Question about Acer Aspire 5551 Notebook
Battery only charges to 86% - Acer Aspire 5551 Notebook
    New Friend:
  • 104 Answers
Restall your battary driver
OR
if the problum not fix then use
buy a new battary
Posted on Mar 23, 2011
Need diagram of charging system for 86 buick electra 3.8 v6
Running should be around 14 something volts. Sounds like your charging system is not working. 1986 MAY have a separate voltage regulator.
Feb 12, 2015 | Buick Cars & Trucks
Wont charge battery
That is probably one of two things, the alternator or the ecu. The voltage regulator is in the ecu.
Dec 13, 2014 | Crown Jeep Cherokee 96 95 94 93 92 91 90...
Break and battery light stays on all the time
sold all over earth, what country> we cant guess this....
don't break the brakes....!!!
my guess, you meant the
brake lamps are on keys in pocket. and the battery lamp is dash(charge) glows, keys in pocket. right?
and battery cable kills all this illegal states above. sure.
86 nissan PU.
720 PU>? Datsun>?
or D21 Nissan ( 1986 Dat-SUNS became NISSANS. in USA)
Model years 1986.5 (second half) and later were called Nissan Hardbody Trucks, chassis code D21.
D21 are called HARD BODY trucks. mid year changes.
so???? which is yours.
as you might not ,know , the models are wired diffrent by different exact models and country.
long ago , i had the 86 with the VG30 V6...
so i will roll the dice and answer for
D21
ok?
things off stay on, 101
bad wiring, hacked in wiring, radios,alarms and other things.
all can cause this..... its old and is common on old cars.
but if wiring is not hacked, (id see that in 10seconds in person)
no hacks.
gas engine car not diesel.
USA 86 body
brakes
Im looking now at the schematic and this car has a hot at all times
brake lamp switch. (foot pedal switch)
SO only a bad switch can cause this.... period
now the dash charge (battery ) light stuck on.
my online source ,has the alternator system missing.
so can not comment.
the lamp gets its power from the key switch
if the key switch fails , all warning lanps glow not just the
charge.(battery)
so its not that
my best guess is wiring errors, that put power the the cluster
key off. id bet that is it .
wiring errors to the ignition output is side, key switched power is failing.
Jul 14, 2014 | 1986 Nissan Pickup 4WD 1986
Why my acer 4741G battery can't charge until 100% and stuck until 86% charge even I have to wait for 3 hours?it's already 1 year since i buy this laptop. Need more assistance, I hope for next, my...
Typical behavior of a faulty battery, cells are not accepting full charge... If its still under warranty, you can get the battery replaced no charge, otherwise you're in to fork out over 100 USD for a new battery pack.
Aug 20, 2011 | Acer Computers & Internet
My acer battery doesn't get full recharge it stop at 86%
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time.
Mar 29, 2011 | Computers & Internet
My hp DV6000 stays charging at 86% and will not complete the charge.
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all.
OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time.
If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Jun 30, 2010 | HP Pavilion dv6000z Notebook
Help on extending the battery life of my acer aspire one!
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, until they won't charge up at all.
The only solution is a new battery.
Dec 26, 2009 | Acer Aspire One PC Notebook
86 Bronco Lost all power (eletrical) and will not start
I own the 87 year model and had a similar experience after being off-road. Found positive cable to be in contact with chassis. try checking to see if this is the case in your situation using an ohm meter with the bat disconnected. should have infinite ohms between pos cable clamp and chassis ground.
Jun 10, 2009 | 1986 Ford Bronco
86 cutlass wont start with a fully charged battery it turns over really slow and drains the battery
Have your starter checked. Once it goes bad it drains your battery very quickly when trying to start vehicle.
Sep 13, 2008 | Oldsmobile Cutlass Supreme Cars & Trucks
Acer Aspire 5551 Notebook Logo
220 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
