformation When I try to signon with the red X showing, I get "The page cannot be displayed If I thendouble click on the icon down in the right corner I elucidated above, RT28701opens up to "Internet Protocol (TCP/IP) with all zeros in the IP addressfield, and Subnet Mask, with no entries in the default gateway. That is a clueto me that the automatic sign on has not found a viable network, or needssomething else. If I then click on Wireless Information tab, the list ofavailable networks, appear in the box. The machine keeps trying to associate myprevious entered name site with my preferred site and tells me the signal isgood, but it cannot link up. This is a signal to me that it has lost my NetworkKey or that the softwarehas failed or both. I then click on advance and delete my preferred network andhit OK, this will force the software to ask me for my network again, and noticethat the preferred is missing. I click on the name of my network again and thenhit connect., then the Wireless Network properties window opens up and I caninsert my Network Key again after I uncheck the "The key is providedautomatically" box. I enter the key and hit the OK button. I still do notget a connection, so I reboot the machine, and wait for about 30 seconds andthe machine synchs up because the little RED X under the icon has disappeared.Now the machine will hook to the internet as long as I want to, but sometimeswhen I turn the machine on it will not synch, so I go through the abovesequence again. The secret is once you have entered your key and ask for themachine to synch up you have to reboot. Why? I do not exactly know, but Isuspect that the WiFi driver looses it You may also wantto look at the TIP http://www.fixya.com/support/r7679654-sylvania_syneto7526_wirless_keyboard To make your knowledge complete AdditionalInformation When I try to signon with the red X showing, I get "The page cannot be displayed If I thendouble click on the icon down in the right corner I elucidated above, RT28701opens up to "Internet Protocol (TCP/IP) with all zeros in the IP addressfield, and Subnet Mask, with no entries in the default gateway. That is a clueto me that the automatic sign on has not found a viable network, or needssomething else. If I then click on Wireless Information tab, the list ofavailable networks, appear in the box. The machine keeps trying to associate myprevious entered name site with my preferred site and tells me the signal isgood, but it cannot link up. This is a signal to me that it has lost my NetworkKey or that the softwarehas failed or both. I then click on advance and delete my preferred network andhit OK, this will force the software to ask me for my network again, and noticethat the preferred is missing. I click on the name of my network again and thenhit connect., then the Wireless Network properties window opens up and I caninsert my Network Key again after I uncheck the "The key is providedautomatically" box. I enter the key and hit the OK button. I still do notget a connection, so I reboot the machine, and wait for about 30 seconds andthe machine synchs up because the little RED X under the icon has disappeared.Now the machine will hook to the internet as long as I want to, but sometimeswhen I turn the machine on it will not synch, so I go through the abovesequence again. The secret is once you have entered your key and ask for themachine to synch up you have to reboot. Why? I do not exactly know, but Isuspect that the WiFi driver looses it You may also wantto look at the TIP http://www.fixya.com/support/r7679654-sylvania_syneto7526_wirless_keyboard To make your knowledge complete
Posted on Mar 25, 2011
My s8 polaroid tablet wont load
None of these answers are relevant to the question being asked, I too have this problem the device is a POLAROID S8 tablet, not Samsung and not virus related, the device just sits at the polaroid splash screen and will not boot into the os
Dec 25, 2013 | Polaroid Tablets & eReaders
My ti nspire cx cas is totally stuck at the loading screen , it keeps reloading and reloading with a sign at the left corner at the bottom that say's that my battery is empty ? what should i do ?
I have a doubt, when I choose to completely format the calculator it will clear your operating system, files saved on it, but the product key (ID protuto) will be deleted too?32d3cd84-9b87-4f5d-abfe-aa04ca86df4c.jpg
Dec 18, 2012 | Texas Instruments TI-Nspire CX CAS...
When I turn on my Acer Laptop it brings me to a screen with options for Safe Mode ect, and other options like "Start up normally" When i click normal start it brings me to the Microsoft Windows...
Possible that PC is hanging up as there is fault on the OS ( operating system) and so the windows XP must be reloaded. Use a recovery disc if you have one . So if you are able to get to the main screen then open the internet options in the browser and clean all the cookies, temporary internet files, defragment the drives and RESTORE the PC to an earlier set date.
You can use a registry cleaner like Advanced system care. Download from the site and check you system for corrupt files. Also use a good antivirus software which is active to keep your system performing without an attack on the OS. Remove all unnecessary programs installed which you do not use all the time and clean up the drives. This will free up the space and make your system faster.
If there is no response but the PC tends to work slower and occasionally hanging when a program is being executed then you might have to install the OS once again. Install the OS and then an antivirus before the drivers of the PC is installed.
Jul 30, 2011 | Computers & Internet
Need internet connection
HI. Welcome to Fixya!
First of all you need to have an broadband internet connection or a wireless router for this to work.
I will provide you the step by step procedure on how to connect your NIntendo DSi to an internet.
1. Turn on your DSi and click on the system settings (If you don't know where the system settings is, it's the wrench icon)
2. Go to page number 3 and select "INTERNET"
3. Choose "CONNECTION SETTINGS"
4. Click on "NONE" for Connection 1
5. Click on "SEARCH FOR ACCESS POINT"
6. The Nintendo DSi will now search for available wireless connections. Once it's done searching it will show you the internet connections available. Look for your internet connection and click on it. It will now connect you to the internet.
I hope this helped solved your problem.
Jun 17, 2011 | Nintendo DSi Black Console
How can i connect internet in my dsi
To connect to the internet in a Nintendo DSI: 1 You must either have broadband internet access and a wireless router or you can connect your Nintendo DSi at a hotspot, such as a library or coffee shop that offers internet access. Make sure you are in a location mentioned above before going to step 2. 2 Turn on your Nintendo DSi and click on the wrench icon. This will take you to the system settings. 3 Go to page 3 and select "Internet". 4 Click "Connection Settings". 5 Click "None" to the right of "Connection 1". 6 Click "Search for an Access Point". 7 Look for an access point that has a gold lock that is unlocked. Select that access point and your Nintendo DSi should now be connected. 8 If you are planning on playing games online with your Nintendo DSi and have WPA security, you will have to set your router to WEP security. To do this, get back to the "Connection Settings" screen mentioned in step 4. Click "Advanced Setup". Click any button that says "none". Click "Search for an Access Point". Look for an access point that has a gold lock that is unlocked. Select that access point and your Nintendo DSi should now be connected.
Apr 03, 2011 | Nintendo DS Console
How to conect with the internet
1. You must either have broadband internet access and a wireless router or you can connect your Nintendo DSi at a hotspot, such as a library or coffee shop that offers internet access. Make sure you are in a location mentioned above before going to step 2.
2. Turn on your Nintendo DSi and click on the wrench icon. This will take you to the system settings.
3.
4. Click "Connection Settings".
5.Click "None" to the right of "Connection 1".
6. Click "Search for an Access Point".
7. Click an Access Point with an unlocked golden lock.
Doing this should connect you whit the internet.
Oct 30, 2010 | Nintendo DS Lite
I got a used Dell Inspiron 700m, no internet
HI,
if the port has light, this means the computer is detecting the internet signal . The problem could be some settings on the internet explorer.Maybe the previous owner might have made customer settings.
Reboot the system and when you see the Dell Logo screen . tap on the f8 key slowly 5-10 times
Select safe mode with networking from the list
Select the default os and hit enter
Wait till system takes you to a login screen
Login as the adminstartor
Click on Yes
Now try connecting to the internet
If the same works , create a new user account .
How to create a new account ?
1. click start >click control panel
2. Click on user account
3. Click on create new account
4. Restart the computer and login with the new account and try connecting
Thanks for using fixya
proton
Aug 28, 2009 | Computers & Internet
When I connecting HTC P3470 (USB), after rebooting my internet-connection doesn't work
for vista you need Windows Mobile Device Centre as ActiveSync is not supported by Vista.
May 23, 2009 | HTC P3470 Cellular Phone
Dell Dimension 8250 won't boot-up IDE fail code 5
install your OS and then firstly run chkdsk..
Jan 21, 2009 | Dell Dimension 8250 PC Desktop
Sylvania G-Netbook Logo
397 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
