Question about Gateway GT5082 PC Desktop
When turned on my computer freezes while starting
    Master:
  • 515 Answers
Safe mode works? last known good configuration in the options may skip some hardware settings issues. restore default BIOS after you take a note of all the settings there and see whether that will help. otherwise you may boot from CD or USB drive, backup the data and restore the operating system or restore to factory default.
Posted on Mar 23, 2011
Why do i have to reboot 4 or 5 times to get it to work?
This is probably done to the bios on start up you will need to load new bios when you get connected
May 09, 2010 | Acer Aspire One PC Notebook
Screen freezes on start up power off,power on freezes again .whats the problem ?
Hi ,
This happens when a startup program is is corrupt or is not responding.It can also be that a hardware is gone corrupt that is making the computer freeze.To correct the problem please follow the trobleshooting steps listed below.
Disconnet any external devices that you have added after you bought the notebook like usb devices ,printer etc.Then turn the computer on and see if the computer freezes or not .If it does not freeze then it means that there is an external device that is causing the problem and to find it out you need to connect one device at a time and check .
U can also do this .Turn the computer off completely and then when you turn the computer on keep on tapping the F8 key till it loads the advance boot menu page then select safe mode just plain safe mode and hit the enter key .Wait till it loads the the log on screen then select administrator.It will take you to the desktop and check if the computer freezes or not .If it doesn't then it means that there is a program that is causing the computer to freeze.Go to start?run ?type in msconfig?enter?click on the startup tab ?click on disable all?apply ?select the services tab?click on disable all ?apply ?click on ok or close to exit from the page and then select restart when it prompts you to .When it is booting up to the normal mode check if the computer freezes.Then you will have to find the program that is causing the computer to freeze.To do this first enable all the startup program and then check if it doesnt then its a program under services that is corrupt .S o select one or more program restart and check so this way you will have to isolate the program and then just leave that program unchecked.
Hope this post helps you ...all the best
you can revert if this does not work....
May 08, 2010 | Medion MD-40954 Notebook
Compaq presario v2000 freezing after start up. making it impossible to navigate pages to solve
click on start and then click on run.
type in MS config and then click ok.
uncheck the option which says load startup items.
Click on ok to restart the computer.
This should stop the computer from freezing once it turns on.
Apr 16, 2010 | HP Compaq Presario V2000 Notebook
My computer is freezing up, won't do nothing
Freezing often occurs when your computer is receiving several commands at the same time.
First check your Startup Menu and turn off (uncheck) any programs that don't need to run upon starting up (Go to Start, Run, type in MSCONFIG, select "Start Up" tab and uncheck those needless programs). You can always turn programs on manually when needed (such as media players, games, Instant Messaging, etc.)
Second, check the Options or Preferences in your anti-virus and anti-spyware programs and make certain you don't have a constant scan occuring that will slow down your applications.
Third, turn off any programs or applications that might be running but that you're not using. The fewer programs you have running at one time, the less your computer has to process.
Fourth, when your computer freezes, click on your Control/Alternate/Delete keys at the same time and only once. A window will open called a Windows Task Manager. Select the "Applications" tab if it's not already selected, and highlight any programs which are "Not Running." Then click on "End Task" for those programs only. This way you don't have to restart your computer.
Fifth, notice those programs that seem to cause your computer to freeze and either remove them, replace them or reinstall them.
Dec 27, 2009 | Computers & Internet
Dell 1525 laptop keeps freezing
i am suspesioning on Rams. maybe overheating also does that.
May 30, 2009 | Dell Inspiron 1525 Laptop Jet Black
Computer won't start
remove the ram and blow air and clean it in case dust might be formed
fix it and clean the system once and check all socket fittings once and turn it on
Mar 15, 2009 | Computers & Internet
After i've turned on my computer, and used it for about 5 to 10 minutes, the computer freezes and i have to turn the computer off. when my computer freezes my mouse usually does not freeze. sometimes i'll...
You can start by uninstalling the program you installed before this started happening. You can also do system restore which you'll find in start>accessories>system tools.
If nogo, try disconnecting devices on the back of the computer except the keyboard, mouse, monitor and power. Turn the computer on without them. If the issue disappeared, reconnect what you unplugged one at a time until you find the culprit.
Nov 05, 2008 | Computers & Internet
Freezing computer after loading security cd.
Start your computer in SAFE MODE and remove the norton.
To do that >> Turn off your computer >> turn on ...and before windows loading hit F8 and select SAFE MODE
Nov 05, 2008 | Acer TravelMate 2300 Notebook
Startup freezes
There's a driver problem with your wifi adapter. You need to update it. Download the updated driver from the manufacturer's website. Uninstall first the driver then reinstall it using the downloaded driver
Sep 05, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Will not start up normally (freezes )
shift prees then mouse buten click for startup freezes icon then uninstaLL
Jun 24, 2008 | HP Media Center m7060n PC Desktop
Gateway GT5082 PC Desktop Logo
48 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
