Question about Kenmore 13485 Wine Cooler
Our kenmore wine cooler started leaking water all over the floor.
  • 604 Answers
I don't know how it is leaking water, it isn't hooked up to a water supply. better start looking for the actual source of the water
Posted on Mar 23, 2011
Beeping will not stop on wine cooler - red wine side
Beeping usually indicates that something has gone wrong. Probably not cooling properly. The water coming out would indicate that the unit has defrosted. Turn the unit back on again and see if the red side is cooling properly. Some wine fridges have independent evaporators which allows different cooling temps in different parts of the cabinet.
Jun 26, 2014 | Danby DWC2727BLS Silhouette 54-Bottle...
POOL OF LIQUID FROM VESTFROST WINE COOLER ON FLOOR
it's not the refrigerant - that is a gas. It may be water from inside, or oil from a leaking pipe. If it's oil it's not a diy job
Apr 15, 2014 | Breezaire WKL 4000 Wine Cooler
Marvel wine cooler leaks water
All coolers produce water as a result of condensation which occurs when air is cooled. The water appears upon the radiator (technically called the evaporator) inside the cold area of the cooler. When the water drips off of the radiator, it is caught by a pan which may or may not be a removable piece. The pan should lean toward the rear of the cooler and the water should pour into a drain tube. The drain tube should lead down into the compressor area of the cooler and deposit the water into another pain which is outside of the cooler where it should evaporate back into the air. Sometimes "cardboard" fins are used to help the water evaporate. Sometimes a pan with a huge surface area is used to help the water evaporate. Other times the pan is literally on top of the compressor. Make sure the cooler itself is level. Make sure room air is able to move over the pan where the water is supposed to evaporate. Make sure the drain hose is not clogged. Make sure pans are not leaking.
Jun 11, 2011 | Marvel (6SBARBSG) Wine Cooler
Myy cooler isnt getting cold
there will be a leak in the pressurised line, leak check it with soapy water. if you cant find anything then get it re gassed, hope this helps :)
May 03, 2011 | Emerson (025806803716) Wine Cooler
It leaks water from underneath
It is not really leaking water (did you put water inside?) ... that is probably condensate ... a by product of the cooling process. Are you in a high humidity area? If yes ... that is the primary reason for this water.
Here in North America, we think that only white wine should be chilled and then only to 'celler' temp (or about 55 degrees F.
You may be able to reduce the water problem if
(1) up the temp in the cooler (it isn't a refrigerator - don't use it as one)
(2) don't put 'hot' wine inside
(3) put a small fan blowing on the cooler to help evaporate the condensate.
If the water is a big problem, sit your frig on a big tray, similar to the one you might put under your car in the garge to catch dripping oil.
I hope you find these suggestions helpful.
Thanks for visiting and please come again.
Feb 05, 2011 | Haier BC112G Wine Cooler
Kenmore wine cooler 13485 spill wine in the top not cooling
if suction line is warm and pressure line hot . sounds like comp is trying to do its job / ck the fans and they may be slow or not going . spilling of the wine did not cause problem . .. but now is the time to correct the problem .. mm / ps if unit is running like you state the you might look at the ref charge . as it may be low . mm . hope this hs helped . feed back pls .. mm
Jul 22, 2010 | Kenmore 13485 Wine Cooler
Water seeping out the bottom of my wine cooler
there should be a drain pan that you will periodically remove. Condensate (water) is a normal byproduct of all refrigeration devices. Also look for a drain fitting that you can run to a waste line.
Nov 25, 2008 | U-Line Wine Captain (2015WC) Wine Cooler
Water leaking from unit
It may be the drain line is not dripping into the catch bucket under the back side, visually check to see if the line is reaching into the bucket and that it's not clogged up on the inside of the unit floor. The back panel being wet may just be condensation in between cooling cycles as the frost melts. If the unit is OK with keeping temps the refrigerant charge is likely OK.
Nov 21, 2006 | Haier HVF060A Wine Cooler
Kenmore 13485 Wine Cooler Logo
521 people viewed this question
Top Kenmore Furniture Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Kenmore Furniture Expert? Answer questions, earn points and help others
