Question about Kitchen Ranges
Brand new brada chest freezer (7.0 cubic feet) ice build up under door seal and water on door seal.We only puchased this freezer on Dec. 26 and after 4 service calls that even stumped the service tech we were finally able to have it replaced.The same thing is now happening with the replacement.From what the store told us we seem to be the only people who have had any issues with this particular product Any advice to solve this issue would be greatly appeciated. PS The store won't take the appliance back we would only get a store credit.
  • 183 Answers
SOURCE: ice build up on fan
problem is most likely caused by water overflowing from ice tray and then freezing to motor, hold light switch in and see what happens when tray fills up. Regards Advisor
Posted on Aug 23, 2007
Falling Down
  • 67 Answers
SOURCE: door liner on chest freezer broke due to ice build-up
if you can't find a replacement, use a piece of flat vinyl siding that goes on houses. You can heat it and bend it as needed, or cut it and screw the pieces to a balsa wood frame for lightweight support. Glue or epoxy probably won't work as the cold temps make them brittle but external caulking may be ok to hold the pieces together. Be sure to sand all edges and corners as the cut plastic can be sharp. If you can disassemble the unit and place the door face down, you can fill the cavity with insulating foam to help stabilize it.
Posted on Nov 30, 2007
  • 2692 Answers
SOURCE: oven door not sealing?
These doors have springs to shut them. If you can figure out how to get to the springs usually you will see that one is either unhooked or unattached at one end. If broken on the end bend another hook into it and add a pice of wire long enough to make up the broken difference.
Posted on Jan 01, 2009
jumptrout51
  • 3361 Answers
SOURCE: F1-7 error displayed
A shorted membrane key pad or defective wiring harness.
Posted on Mar 10, 2009
  • 226 Answers
SOURCE: my brand new freezer wont freeze
I would plug it into a different plug in - not one that is on the same circuit that it is plugged into now. If the plug in is working for other things, it still may be bad and not able to handle the load of the freezer. If your freezer will not work on a completely different circuit, then there could be something wrong with the freezer, but it is not likely since two of them should not be bad. Seems to me more like an electrical problem in your location. Hope this helps you, Rick
Posted on Apr 29, 2009
Water leak under freezer door
the drain should be at the very bottom of the freezer. but it sounds like ur door gasket aint sealing all the way so ur freezer is trying to over compensate for the warmer air coming in
Jan 04, 2014 | Samsung RS267TDWP 26 cu. ft. side by side...
Cubic feet for Frigidaire Chest Freezer MFC13M4FW3
Good Morning, thank you for your question! This particular unit is a 12-13 cubic foot freezer. If you have further questions, please do not hesitate to reconnect.
Jul 20, 2013 | Frigidaire 5 cu. ft. / 142 liter Chest...
Freezer is not defrosting
1. Remove all of the food from inside the freezer and place it into the ice chest. Use more than one ice chest, if necessary. Cover the food with ice from a 10 lb. bag of ice. Alternatively, place all of the food from your freezer into the refrigerator compartment, packed tightly together.
2. Place one or two 10 lb. bags of ice into one or two large bowls inside the refrigerator compartment to keep the food chilled. Keep the door to the refrigerator tightly closed and avoid opening it during the freezer defrosting process.
3. Unplug the unit and leave the freezer door open.
4. Let the freezer defrost overnight or for at least eight hours.
5. Use the towels to wipe up the melted ice.
6. Plug in a hair dryer and direct it to the interior of the freezer to melt any remaining ice from the walls and door. Be sure to direct it into the vents of the freezer, too.
7. Wipe up any water from ice melted with the hair dryer from inside and around the freezer.
8. Plug the freezer back into the outlet, and return food still solidly frozen to the freezer compartment from the ice chest or refrigerator. Use any thawed foods within a day or two or discard.
May 25, 2010 | Maytag 21.0 Cu. Ft. Top-Mount Refrigerator...
Ice crystals forming on inside front freezer panel
Very possible the door seal is not properly sealed. Warm inflowing air onto a cold coil will cause ice build up at the lid.
Oct 08, 2009 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Freezer builds up frost and ice too quickly.
Either the door gasket is not sealing well or the unit is low in refrigerant.
Sep 24, 2009 | Freezers
I keep having frost and ice build up in the upper corners of teh freezer. It will make it difficult soon to slide the doors open. What could be the problem?
Any freezer without automatic defrosting will build this up over time but a poor gasket seal between lid and chest can accelerate the buildup of frost.
If you want to check the quality of the seal, you could use food coloring (I'd choose green or blue) in water, add a drop of dish detergent and apply this mix to the sealing surface of the chest. Closing the lid gently and then reopening it, you may be able to see if the contact between sealing surfaces is as it should be.
The mixture will wipe off easily with a clean cloth or paper towel.
Apr 30, 2009 | True 598-THF29FL Horizontal Spot Freezer...
Chest type freezer icing up real bad
I quick way to test the door seal is take a dollar bill close the door on it if you can pull the dollar out with little resistance the seal needs to be replaced. That is what I am thinking is wrong with unit.
Dec 03, 2008 | Freezers
Chest freezer - hose adaptor?
That would depend on the size of the freezer. If it's a compact 5-7 cubic feet, then its not necessarily needed, but if it is a large freezer I would recommend buying the hose adapter. The basic function for the hose adapter is draining the water after defrosting the freezer.
So if it's a large freezer that will not be moved, then YES by all means, you need the adapter.
Nov 19, 2008 | Kenmore Freezer 8.8 cu. ft. Chest Freezer...
Refrigerator on the fritz
The defroster is not working. Ice build up prevents cold air from the freezer chest from blowing into the lower part.
The way the defroster works is this: There is a defrost timer, probably found under the refrigerator at the front, that turns on the defroster three times per day or so. That turns on a heater nested among the freezer coils. It keeps heating until the defrost thermostat gets warm; then it quits defrosting.
I think your defrost timer doesn't turn. You can turn it with a screw driver till you hear a click. Now your ice compartment should be defrosting. With ice buildup it may need lots and lots of defrosting. You might not get cooling back into the lower part for awhile, till the ice buildup melts.
By the preceding, you should know if the defrost timer needs replacing.
If you should need to manually defrost the freezer coils, they are, I think, under the floor of the freezer. To defrost them, I'm told, a hair drier works better than boiling water. The defrost thermostat is in there too, a one inch unit with two wires. It should have no continuity warm, closed circuit frozen. If it has open circuit frozen, that would be your problem.
Jun 14, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kitchen Ranges Logo
151 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
